stroker for 4.7 liter #2087826
06/07/16 05:14 PM
06/07/16 05:14 PM
FRANCE, Paris
Chal340 Offline OP
Chal340  Offline OP
FRANCE, Paris
A friend would like to put a stroker in his engine. He has a 2003 Dodge Ram with a 4.7 liter. Where can I find a stroker if there is? if no, are there aluminium heads for this engine?
70 Challenger, A66, 340 ci
Re: stroker for 4.7 liter [Re: Chal340] #2087830
06/07/16 05:21 PM
06/07/16 05:21 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
I am not aware of either being available for hte 4.7, assuming by aluminum heads you mean aftermarket because the stock head is aluminum. However, there are places that do offer performance stuff for the 4.7.
http://www.airram.com/custompage.php?page=18
Don't be the exception.
Re: stroker for 4.7 liter [Re: Chal340] #2087882
06/07/16 07:06 PM
06/07/16 07:06 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
Probably gonna have to go to smaller rod journals and offset grind the stock crank.
Factory heads are aluminum, they could be ported like other heads but I don't know of any aftermarket heads.
Re: stroker for 4.7 liter [Re: Chal340] #2087967
06/07/16 09:20 PM
06/07/16 09:20 PM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
The rod journal is only 2" on a 4.7 so you're looking at Honda journal size for off the shelf rods. Going from a 2" to an offset 1.88 journal only gains you .006" stroke does it not? With a .030 overbore that is 5 cubes. Not worth the bother IMHO.
Has anyone flowed a 4.7 head? That number would give you some idea of the engine's potential.
2 ways to get serious power out of a small package, spin the wee out of it or boost (or both...). OHC make the former a little easier but a 5000lb truck needs torque so my vote would be for boost.
Kevin
Re: stroker for 4.7 liter [Re: Chal340] #2087997
06/07/16 10:19 PM
06/07/16 10:19 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
My vote would be to find something else to hop up
Re: stroker for 4.7 liter [Re: Supercuda] #2088042
06/07/16 11:19 PM
06/07/16 11:19 PM
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
Where's the sport in that? laugh2
Kevin
Re: stroker for 4.7 liter [Re: Chal340] #2088084
06/08/16 12:12 AM
06/08/16 12:12 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Well, my wallet is too flat for that kind of sport.
Re: stroker for 4.7 liter [Re: Twostick] #2088219
06/08/16 10:20 AM
06/08/16 10:20 AM
Stinnett, Tx
rumblebee4232 Offline
Stinnett, Tx
I believe it would give you 0.24 if you can use the original surface on the outer edge..
Kevin
Re: stroker for 4.7 liter [Re: Chal340] #2088304
06/08/16 12:56 PM
06/08/16 12:56 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
Some of the Dakota guys have been able to drop in gen III hemis and run them on the stock computer.
- Stu Harmon
Re: stroker for 4.7 liter [Re: feets] #2088316
06/08/16 01:16 PM
06/08/16 01:16 PM
Ontario Canada
MattW Offline
MattW  Offline
Ontario Canada
Bingo!!!!
A lot less work swapping a 5.7 in them modifying a 4.7.
Plus more potential with the 5.7.
Matt
Re: stroker for 4.7 liter [Re: rumblebee4232] #2088367
06/08/16 02:25 PM
06/08/16 02:25 PM
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
Kevin
flame Yes it's .120 not .012. My math sucks.
I can never remember if you get 2x the offset for stroke increase or half.
.240" increase would be a worthwhile increase.
Kevin
Re: stroker for 4.7 liter [Re: Chal340] #2088400
06/08/16 03:30 PM
06/08/16 03:30 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
With a .120 longer stroke and .030 overbore it would be a 316 CID instead of 287 with a head that barely flows better than a 318 head it will run about like a 318 but a lot quicker reving although power and TQ should be similar, maybe a smidge more.
I know the 4.7 truck I am driving now has way less TQ than my old 318 truck, both 5 speeds and 3.55 geared 4x4.
Re: stroker for 4.7 liter [Re: Twostick] #2088408
06/08/16 03:37 PM
06/08/16 03:37 PM
dogdays Offline
dogdays  Offline
If offset grinding, then the Mitsubishi 1.850 rod journal size could be used.
All of you are wrong on the stroke increase. It is just slightly less than the difference in the rod journal sizes. So going from 2.000 to 1.88 is 0.112" But the grinding wheel has to contact the rod surface all the way around so you'd maybe end up with 0.105" stroke increase.
