Page 1 of 3 1 2 3
My engine likes too much timing, what to do? #2089427
06/10/16 12:16 AM
06/10/16 12:16 AM
Champion City
The Sphinx Offline OP
Champion City
I have a 360 with eddy out of the box heads, hughes 1.6 rockers, 10.5:1compression and a MP .557 cam, MSD digital 6 ignition with an msd pro billit distributor that is locked out, Holley hp750 with 80/82 jets, Eddy airgap intake. For some reason my car just wants more timing. At 36 it runs awful, 41 degrees its happier and I'm nervous about giving it more, but the car runs faster the more I give it. So far Ive ruled out the balancer, distributor,and ignition box as I have swapped them out with No change. I did degree the cam and everything came in spec with the cam card and left it straight up. Anybody have any input on what I should do next?
Re: My engine likes too much timing, what to do? [Re: The Sphinx] #2089432
06/10/16 12:20 AM
06/10/16 12:20 AM
CT
GTX MATT Offline
GTX MATT  Offline
CT
Is this 93 pump? Could be fuel atomization issues or way too rich. Whats the AFR? Too cold of a plug? Polarity on the distributor/rotor phasing wrong?
Re: My engine likes too much timing, what to do? [Re: The Sphinx] #2089433
06/10/16 12:22 AM
06/10/16 12:22 AM
Central TEXAS!!!!
sr4440 Offline
sr4440  Offline
Central TEXAS!!!!
Have you verified that when timing tab and balancer read "0" that the piston is truly at TDC?
Joe
Without Data, you’re just another guy with an opinion.
Re: My engine likes too much timing, what to do? [Re: GTX MATT] #2089436
06/10/16 12:25 AM
06/10/16 12:25 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Could be any of the above... swap the wires at
the dist first and see if the timing drops
wave
Re: My engine likes too much timing, what to do? [Re: GTX MATT] #2089452
06/10/16 12:50 AM
06/10/16 12:50 AM
Champion City
Champion City
Yes 93 octane, plugs look good for fuel mixture, yes my plugs are too cold, as for the polarity it plug and play, GI proof cable.
Could too cold of a plug cause my problem?
Re: My engine likes too much timing, what to do? [Re: sr4440] #2089453
06/10/16 12:51 AM
06/10/16 12:51 AM
Champion City
Champion City
Joe
Did it, it is
Re: My engine likes too much timing, what to do? [Re: MR_P_BODY] #2089456
06/10/16 12:53 AM
06/10/16 12:53 AM
Champion City
Champion City
wave
Even though the cable is GI proof its worth a shot
Re: My engine likes too much timing, what to do? [Re: The Sphinx] #2089459
06/10/16 12:55 AM
06/10/16 12:55 AM
Its a TRAP!
DARTH V8Я Offline
Oh No!! I just had a moron attack!
DARTH V8Я  Offline
Its a TRAP!
41? Yikes.. how far back ya retard the cam lol.
When it takes more than a sweet mullet to prove you rule at the trailer park..
Re: My engine likes too much timing, what to do? [Re: The Sphinx] #2089478
06/10/16 01:22 AM
06/10/16 01:22 AM
MR_P_BODY Offline
MR_P_BODY  Offline
wave
There was a bunch of those cable made backwards... cut
them and try it worst case you you solder it with some
shrink tubing... one way it picks up on the leading edge
the other way it picks up on the trailing edge
EDIT
On the dyno my W-5 wanted 40* but that was at the
max.. your engine is still looking for more..either
the items above or the cam is retarted...you did go
off the second valve correct(intake)
wave
Re: My engine likes too much timing, what to do? [Re: The Sphinx] #2089511
06/10/16 07:21 AM
06/10/16 07:21 AM
Pa
Hot 340 Offline
Hot 340  Offline
Pa
My buddy had this happen to him once. He used one of those timing lights with the knob on the back. Looked legit with a regular light. His was off.
