Re: Trick Flow heads
[Re: fast68plymouth]
#2090930
06/12/16 11:23 PM
06/12/16 11:23 PM
Posts: 1,096 Australia
ozymaxwedge
Australia
You might need to re read Mikes post again
1963 Plymouth Max Wedge 1971 Barracuda
[Re: Jamie McGrath]
#2091098
06/13/16 10:44 AM
06/13/16 10:44 AM
Posts: 561 USA
B3RE
USA
Hummmm, just throwing this out there but same issue with two different brand heads? I assume the same brand housing/wp and thermostat? We all have our pet brands, could the hole in the thermostat not be bleeding? No stat during test or dyno runs. No issue with Edelbrock heads, only the Trick Flow heads. We also tried a Shogun stand alone pump with the same results, so I'm reluctant to blame the water pump in this case. For all I know, there may be something hinky in the block passages that I couldn't see. No matter, I gave the customer instructions to purge the air and avoid overheating once he gets it in the car.
Mike Beachel
I didn't write the rules of math nor create the laws of physics, I am just bound by them.
[Re: B3RE]
#2091184
06/13/16 01:10 PM
06/13/16 01:10 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Hummmm, just throwing this out there but same issue with two different brand heads? I assume the same brand housing/wp and thermostat? We all have our pet brands, could the hole in the thermostat not be bleeding? No stat during test or dyno runs. No issue with Edelbrock heads, only the Trick Flow heads. We also tried a Shogun stand alone pump with the same results, so I'm reluctant to blame the water pump in this case. For all I know, there may be something hinky in the block passages that I couldn't see. No matter, I gave the customer instructions to purge the air and avoid overheating once he gets it in the car. I had a issue on all of my W-type heads... I had a piece of clear plexi tubing in the upper radiator hose to see if water was moving... I would run the engine(in the car) and get it to about 140* and shut it down.. then turn on the pump(electric) and it would start to flow..let the pump run about 5 minutes then fire up the engine... once it purged the air it never had any more issues unless I drained the water.. and had to do it all over again... but the clear tube was a BIG HELP ![wave wave](/ubbthreads/images/graemlins/custom/wave.gif)
[Re: MR_P_BODY]
#2091418
06/13/16 09:43 PM
06/13/16 09:43 PM
Posts: 561 USA
B3RE
USA
Hummmm, just throwing this out there but same issue with two different brand heads? I assume the same brand housing/wp and thermostat? We all have our pet brands, could the hole in the thermostat not be bleeding? No stat during test or dyno runs. No issue with Edelbrock heads, only the Trick Flow heads. We also tried a Shogun stand alone pump with the same results, so I'm reluctant to blame the water pump in this case. For all I know, there may be something hinky in the block passages that I couldn't see. No matter, I gave the customer instructions to purge the air and avoid overheating once he gets it in the car. I had a issue on all of my W-type heads... I had a piece of clear plexi tubing in the upper radiator hose to see if water was moving... I would run the engine(in the car) and get it to about 140* and shut it down.. then turn on the pump(electric) and it would start to flow..let the pump run about 5 minutes then fire up the engine... once it purged the air it never had any more issues unless I drained the water.. and had to do it all over again... but the clear tube was a BIG HELP Mike, That's pretty much what I had to do, sans the clear tube. That would have been a big help. On the test stand, I would start the motor and the temp would slowly start coming up and then start climbing rapidly, so I would shut it down. I had to repeat that about five or six times. Not such a big deal on a roller cam, but now I'm working on a flat tappet build with these heads, and I don't want to be shutting it down multiple times during the cam break in. A judiciously placed bleeder port would be a good idea, if I knew where judicious was. Don, not a bad idea, but I don't have one because I've never needed one before. Surprisingly, no, I've never hotrodded a VW Rabbit ![grin grin](/ubbthreads/images/graemlins/custom/grin.gif) . We used to drive a diesel Rabbit like it was a hotrod though. I might have to invest in one for instances like this.
Mike Beachel
[Re: Cudajon]
#2101397
06/30/16 11:07 PM
06/30/16 11:07 PM
Posts: 31,082 Oregon
AndyF
These are Harland sharp on stock TF pedestals right? Yes, Harland Sharp rocker arms on OOTB Trick Flow heads. No machine work required. Just need to order the correct pushrods and it should work. I'm using the Trick Flow roller cam retainers in the picture and everything clears.
[Re: BSB67]
#2101533
07/01/16 01:22 AM
07/01/16 01:22 AM
Posts: 430 NH, USA
toddinNH
Egghead
Egghead
NH, USA
Maybe I've been asleep for the last ten years, but is this statement from the article believable?
" That’s a bit shy of TFS’s claim, but if nothing else, it does bear out the stingy nature of Westech’s Superflow dynamometer."
Nah, Mr. Stiltskin ![wink wink](/ubbthreads/images/graemlins/custom/wink.gif) I was aghast at both that and the fact that HotRod's(HR) and Trick Flow's(TF) flow bench results were identical. They corresponded(a good word in this instance *ahem*) right down to the last CFM. Shocking! Methinks that HR may have simply co-opted the TF data. (I need that whistling smiley..there we are) Is this what passes for automotive hi-performance journalism? It appears so.. Maybe S. Dulcich can be consulted on this matter. On Edit: I'm not that new..I had an account a decade ago, but lost my username and log-on creds. So this is a new beginning..hopefully
Last edited by toddinNH; 07/01/16 01:26 AM. Reason: added junk about not being a total noob.
[Re: AndyF]
#2102063
07/01/16 07:21 PM
07/01/16 07:21 PM
Posts: 2,094 central texas
krautrock
central texas
Very similiar shortblocks but Steve says the TF engine has TRW pistons while the older article says Probe pistons. Otherwise they seem to be the same shortblock. oh yeah i see that now, missed that caption last night
[Re: cudadoug]
#2102100
07/01/16 08:43 PM
07/01/16 08:43 PM
Posts: 561 USA
B3RE
USA
What is everyone's thoughts on the TF heads on a smaller bore: Say 4.280?
A friend and I are knocking around ideas a street/strip build and his one fundamental wish is to use his current 383 block, with a stroker kit.
Discuss... Screwing one together right now. I just finished the short block, and will complete the top end after the holiday. The bores really need to be notched for a 4.280" bore.
Mike Beachel
