What cam bearings for my 400 block ? #2091223
06/13/16 02:38 PM
06/13/16 02:38 PM
robin hood country
deaks Offline OP
deaks  Offline OP
robin hood country
One of our suppliers in england has the Clevite BYSH876S, will these be ok for my stroker ?
Mick
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200#
best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft
best 60ft 1.36
Re: What cam bearings for my 400 block ? [Re: deaks] #2091227
06/13/16 02:49 PM
06/13/16 02:49 PM
Mt Morris Michigan
mopar dave Online content
mopar dave  Online Content
Mt Morris Michigan
I don't know about those, but I just bought king cs533hp cam bearings for my 400 block.
Re: What cam bearings for my 400 block ? [Re: deaks] #2091268
06/13/16 04:18 PM
06/13/16 04:18 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
Mick
I think that is the standard replacement cam bearing. I don't know of any problems with it? Maybe some of the engine building pros will post their thoughts.
I think that should be "B-1 SH876S", the B-1 is the bearing Material, "B-1 Steel backed tin or lead base conventional babbitt
(nominal .020” thickness)".
The Clevite Performance cam bearings use "B-2 Steel backed tin or lead base with a Micro-Babbitt
lining (nominal .006” thickness)", park #SH2152S.
I have been using the Dura-Bond PDP-17 cam bearings.
I do recall having fitment issues with some King cam bearings, but I don't recall if the issue was the bearing or the cam?
We installed the cam bearings and the cam would not fit, ended up removing the cam bearings and one would not fit over the cam journal (uninstalled from the block?) Like I said, not sure if it was the cam, bearing, or maybe a wrong marked bearing (it fit the block OK, and I think the part # was correct too?)
Link to related topic:
https://board.moparts.org/ubbthreads/ubbt...vs-clevite.html
Re: What cam bearings for my 400 block ? [Re: deaks] #2091730
06/14/16 12:23 PM
06/14/16 12:23 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
Mick
What type of cam , what spring pressures ?
Re: What cam bearings for my 400 block ? [Re: deaks] #2091859
06/14/16 04:11 PM
06/14/16 04:11 PM
robin hood country
deaks Offline OP
deaks  Offline OP
robin hood country
Not sure yet, either big solid cam, around 280 at .050 .650 lift, or if money allows similar spec roller, comp will be around 13.5.1.
Mick
best 60ft 1.36
Re: What cam bearings for my 400 block ? [Re: 451Mopar] #2091910
06/14/16 05:04 PM
06/14/16 05:04 PM
Mt Morris Michigan
Mt Morris Michigan
i have been told that most big and small block mopars have issues fitting the cam after bearing replacement.
Re: What cam bearings for my 400 block ? [Re: deaks] #2092028
06/14/16 08:46 PM
06/14/16 08:46 PM
crabman173
crabman173
If housing bores in the block are correct size any bearing will do fine--some of the Clevites are not a one piece but are "joined" together strips The very best out there are the PDP-17 by Durabond--they are harder than std units and are finished much better--we have had great luck with them over the years the standard and cheaper Durabond PD-17 also works very well but seeing as how your sources are limited I would take what you can get and go with it
Re: What cam bearings for my 400 block ? [Re: ] #2092172
06/15/16 12:18 AM
06/15/16 12:18 AM
IN
ahy Offline
ahy  Offline
IN
In general the cam bearing does not have very high loads. Standard replacement bearings should be fine.
The trick is in installation and adjustment. Cam bearing bores do not always line up just so and the cam may want to bind. They can be line honed, or a used cam with grooves cut in the journals can be used to line them up after install or skillful use of a bearing knife per preference and experience of the builder.
Re: What cam bearings for my 400 block ? [Re: deaks] #2092244
06/15/16 06:21 AM
06/15/16 06:21 AM
robin hood country
deaks Offline OP
deaks  Offline OP
robin hood country
I will buy the PDP -17 from Mancini, thanks for your replies.
Mick
best 60ft 1.36