Re: My engine likes too much timing, what to do? [Re: MR_P_BODY] #2089520
06/10/16 09:25 AM
06/10/16 09:25 AM
Champion City
Champion City
wave
EDIT
wave
I degreed it off #1 intake, second lifter back. I think I can un-pin the cable and swap it
Re: My engine likes too much timing, what to do? [Re: Hot 340] #2089521
06/10/16 09:26 AM
06/10/16 09:26 AM
Champion City
Champion City
Interesting, sounds like my timing light. I'll try another.
Re: My engine likes too much timing, what to do? [Re: The Sphinx] #2089523
06/10/16 09:30 AM
06/10/16 09:30 AM
Shelby mi.
JAKE68 Offline
JAKE68  Offline
Shelby mi.
[quote=The Sphinx] I have a 360 with eddy out of the box heads, hughes 1.6 rockers, 10.5:1compression and a MP .557 cam, MSD digital 6 ignition with an msd pro billit distributor that is locked out, Holley hp750 with 80/82 jets, Eddy airgap intake. For some reason my car just wants more timing. At 36 it runs awful, 41 degrees its happier and I'm nervous about giving it more, but the car runs faster the more I give it. So far Ive ruled out the balancer, distributor,and ignition box as I have swapped them out with No change. I did degree the cam and everything came in spec with the cam card and left it straight up. Anybody have any input on what I should do next? [/q
Something is wrong if it runs bad with less timing if timing was retarded it would be just down on a little power not run bad. sounds like more timing is covering up a problem.
JAKES AUTOMOTIVE
Re: My engine likes too much timing, what to do? [Re: The Sphinx] #2089532
06/10/16 09:54 AM
06/10/16 09:54 AM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
A simple way to check the cable is with an ohm meter, no cutting involved.
Re: My engine likes too much timing, what to do? [Re: The Sphinx] #2089564
06/10/16 11:33 AM
06/10/16 11:33 AM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
Timing is just a number, if the motor is happy at 41 leave it. My eddy headed motor was 38 and my indy motor was 41. My W9 motor likes 36. Bretts engine master Indy headed motor made the most power at 42 on the dyno.
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: My engine likes too much timing, what to do? [Re: The Sphinx] #2089590
06/10/16 12:15 PM
06/10/16 12:15 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
Seen a lot of different small block combo's that like 40.
I pulled Eddie heads off a 416 flat tappet short block years ago that liked 34.
Put a W5 top end on that short block and it liked 40. Turn it back to 36 and it slowed down a whole tenth.
Later built a roller short block, put the W5 heads on that and it liked 32.
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
Re: My engine likes too much timing, what to do? [Re: 1967dartgt] #2089597
06/10/16 12:27 PM
06/10/16 12:27 PM
North, Alabama
D-50 Offline
D-50  Offline
North, Alabama
1967Dartgt which engine masters motor?
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
Re: My engine likes too much timing, what to do? [Re: The Sphinx] #2089617
06/10/16 01:25 PM
06/10/16 01:25 PM
Central TEXAS!!!!
sr4440 Offline
sr4440  Offline
Central TEXAS!!!!
well I reread your OP, I will bet you are checking your timing at Idle, check your timing at 5000 and see what it is. Some of the digital have bad cases of magnetic hysteresis. I had some digital 7 boxes that drop 1 degree per 1000.
I would really like to see a pic of the plugs.
Joe
Re: My engine likes too much timing, what to do? [Re: D-50] #2089668
06/10/16 03:04 PM
06/10/16 03:04 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
Yours!
Re: My engine likes too much timing, what to do? [Re: sr4440] #2089685
06/10/16 03:45 PM
06/10/16 03:45 PM
Champion City
Champion City
Joe
I check it at 3000. My fuel air mixture looks good, no noticable annealing line on the ground strap of the plug of the plug
Page 1 of 3 1 2 3
