Page 1 of 5 1 2 3 4 5
Spool, truetrac, clutch sure grip or other for street/strip? #2080259
05/25/16 09:11 PM
05/25/16 09:11 PM
Wichita
GY3 Offline OP
GY3  Offline OP
Wichita
I have a new Auburn unit in the car (complete 3rd member from Manciniracing) that's already starting to make noises going around corners. Less than 2k miles. down
It's in an 8 3/4 with 3.55 gears and I'm pushing 600 horsepower with ET Street Pro's.
I'm not a fan of the Detroit locker because of the noises it makes in a friend's 9 inch.
I've thought about a spool but not excited about corners on the street with one.
Is the truetrac okay for this level of horsepower and sticky tires?
I've started gathering Dana 60 parts and may just upgrade the whole rear. hammer weld
Re: Spool, truetrac, clutch sure grip or other for street/strip? [Re: GY3] #2080266
05/25/16 09:29 PM
05/25/16 09:29 PM
Washington
madscientist Offline
Washington
You want it all and the cake too? You can't have it. They make lockers that aren't as noises around corners.
You need a locker or a spool.
Re: Spool, truetrac, clutch sure grip or other for street/strip? [Re: GY3] #2080275
05/25/16 09:44 PM
05/25/16 09:44 PM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
I have a S60 with locker , don't even know its there
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
Re: Spool, truetrac, clutch sure grip or other for street/strip? [Re: GY3] #2080302
05/25/16 10:22 PM
05/25/16 10:22 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Love my spool for many years..........
Re: Spool, truetrac, clutch sure grip or other for street/strip? [Re: GY3] #2080324
05/25/16 10:57 PM
05/25/16 10:57 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
No Eaton true trac in an 83/4 they are JUNK !! the axle side gears move all around & dont support the axle end & makes all kinds of noise when slowing down. I have so much time & money in this crappy 8 3/4 NEVER AGAIN,,, Dana 60 is the only way to go.
check this link link to true junk
Re: Spool, truetrac, clutch sure grip or other for street/strip? [Re: GY3] #2080327
05/25/16 11:04 PM
05/25/16 11:04 PM
New Brunswick, Canada
TrxR Offline
TrxR  Offline
What about some sort of air locker like that use for offroad setups. ??
Re: Spool, truetrac, clutch sure grip or other for street/strip? [Re: GY3] #2080340
05/25/16 11:14 PM
05/25/16 11:14 PM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
I have a spool, I was really worried about it before I put it in. But once I got it in the car it's really zero issue.
3.55 gear with 275 drag radials.
This drive around video shows the car turning around a tight corner (7min mark). No binding , no sqeeling, no problems.
https://youtu.be/vqJoG_2wdMQ
Just respect the car in the corners before you're on the throttle hard and you won't even notice.
Re: Spool, truetrac, clutch sure grip or other for street/strip? [Re: dizuster] #2080350
05/25/16 11:23 PM
05/25/16 11:23 PM
fullmetaljacket Offline
Keep an eye when in wet weather conditions with a spool. Get good axles and bearings along with good seals.
Also, the best man for the job with which ever way you go is no other than Dr. Diff.
Re: Spool, truetrac, clutch sure grip or other for street/strip? [Re: GY3] #2080390
05/25/16 11:59 PM
05/25/16 11:59 PM
North, Alabama
D-50 Offline
D-50  Offline
North, Alabama
I am running a borrowed 9 in. center section since I broke mine and it has 4.56 gears with welded spider gears (Poor mans spool). It works great and does not make any noise when street driving.
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
Re: Spool, truetrac, clutch sure grip or other for street/strip? [Re: D-50] #2080447
05/26/16 01:21 AM
05/26/16 01:21 AM
Wichita
GY3 Offline OP
GY3  Offline OP
Wichita
I have 3.54 Dana gears, housing ends to weld on in place of the full floaters and a truck housing. Looks like I need to ring Dr. Diff and get axles, bearings and a spool...
