Re: McLeod clutches [Re: Gerald l] #2096164
06/22/16 11:43 AM
06/22/16 11:43 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Depends on the bell housing you have.Scatter shield would take both but to use the 130 they sell a kit to move starter over.Rocky
Chrysler Firepower
Re: McLeod clutches [Re: Gerald l] #2120039
07/28/16 06:51 PM
07/28/16 06:51 PM
GA
Gerald l Offline OP
Gerald l  Offline OP
GA
So I contacted brewers and they recommended I get the McLeod 12" instead of the street twin.
McLeod recommended the 11". Guess my question is will the 12" fit in a stock B body bellhousing? I seen on summits sight that it's a truck clutch
Re: McLeod clutches [Re: Beep Beep] #2121075
07/30/16 02:23 AM
07/30/16 02:23 AM
Pinelands , NJ
joelson6 Offline
joelson6  Offline
Pinelands , NJ
Originally Posted By Beep Beep
I have used the Mcleod Rst and Rxt (twin disc) in my 4100lbs RR.
My first stroker motor made 550 torque 500 hp. I used the RST, and intermittently the clutch would slip. I took the clutch apart, and found glazing on the flywheel and discs.
I sent the clutch back to Mcleod, and they rebuilt it under warranty. They said for some reason the clutch never seated properly. I did perform the 500 miles break-in period.
Mcleod wanted me to use the RST again. Since I replaced the cam/intake on my motor, It now made 600 hp and 650 torque. I decide to use the RXT, and I am currently breaking it in. Breakin is very important.
The clutch feels very light. It's a pleasure to drive in heavy traffic. The pedal effort feels very close to a new car.
Centerforce did not recommend the DF for my setup because my car weight and power. I think they mentioned it was good for 500-550 hp in a 3500lbs car.
I also have an RXT in my '74 Challenger and I love it. I used Ram 3200# pressure plates and the 900 series discs and use to eat them up like candy. never go back to the Ram clutches.
I have a CF II in my all stock '72 Challenger and that's awesome too. it doesn't get a lot of abuse though. had to remove the over center spring too.