Using the 1.85" journal you could get maybe 0.135 stroke increase.
Using an example from the real world, the 440 crank with its 2.375" journals can be offset ground to 2.200" and stroke increases from 3.75 to about 3.91.
To the OP: This is an engine that has no real factory support for high performance use. It is well-known to have durability problems. There are no high performance heads for it, and the stroke increase I outlined above wouldn't be worth the trouble.
IF you must keep the engine because of your country's licensing rules then supercharging would be the best answer. Even 0.4 bar would increase performance quite a bit.
If there's any way to use a Generation III Hemi that would be the way to go. You'd probably double the apparent horsepower with a stock 5.7.
R.
Re: stroker for 4.7 liter [Re: dogdays] #2088484
06/08/16 06:02 PM
06/08/16 06:02 PM
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
R.
Your math is as bad as mine. laugh2
2 - 1.88 = .120
Kevin
Re: stroker for 4.7 liter [Re: Twostick] #2088710
06/08/16 11:37 PM
06/08/16 11:37 PM
Stinnett, Tx
Stinnett, Tx
2 - 1.88 = .120
Kevin
the you have to double the 0.120 because at the top of the stroke it is 0.120 higher in the cylinder and at the bottom of the stroke it is 0.120 lower in the cylinder or as someone above said the grinder has to contact the journal all the way around so lets call it 0.110 and double that for the full stroke increase so total increase would be 0.220
Re: stroker for 4.7 liter [Re: Chal340] #2088726
06/08/16 11:51 PM
06/08/16 11:51 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
That's a theoretical maximum increase in stroke by offset grinding the pin, it'll be less in reality, especially if you need to grind the crank an undersize. Figure .020" less as a rule of thumb. And you don't double it to calculate the stroke increase.
The math works out such that if you have a .120" smaller journal size you offset grind to then your stroke increase is... .120", less the .020' I mentioned, so figure .100" increase.
http://www.hotrod.com/how-to/engine/ccrp-9812-engine-boring-and-stroking-fundamentals/
Re: stroker for 4.7 liter [Re: Chal340] #2088855
06/09/16 03:02 AM
06/09/16 03:02 AM
Canada
WO23Coronet Offline
WO23Coronet  Offline
Canada
There's adapters you can get to put 4.6 intakes on 4.7's, including the supercharger set up from the Terminator engine, that's kind of cool
Re: stroker for 4.7 liter [Re: Chal340] #2089060
06/09/16 02:01 PM
06/09/16 02:01 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
I have a bad 4.7 in my shop and some 1.85 journal NASCAR rods, maybe I should try building one of these with the solid lifters that one place sells... there are tons of rigs on CL for sale with blown up 4.7s in em.
Re: stroker for 4.7 liter [Re: Supercuda] #2089067
06/09/16 02:16 PM
06/09/16 02:16 PM
Stinnett, Tx
Stinnett, Tx
You are incorrect.. Using simple numbers say starting with a 3.00" stroke which is 1.5 inches either side of the centerline of the crank, you offset grind 0.10 it adds 0.20 inches total to the stroke.. that is 0.10 inches at TDC from 1.5 to 1.6" on the compression side of the crankshaft centerline and 0.10 inches at BDC again from 1.5' to 1.6 inches on the bottom side of the stroke..
Using you method is physically impossible.. you can not add stroke to one side of the stroke and not add the same to the other side..
Re: stroker for 4.7 liter [Re: rumblebee4232] #2089097
06/09/16 03:02 PM
06/09/16 03:02 PM
dogdays Offline
dogdays  Offline
Rumblebee, you are forgetting ONE IMPORTANT THING:
Assuming you leave the outermost edge of the rod journal and grind all of the 0.120" off the inside, you have only moved the center of the rod journal out 0.060". Yes that's on both sides of the circle, but it's 2 X 0.060 and not 2 X 0.120.
I believe rod length of the 4.7 is 6.12. Deck height is 9.09.Stock stroke is 3.405 Piston compression height computes out to 1.26" Rods weigh 565 grams
See writeup here:
http://www.allpar.com/mopar/47.html
To the OP: Maybe an easier way to get more power would be to find a 2008 - 2013 290hp version, there were quite a few improvements according to the writeup.
It's an interesting question, thanks for asking it!
R.
