My engine likes too much timing, what to do?
#2089427
06/10/16 12:16 AM
06/10/16 12:16 AM
Posts: 591 Champion City
The Sphinx
Champion City
I have a 360 with eddy out of the box heads, hughes 1.6 rockers, 10.5:1compression and a MP .557 cam, MSD digital 6 ignition with an msd pro billit distributor that is locked out, Holley hp750 with 80/82 jets, Eddy airgap intake. For some reason my car just wants more timing. At 36 it runs awful, 41 degrees its happier and I'm nervous about giving it more, but the car runs faster the more I give it. So far Ive ruled out the balancer, distributor,and ignition box as I have swapped them out with No change. I did degree the cam and everything came in spec with the cam card and left it straight up. Anybody have any input on what I should do next?
Re: My engine likes too much timing, what to do?
[Re: The Sphinx]
#2089432
06/10/16 12:20 AM
06/10/16 12:20 AM
Posts: 5,163 CT
GTX MATT
CT
Is this 93 pump? Could be fuel atomization issues or way too rich. Whats the AFR? Too cold of a plug? Polarity on the distributor/rotor phasing wrong?
[Re: The Sphinx]
#2089433
06/10/16 12:22 AM
06/10/16 12:22 AM
Posts: 715 Central TEXAS!!!!
sr4440
Central TEXAS!!!!
Have you verified that when timing tab and balancer read "0" that the piston is truly at TDC?
Joe
Without Data, you’re just another guy with an opinion.
[Re: GTX MATT]
#2089436
06/10/16 12:25 AM
06/10/16 12:25 AM
Posts: 52,972 Romeo MI
MR_P_BODY
Is this 93 pump? Could be fuel atomization issues or way too rich. Whats the AFR? Too cold of a plug? Polarity on the distributor/rotor phasing wrong? Could be any of the above... swap the wires at the dist first and see if the timing drops
[Re: GTX MATT]
#2089452
06/10/16 12:50 AM
06/10/16 12:50 AM
The Sphinx
Champion City
Is this 93 pump? Could be fuel atomization issues or way too rich. Whats the AFR? Too cold of a plug? Polarity on the distributor/rotor phasing wrong? Yes 93 octane, plugs look good for fuel mixture, yes my plugs are too cold, as for the polarity it plug and play, GI proof cable. Could too cold of a plug cause my problem?
[Re: sr4440]
#2089453
06/10/16 12:51 AM
06/10/16 12:51 AM
The Sphinx
Champion City
Joe Did it, it is
[Re: MR_P_BODY]
#2089456
06/10/16 12:53 AM
06/10/16 12:53 AM
The Sphinx
Champion City
Is this 93 pump? Could be fuel atomization issues or way too rich. Whats the AFR? Too cold of a plug? Polarity on the distributor/rotor phasing wrong? Could be any of the above... swap the wires at the dist first and see if the timing drops Even though the cable is GI proof its worth a shot
[Re: The Sphinx]
#2089459
06/10/16 12:55 AM
06/10/16 12:55 AM
Posts: 2,154 Its a TRAP!
DARTH V8Я
Oh No!! I just had a moron attack!
Its a TRAP!
41? Yikes.. how far back ya retard the cam lol.
When it takes more than a sweet mullet to prove you rule at the trailer park..
