Re: Porting iron P-car heads & whoops! [Re: DARTH V8Я] #2092201
06/15/16 01:14 AM
06/15/16 01:14 AM
central texas
K
krautrock Offline
krautrock  Offline
K
central texas
braze it up???
Re: Porting iron P-car heads & whoops! [Re: DARTH V8Я] #2092261
06/15/16 08:55 AM
06/15/16 08:55 AM
Charlotte, North Carolina
sgcuda Offline
sgcuda  Offline
Braze it or put some threads on it. Smear JB weld over a piece of threaded rod with a screw slot on the end of it.
[image][/image]
Re: Porting iron P-car heads & whoops! [Re: DARTH V8Я] #2092320
06/15/16 10:33 AM
06/15/16 10:33 AM
Its a TRAP!
DARTH V8Я Offline OP
Oh No!! I just had a moron attack!
Its a TRAP!
I'll try the JB weld. It's a small banana shaped hole at the very bottom. About double the width of a credit card looked edge on. Thanks.
When it takes more than a sweet mullet to prove you rule at the trailer park..
Re: Porting iron P-car heads & whoops! [Re: DARTH V8Я] #2092398
06/15/16 01:01 PM
06/15/16 01:01 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
I guess I'm confused.......the air injection hole goes all the way through.
How do you hit water like that ?
Re: Porting iron P-car heads & whoops! [Re: DARTH V8Я] #2092471
06/15/16 03:09 PM
06/15/16 03:09 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
Way to learn😅
Re: Porting iron P-car heads & whoops! [Re: FastmOp] #2092475
06/15/16 03:20 PM
06/15/16 03:20 PM
Its a TRAP!
Its a TRAP!
Originally Posted By FastmOp
Way to learn😅
Gotta start somewhere.
Dunno. Drilled 5/16ths as suggested, boom water. Drilled the first two to the same depth, no problem.
Re: Porting iron P-car heads & whoops! [Re: fast68plymouth] #2092476
06/15/16 03:20 PM
06/15/16 03:20 PM
Washington
madscientist Offline
Washington
That's what I'm wondering. If you are just cleaning the hole up to tap how did you find water?
You could have turned some stock down on a lathe and just pressed them in.
You are just plugging a a small hole.
Re: Porting iron P-car heads & whoops! [Re: madscientist] #2092480
06/15/16 03:26 PM
06/15/16 03:26 PM
Its a TRAP!
Its a TRAP!
That's what she said. HAHA.
Don't have a lathe unfortunately. I'll fix her up. smile
Re: Porting iron P-car heads & whoops! [Re: DARTH V8Я] #2092485
06/15/16 03:29 PM
06/15/16 03:29 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
All you need is some 1/8" set screws. You don't have to plug the holes with plugs that large. I didn't even have to drill my heads. I just bought a new tap and went at it.
Re: Porting iron P-car heads & whoops! [Re: burdar] #2092493
06/15/16 03:44 PM
06/15/16 03:44 PM
dogdays Offline
dogdays  Offline
Good luck with the plug. In cases like this JB Weld is your friend.
I don't believe anyone said drill with a 5/16" drill bit. I did say to use a 5/16" tap and drill with the correct size drill bit. This info used to be stamped right onto the tap shank. I only drilled as far as the tap would go in. In your case it illustrates that blocks weren't the only thing to have core shift.
I am convinced that once the AIR hole is cleaned out, filling it with JB Weld would keep things sealed up for the rest of time. So that's what I'd do with the hole in your cylinder head.
R.
