Re: Kevlar/CF laminating an OEM Alum manual bellhousing, Crazy?
[Re: slantzilla]
#2086466
06/05/16 04:22 PM
06/05/16 04:22 PM
Posts: 22,783 Bitopia
jcc
Bitopia
Another option would be to get a copy of the adapter plate Mark Goodman used to make and then find a used small block shield. That also allows you to use the 130 tooth flywheel, but puts the starter in the low position.
Lou (Dart 270) on the Slant board has the one I had made. I think he would loan it out so you could copy it. Wish you hadn't suggested that. That's really the right direction I should be going, solves a lot of other issues down the road.
[Re: jcc]
#2086536
06/05/16 06:10 PM
06/05/16 06:10 PM
Posts: 4,213 New York
polyspheric
New York
Have you considered armoring the tunnel and floor (inside or out) instead of the BH? If the pieces can't reach you who cares where they go.
Boffin Emeritus
[Re: jcc]
#2086893
06/06/16 10:14 AM
06/06/16 10:14 AM
Posts: 1,213 Minn
SportF
Minn
I have said this many times before, if you had seen what happened, and what was left of a carbon fiber shield from a tranny that blew up in Eddyville in '13, you wouldn't even think of anything fiber. He almost lost a foot! That shield did NOTHING. Let me repeat that, it did nothing.
The way every body tries to fit a trans blanket, they don't work either. The trick is to put it over the trans, and wrap the ends around the torsion bars. You may need one simple brace to keep it off the headers on the driver side.
Think about this, at the track, I bet flywheels have killed more people than you'd would ever care to hear about. And some of those were in the stands.
Best of luck to you.
[Re: Scott440]
#2086941
06/06/16 11:48 AM
06/06/16 11:48 AM
jcc
Bitopia
Bullet proof vests don't use just a handful of layers. I don't know how much your supplies would cost but 30+ layers of kevlar plus epoxy around a bell means material costs beyond $100 for me. So I think the trans blanket suggestion was a good one, unless you really want to get the experience.
If you worked for an exotic car mfr (front engine/trans) and they wanted something more classy than a blanket I think this is a really good idea. You could even take it to the firing range and put a small caliber bullet through it as a simulation. I wouldn't bother with the carbon fiber. I hoping I can size/pre cut my fabric to prevent as much waste as possible. You are correct, enough layers to do the job will certaintly be more then a handfull. Your comment on bypassing the CF instills me to ask your reasoning. My thinking, the OEM housing is over 1/4"+- alum, my first layers would be CF, as increasing the overall strength of the alum housing from failure, would be first goal in the event of an explosion, CF is close to stiffness of alum, plus it would likely slightly dampen the alum, and to a lessor degree, maybe protect the following added layers of kelvar, from any arising sharp edges of cracked/broken alum protruding outward. The problem with that scenario is, most of the CF I has seen that failed, has its own sharp edges. My understanding of Kelvar, besides its general robust strength, is its resistant to tearing/cutting, but it can be cut, so sharp edges are to be avoided. Then I was thinking another outside final layer again of CF, since the outside layer would be the first to fail from stress, in an explosion. I also pondered adding a thin form-able layer inside of a SS liner. I'm also thinking I'm talking myself into calling Summit. But that wouldn't be any fun. PS "SportF", this ever saw the drag strip or higher powers, this idea would not be considered, and I cannot see it can do any harm, other then my wallet, nor am I trying to mislead others to follow this path. "Poly", reinforcing the tunnel, would not protect nearby fuel lines, brake lines, tires, bystandersrs, etc
[Re: jcc]
#2086964
06/06/16 12:17 PM
06/06/16 12:17 PM
Posts: 7,506 Az
Crizila
Az
