Re: 440 running weird
[Re: 69x]
#2081782
05/28/16 12:10 PM
05/28/16 12:10 PM
Posts: 4,806 Moved to N.E. Tennessee
GomangoCuda
Did you take any plug wires off when you changed motor mounts? You might have switched a couple of them.
[Re: GomangoCuda]
#2081784
05/28/16 12:20 PM
05/28/16 12:20 PM
69x
Did you take any plug wires off when you changed motor mounts? You might have switched a couple of them. I did not do the work myself, I will have to ask him next week if he took any off, but would think with the lengths being close he did not mess that up. I will check it out when I am off work myself later on.
[Re: 69x]
#2081814
05/28/16 01:07 PM
05/28/16 01:07 PM
RapidRobert
You might plumb a gas can in the eng compartment to the pump inlet & see how it acts with fresh gas. I would check the plugs and possibly opening up the carb top for a visual. Holler how it turns out
[Re: 69x]
#2088369
06/08/16 02:25 PM
06/08/16 02:25 PM
RapidRobert
the choke was messed up, it was stuck so the car was running very rich. I never woulda guessed. Glad you got it squared away
