28x9" slick air psi? #2086038
06/04/16 08:38 PM
06/04/16 08:38 PM
jax. fla.
70Dustmite440 Offline OP
jax. fla.
Wondering how far we're off running about 14psi in a friends 28x9" slick? if it makes any difference we're at about 2900lb race weight (i think), footbrake car, stock suspension, has boost n stuff. What say ye?
8sec. street car, been there done that. Quitting when your ahead isn't the same as quitting.
[img]https://scontent-atl.xx.fbcdn.net/hphoto...amp;oe=55DB3E4C[/img]
https://www.facebook.com/eric.norton.1048
R.I.P.UN.
Re: 28x9" slick air psi? [Re: 70Dustmite440] #2086067
06/04/16 09:59 PM
06/04/16 09:59 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
My MT 9x28 liked 12.5 on slippery tracks. 14 would be better for et as long as it hooked. So if your hooking keep it there.
Re: 28x9" slick air psi? [Re: 70Dustmite440] #2086141
06/05/16 12:49 AM
06/05/16 12:49 AM
Massillon, Ohio
cudatom Offline
cudatom  Offline
Massillon, Ohio
I'm sure mine isn't nearly as fast but it likes 16lbs. These are Hoosier 28x9. Weight is at least 3800.
Ok
Re: 28x9" slick air psi? [Re: 70Dustmite440] #2086251
06/05/16 10:42 AM
06/05/16 10:42 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Last year testing my friends 64 Polara with a Go=Pro video reveled the tire was being crushed. After shock adjustments we continued to add air. The car weighs 3775 and now runs 17psi on 9x28.5 went from 10.90's to 10.60's
Doug
Re: 28x9" slick air psi? [Re: 70Dustmite440] #2086262
06/05/16 11:09 AM
06/05/16 11:09 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Go to your local scales.. weigh the whole car then roll
the fronts off and weigh it again so you have the front
and rear weights... the rear weight will help a lot on
figuring many different things.. how high is the boost
at the line...make sure the front has the travel and has
good adjustable shocks... what T-bars are in it.. on the
scales.. make sure you see it at zero before pulling on
wave
Re: 28x9" slick air psi? [Re: dvw] #2086339
06/05/16 12:59 PM
06/05/16 12:59 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Doug
My new pic from the last outing shows the tire gettin killed at 12 lbs so this is a good idea about adding pressure that I need to try next time out............ thumbs
Re: 28x9" slick air psi? [Re: 70Dustmite440] #2086342
06/05/16 01:00 PM
06/05/16 01:00 PM
jax. fla.
jax. fla.
I used to know how to post up pics, anyways not my car i've just been driving it. seems like he says its close to 50/50 weight. motor is moved back some. boost at the line isnt much, comes on quick tho. pro-charger system and blow thu carb. when it only made about 9psi boost it would pull mid to upper 1.30's 60. now more boost 60's are mid/low 1.40's i think iirc ... something like that wink
R.I.P.UN.
