Re: Measuring problems. Can someone help?
[Re: moparmojo]
#2089780
06/10/16 07:28 PM
06/10/16 07:28 PM
Posts: 4,737 Moved to N.E. Tennessee
GomangoCuda
I am not a body man and don't know what they use to measure but after 35 years as a toolmaker in an assembly plant and 22 years programming and operating coordinate measuring machines (cmm's) to measure the dimensional integrity of thousands of car bodies I can tell you that the main datums are going to be gage holes in the bottom of the frame rails. The diagonal measurements that you are referring to are likely between the same holes.
[Re: moparmojo]
#2089817
06/10/16 09:06 PM
06/10/16 09:06 PM
Posts: 5,914 ohio
ruderunner
ohio
Or don't worry about the factory way.
Pick identical points on each side of the car. Measure front to back, side to side and diagonally between points. You can even pick a "cornerstone" point that all diagonal measures need to be equal.
A plumb Bob and tape measure is all you need.
Angry white pureblood male
[Re: moparmojo]
#2091711
06/14/16 12:04 PM
06/14/16 12:04 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Wow, nice graphic and not what's in my 70 FSM. Where'd you get this?
[Re: Supercuda]
#2091789
06/14/16 01:51 PM
06/14/16 01:51 PM
Posts: 10,030 Wisconsin
Aero426
Wisconsin
Wow, nice graphic and not what's in my 70 FSM. Where'd you get this? Aftermarket frame book from the olden days. The ones in the FSM are not the most simple to work with.
[Re: moparmojo]
#2091805
06/14/16 02:48 PM
06/14/16 02:48 PM
Posts: 5,914 ohio
ruderunner
ohio
That needs a sticky! Got one for b body?
[Re: moparmojo]
#2091847
06/14/16 03:56 PM
06/14/16 03:56 PM
Posts: 28,068 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
For the love of God-YES! This is awesome. As soon as I get a moment I will crawl under the car and check out the measurements you posted. I think this is exactly what I was looking for. I'll try doing this on Saturday and let everyone one know how beneficial it is. Thanks Aero! Remember that you'll be measuring center to center on the holes. If you measure between the holes the number will be off the width of the hole. To get it done easily you can measure from the near side of one hole to the far side of the other hole (assuming they are the same size).
[Re: feets]
#2091865
06/14/16 04:21 PM
06/14/16 04:21 PM
Aero426
Wisconsin
Measure holes according to the specific data sheet. Some measurements are edge to edge. Some data providers are center to center. Ball joints are typically edge of hole to center of ball joint.
