Re: Race Trans 904 problem?
[Re: sixpacksteve]
#2088128
06/08/16 01:23 AM
06/08/16 01:23 AM
Posts: 11,691 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Lucky he didn't loose the car. Not a bad idea to neutral it, but you have to use the correct valve body and shifter with the clean neutral behind high gear.
[Re: CMcAllister]
#2089364
06/09/16 10:35 PM
06/09/16 10:35 PM
Posts: 1,468 N.Y.
sixpacksteve
N.Y.
he was on his way to neutral!
Hell Hath No Fury Like Mine
[Re: sixpacksteve]
#2089369
06/09/16 10:41 PM
06/09/16 10:41 PM
Posts: 20,197 PA.
pittsburghracer
"Little"John
"Little"John
PA.
I could never understand why guys want to shift their cars into neutral after a pass.
[Re: pittsburghracer]
#2089375
06/09/16 10:51 PM
06/09/16 10:51 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I could never understand why guys want to shift their cars into neutral after a pass. Mainly on alum rods.. get the rpm down to save rod life and if you are letting the rpm pull the car down your just keeping the rpm up
#2089398
06/09/16 11:33 PM
06/09/16 11:33 PM
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
I could never understand why guys want to shift their cars into neutral after a pass. I did that many years ago. Hurst Pro Stick. If you pulled the release just right, it would glide right to neutral. Never missed. Probably lucky I didn't tear up the car.
