steering column wire terminal ?? #2082223
05/29/16 11:30 AM
05/29/16 11:30 AM
moparx Offline OP
moparx  Offline OP
what are the round column connectors called ? are they molex connectors ? and there are two sizes used. a large one for the start, run, accessory plug and a smaller one that is used for the turn signal switch. what size are they ? car in question is a '72 duster. i'm guessing these were used on many years and models. lastly, where is a good place to get these ? TIA.
beer
Re: steering column wire terminal ?? [Re: moparx] #2082237
05/29/16 11:52 AM
05/29/16 11:52 AM
Philadelphia PA
Pynzo Offline
Drugs are bad
Pynzo  Offline
Drugs are bad
Philadelphia PA
http://www.alliedelec.com/molex-incorporated-63824-0200/70090740/
The .093 pins are the small ones, .125 for the large pins. I got mine and the tool from the above link.
Re: steering column wire terminal ?? [Re: Pynzo] #2082692
05/30/16 09:15 AM
05/30/16 09:15 AM
moparx Offline OP
moparx  Offline OP
that will work. up thank you !
beer
