Re: Recommendation: lock up or non-lock up? [Re: 2ndopp] #2087479
06/07/16 12:42 AM
06/07/16 12:42 AM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
mine is 4" aluminum.
Re: Recommendation: lock up or non-lock up? [Re: 2ndopp] #2088225
06/08/16 10:31 AM
06/08/16 10:31 AM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
Originally Posted By 2ndopp
Thanks for all the great advice. Any recommendations if I upgrade the drive shaft?
For others doing similar projects, here are two drive shaft critical rpm calculators:
http://www2.dana.com/expert/wc.dll?hvtss~decrits~warn1
http://www.wallaceracing.com/driveshaftspeed.htm
I used Strange for a chromemoly driveshaft, however I later realized I was exceeding its critical speed on the top end. I am going to have to go with a carbon fiber unit to have a margin of safety. I'm running 3.91's with 28" tall Nittos.
Re: Recommendation: lock up or non-lock up? [Re: 2ndopp] #2090013
06/11/16 04:35 AM
06/11/16 04:35 AM
AZ
2
2ndopp Offline OP
2ndopp  Offline OP
AZ
In another post you mentioned US Cartool makes a kit to swap the transmission in, do you have a link?
I might not need the 3,300 torque converter yet. I still have a stock 360 in the car and my planned engine swap is a year away. But I will be putting 500+ hp when the time comes.
I'll definitely need an upgraded driveshaft.
Any other parts I need to consider?
Re: Recommendation: lock up or non-lock up? [Re: 2ndopp] #2090077
06/11/16 12:30 PM
06/11/16 12:30 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
I highly recommend installing the entire chassis stiffening kit from US Cartool. It's also a good idea to weld up your K-member and weld up the torsion bar crossmember solidly a crossed the floor. I would also reweld your shock towers to the inner fenderwells to strengthen them too. Give John at US Cartool a call and let them know what you are doing.
