Re: overcharging nightmare help
[Re: NANKET]
#2085628
06/03/16 11:48 PM
06/03/16 11:48 PM
RapidRobert
pull the blue/green field wire connectors off of the alt field terminals and ohm the male terminals (the alt internal field circuit). then ohm each one to the alt case. visual on the brushes/brush holders for any (improper) continuity to alt case that you can see. pull the brushes/brush holders & visual for anything that dont look right such as something touching that should not be touching & when replacing them they wear at an angle so restore that clocking. You might also sub in another alt for a quick test (I have a dozen I am tripping over) or take it in to your parts house & have them spin it. borrow another good/fully charged battery & sub it in for a quick test. pull all blue/green field wires/connectors off & with jumper wires with small alligator clips (fab em up they will come in handy in the future) jump 12V to one field terminal and 12V to the top nub terminal in the reg triangle with it facing up like a pyramid as some are not and run a jumper from the side reg nub terminal to the other alt field terminal (no voltage,just connect those 2 to each other, you are duplicating the green wire alt to reg field circuit) & run it at a fast idle & see what you get for voltage at the alt "batt" stud terminal and at the battery posts. Only do each running test for ~4 seconds just long enough to read your meter as this high of pressure is extremely damaging to the system & have the lights/radio etc OFF. I'd do the battery first (easy to do) then the alt then the jumpers. Holler back when you can. WAG-the alt (part time loose or dead shorted connection). EDIT confirm there is no draw with everything shut off (pull a batt cable off of its post at midnight & should be no spark (assuming no clock or LED indicator light on a stereo face etc that is on all the time) & this is with eng OFF, all lights everything off (no spark=no draw)
[Re: JohnRR]
#2086031
06/04/16 08:28 PM
06/04/16 08:28 PM
KOS
Did you look at the main connection thru the bulkhead ? YES one of the first on the checklist...........
[Re: KOS]
#2086064
06/04/16 09:50 PM
06/04/16 09:50 PM
Posts: 3,911 Oregon
hooziewhatsit
Like Andy mentioned, the first test I would do is to measure the voltage between the battery positive terminal, and the blue wire at the alternator while it's running.
That is, put your positive lead on the battery +, and your negative lead on the blue wire. Try to find a safe way to probe the blue wire at the alternator.
Ideally, this will be 0v or close to it. If it's any higher, the battery will overcharge by that amount.
If it is above 0v (I'm guessing you'll see 2-2.5v) you have a voltage drop through the harness before it gets to the blue wire.
[Re: hooziewhatsit]
#2086082
06/04/16 10:35 PM
06/04/16 10:35 PM
KOS
If it is above 0v (I'm guessing you'll see 2-2.5v) you have a voltage drop through the harness before it gets to the blue wire. OK ill try that tm............if it does have a drop how do i go about finding it??
[Re: Ronnman]
#2086083
06/04/16 10:36 PM
06/04/16 10:36 PM
KOS
Do you have GOOD ground straps (wires) from the engine to the vehicle body? Ron YES
[Re: KOS]
#2086088
06/04/16 10:51 PM
06/04/16 10:51 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
voltage drop measurements.
Two ways to do it.
Method one.
Measure voltage from one end of wire to ground, write down reading. Measure voltage from other end of wire to ground, write down reading. The difference, if any, is the voltage drop.
Method two.
Measure voltage from one end of wire to other end of wire. The reading you get is the voltage drop across that wire.
For example, with the key in run you can measure from the battery post + to the switched 12V wire at the VR or alternator, the reading on the meter will show how much drop there is in the entire circuit, connections, wiring, switches, etc. You can measure back from one end to the other to figure the section/part with the issue.
Remember, the closer to zero you get for a voltage drop measurement the better, .2V or so is probably ok, more than that and I'd be cleaning things up.
[Re: KOS]
#2086163
06/05/16 01:32 AM
06/05/16 01:32 AM
Posts: 3,911 Oregon
hooziewhatsit
supercuda covered it pretty well. The sense line (blue wire) goes from the battery, through the bulkhead (twice), through the ignition switch plug (twice), through the ignition switch itself, and maybe another connection or two along the way. Any or all of those can be less than ideal. My solution was to mount a relay under the hood, have the old blue wire trigger it, and run a new wire through the relay to the alternator/ignition subsystem. No more overcharging for me. Edit: if you do find a large voltage drop, you can temporarily install a jumper from the battery + to the blue wire at the alternator to bypass all of the voltage drops. That should immediately bring your charging voltage back down. Note that it will no longer turn off with the key while this jumper is in place ![laugh2 laugh2](/ubbthreads/images/graemlins/custom/laugh2.gif)
[Re: KOS]
#2086169
06/05/16 01:49 AM
06/05/16 01:49 AM
Supercuda
About to go away
About to go away
up yours
One other thing you have to remember.
All electrical circuit require a supply and a return.
Both the supply and the return can have voltage drop issues.
In cars the return isn't as obvious as the supply, because generally the return is the body, or the block.
You must have a good ground to both the body and the block from the battery and the alternator. You can use the voltage drop method to test that connection as well.
[Re: Supercuda]
#2086210
06/05/16 07:27 AM
06/05/16 07:27 AM
RapidRobert
if the hard components (batt/reg/alt) are good then it has to be a voltage drop issue on the supply side or the ground side. Now if there was an unwanted draw (& I'm thinking not from your clue) that ran the batt down then it would charge high or even peg (full field) till it replenished the battery & you'd see that on immediate startup then it'd return to normal after awhile. the puzzler (the clue) to me is it worked for awhile then the voltage started to creep back up as something dont make sense on that symptom (the slowly creeping upward). Stay on it we need to know. I'm still thinking batt or alt or loose/part time connection somewhere but I am speculating
[Re: KOS]
#2086244
06/05/16 10:19 AM
06/05/16 10:19 AM
Andrewh
what was the power to the relay coming from? it says the battery in your original post.
What type of connector and wiring did you use? intermittent connections cause this too.
What type of ground did you wire to the vr? where is it grounded to?
Did you check your wiring to the alt? it also could be bad/poor connection. check your voltage drop there. Both lines to the fields.