[Re: The Sphinx]
#2089478
06/10/16 01:22 AM
06/10/16 01:22 AM
MR_P_BODY
Is this 93 pump? Could be fuel atomization issues or way too rich. Whats the AFR? Too cold of a plug? Polarity on the distributor/rotor phasing wrong? Could be any of the above... swap the wires at the dist first and see if the timing drops Even though the cable is GI proof its worth a shot There was a bunch of those cable made backwards... cut them and try it worst case you you solder it with some shrink tubing... one way it picks up on the leading edge the other way it picks up on the trailing edge EDIT On the dyno my W-5 wanted 40* but that was at the max.. your engine is still looking for more..either the items above or the cam is retarted...you did go off the second valve correct(intake)
[Re: MR_P_BODY]
#2089520
06/10/16 09:25 AM
06/10/16 09:25 AM
The Sphinx
Champion City
Is this 93 pump? Could be fuel atomization issues or way too rich. Whats the AFR? Too cold of a plug? Polarity on the distributor/rotor phasing wrong? Could be any of the above... swap the wires at the dist first and see if the timing drops Even though the cable is GI proof its worth a shot There was a bunch of those cable made backwards... cut them and try it worst case you you solder it with some shrink tubing... one way it picks up on the leading edge the other way it picks up on the trailing edge EDIT On the dyno my W-5 wanted 40* but that was at the max.. your engine is still looking for more..either the items above or the cam is retarted...you did go off the second valve correct(intake) I degreed it off #1 intake, second lifter back. I think I can un-pin the cable and swap it
[Re: Hot 340]
#2089521
06/10/16 09:26 AM
06/10/16 09:26 AM
The Sphinx
Champion City
My buddy had this happen to him once. He used one of those timing lights with the knob on the back. Looked legit with a regular light. His was off. Interesting, sounds like my timing light. I'll try another.
[Re: The Sphinx]
#2089523
06/10/16 09:30 AM
06/10/16 09:30 AM
Posts: 1,495 Shelby mi.
JAKE68
Shelby mi.
[quote=The Sphinx] I have a 360 with eddy out of the box heads, hughes 1.6 rockers, 10.5:1compression and a MP .557 cam, MSD digital 6 ignition with an msd pro billit distributor that is locked out, Holley hp750 with 80/82 jets, Eddy airgap intake. For some reason my car just wants more timing. At 36 it runs awful, 41 degrees its happier and I'm nervous about giving it more, but the car runs faster the more I give it. So far Ive ruled out the balancer, distributor,and ignition box as I have swapped them out with No change. I did degree the cam and everything came in spec with the cam card and left it straight up. Anybody have any input on what I should do next? [/q
Something is wrong if it runs bad with less timing if timing was retarded it would be just down on a little power not run bad. sounds like more timing is covering up a problem.
JAKES AUTOMOTIVE
[Re: The Sphinx]
#2089564
06/10/16 11:33 AM
06/10/16 11:33 AM
Posts: 3,978 Hilltown Pa
1967dartgt
Hilltown Pa
Timing is just a number, if the motor is happy at 41 leave it. My eddy headed motor was 38 and my indy motor was 41. My W9 motor likes 36. Bretts engine master Indy headed motor made the most power at 42 on the dyno.
Brett Miller W9 cnc'd heads STR Chassis fabraction
[Re: The Sphinx]
#2089590
06/10/16 12:15 PM
06/10/16 12:15 PM
Posts: 11,722 Portage,michigan
B3422W5
Portage,michigan
Seen a lot of different small block combo's that like 40.
I pulled Eddie heads off a 416 flat tappet short block years ago that liked 34. Put a W5 top end on that short block and it liked 40. Turn it back to 36 and it slowed down a whole tenth. Later built a roller short block, put the W5 heads on that and it liked 32.
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam Best so far, 10.40 @127 1/4 1.41 best 60 foot 6.60 at 103.90 1/8
[Re: 1967dartgt]
#2089597
06/10/16 12:27 PM
06/10/16 12:27 PM
Posts: 1,267 North, Alabama
D-50
North, Alabama
1967Dartgt which engine masters motor?
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
[Re: The Sphinx]
#2089617
06/10/16 01:25 PM
06/10/16 01:25 PM
sr4440
Central TEXAS!!!!
well I reread your OP, I will bet you are checking your timing at Idle, check your timing at 5000 and see what it is. Some of the digital have bad cases of magnetic hysteresis. I had some digital 7 boxes that drop 1 degree per 1000.
I would really like to see a pic of the plugs.
Joe
[Re: D-50]
#2089668
06/10/16 03:04 PM
06/10/16 03:04 PM
1967dartgt
Hilltown Pa
1967Dartgt which engine masters motor? Yours!
[Re: sr4440]
#2089685
06/10/16 03:45 PM
06/10/16 03:45 PM
The Sphinx
Champion City
Joe I check it at 3000. My fuel air mixture looks good, no noticable annealing line on the ground strap of the plug of the plug