If you worked for an exotic car mfr (front engine/trans) and they wanted something more classy than a blanket I think this is a really good idea. You could even take it to the firing range and put a small caliber bullet through it as a simulation. I wouldn't bother with the carbon fiber. I hoping I can size/pre cut my fabric to prevent as much waste as possible. You are correct, enough layers to do the job will certaintly be more then a handfull. Your comment on bypassing the CF instills me to ask your reasoning. My thinking, the OEM housing is over 1/4"+- alum, my first layers would be CF, as increasing the overall strength of the alum housing from failure, would be first goal in the event of an explosion, CF is close to stiffness of alum, plus it would likely slightly dampen the alum, and to a lessor degree, maybe protect the following added layers of kelvar, from any arising sharp edges of cracked/broken alum protruding outward. The problem with that scenario is, most of the CF I has seen that failed, has its own sharp edges. My understanding of Kelvar, besides its general robust strength, is its resistant to tearing/cutting, but it can be cut, so sharp edges are to be avoided. Then I was thinking another outside final layer again of CF, since the outside layer would be the first to fail from stress, in an explosion. I also pondered adding a thin form-able layer inside of a SS liner. I'm also thinking I'm talking myself into calling Summit. But that wouldn't be any fun. PS "SportF", this ever saw the drag strip or higher powers, this idea would not be considered, and I cannot see it can do any harm, other then my wallet, nor am I trying to mislead others to follow this path. "Poly", reinforcing the tunnel, would not protect nearby fuel lines, brake lines, tires, bystandersrs, etc I can attest to the last line above. I do like "sport F's" suggestion of attaching a blanket to the torsion bars. Will look at doing that. Might help with my existing blanket / trans linkage clearance issues that I have.
Fastest 300
[Re: SportF]
#2086974
06/06/16 12:36 PM
06/06/16 12:36 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Best of luck to you. You dont want a blanket tight... you want them to stretch and absorb the energy... the C/F shields that are SFI approved are there for a reason... the trans itself helps slow the energy then the shield helps it even more.. and they arent thick... you want things to stretch to eat up the energy EDIT On a 727 if you break the sprag anything over 6200 rpm will blow the drum.... based on the 2.2 times faster than the engine rpm and based on testing that 13,000 rpm will rip it apart.. and we know MOST people turn more than 6200 rpm.... but if you dont do stupid stuff you wont blow the drum.. NEVER get out of it and get back on it if the sprag is broke.. that extra distance will roll over the ramps... if you get out of it SHIFT... low is when the sprag is engaged granted in this post its a manual trans
[Re: Scott440]
#2086988
06/06/16 01:01 PM
06/06/16 01:01 PM
MR_P_BODY
If you worked for an exotic car mfr (front engine/trans) and they wanted something more classy than a blanket I think this is a really good idea. You could even take it to the firing range and put a small caliber bullet through it as a simulation. I wouldn't bother with the carbon fiber. The vest that SAVED my life was a solid 3/4"carbon fiber... the chopper crews wore them(most of the guys sat on them... they were heavy and had just a front and back with velcro straps to hold it on... I was hit in the chest with part of a B-40 rocket... it blew me back about 15' and I hit a guy behind me and I broke his nose.. a couple other parts got me.. one in the shoulder and one in the side... but I walked away and still kept fighting till I could be choppered out.. then the chopper was shot down(about 60' up) but we all got out before they hit it with a mortar round...C/F is STRONG stuff.... if I would have had a normal vest on(the army style) I wouldnt be here
[Re: MR_P_BODY]
#2096121
06/22/16 10:51 AM
06/22/16 10:51 AM
jcc
Bitopia
I'm ending the project. I'm chickening out. After prepping the the used alum 50? year old housing, on close inspection there seems to be an awful lot of minute casting? cracks. When I started I dismissed them as casting lines, but after grinding away some threaded unneeded bosses, and discovering numerous porosity inclusions, I looked closer at the casting lines, my suspicion, they are from thermal cooling shock when cast, or something, they don't look to be always in use stress related, although some do. Bottom line, not worth trying to make a safe silk purse out of a pigs ear. I'll get the QT bellhousing, save my efforts for something else. Below are a couple of pics on my added lower cover retaining holes. I also under stand there are few if any good methods to locate cracks in alum. Is this a rarity what I am seeing, or common?