Re: Spool, truetrac, clutch sure grip or other for street/strip? [Re: GY3] #2080499
05/26/16 07:00 AM
05/26/16 07:00 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I have been running Detroit Locker for over 5 years and I love it. Most of the time I dont even know its in there. Ron
Re: Spool, truetrac, clutch sure grip or other for street/strip? [Re: GY3] #2080505
05/26/16 07:19 AM
05/26/16 07:19 AM
aotearoa
rebel Offline
rebel  Offline
aotearoa
Another Detroit here, can't say I've heard it making much noise on corners, it's way more friendly than the spool I had in it before.
Re: Spool, truetrac, clutch sure grip or other for street/strip? [Re: GY3] #2080510
05/26/16 08:03 AM
05/26/16 08:03 AM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
Spool here, no issues in the six years I've had it.
Re: Spool, truetrac, clutch sure grip or other for street/strip? [Re: GY3] #2080520
05/26/16 09:12 AM
05/26/16 09:12 AM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
With my old 8.75, the Auburn sg didn't hold up; the clutch-type sg was the better option.
When I ordered my Strange S-60 from Doctor Diff, we discussed both the Detroit locker and Strange's S-Trac. I ended up going with the S-Trac. Strange has a video on YouTube that goes into the details of the S-Trac that I found helpful, too.
Re: Spool, truetrac, clutch sure grip or other for street/strip? [Re: rebel] #2080521
05/26/16 09:15 AM
05/26/16 09:15 AM
Nashville, Tennessee
Tempest Offline
Tempest  Offline
Ditto on this. The key to the Locker is knowing what RPM to shift during street driving, turns etc. Once you find what it likes, you wont notice it.
Re: Spool, truetrac, clutch sure grip or other for street/strip? [Re: D-50] #2080529
05/26/16 09:55 AM
05/26/16 09:55 AM
moparx Offline
moparx  Offline
a "lincoln locker". grin
beer
Re: Spool, truetrac, clutch sure grip or other for street/strip? [Re: GY3] #2080538
05/26/16 10:26 AM
05/26/16 10:26 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
I have had a spool in my car for a long time. I had an auburn unit at one time that didn't last long at all so the spool was the next most reliable choice when I moved to 35 spline axles. My Jeep has a locker in it and while its better than a spool it is still a spool anytime your under throttle. It still chirps and barks the tires around corners and it can swap ends on you in the rain if your not careful when it goes from "open" to locked around a corner. The spool is really only annoying in parking lots and spaces that require tight turning, out on the road its a non issue.
68 Barracuda Formula S 340
Re: Spool, truetrac, clutch sure grip or other for street/strip? [Re: GY3] #2080541
05/26/16 10:32 AM
05/26/16 10:32 AM
an8sec70cuda Offline
I've had a spool in my cuda for about 15 years, street and strip, no problems ever. Dry pavement, wet pavemet, doesn't matter. The issues some people blame on a spool ends up being from the tires they were running.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Spool, truetrac, clutch sure grip or other for street/strip? [Re: GY3] #2080614
05/26/16 12:17 PM
05/26/16 12:17 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Auburn type units are garbage, but you know that wink.
A true trac COULD hold up to that power but you need to disassemble it when you get it and make sure it's put together properly, the one I put in a friends 8.8 was not and ate itself up in less than 15k miles with maybe 100 passes.
He ended up going with a Yukon Grizzly locker that I changed the springs to lighter ones to make it more street friendly. The last time I was in it you could barely hear it making the clicking that it does when going around a corner.
He isn't making the HP you are, '12 V6 mustang with a 50HP shot that runs in a 12.50 index class with slicks and a manual trans.
Re: Spool, truetrac, clutch sure grip or other for street/strip? [Re: JohnRR] #2080679
05/26/16 02:26 PM
05/26/16 02:26 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
"Auburn type units are garbage, but you know that"
I unfortunately have come to that conclusion, AFTER I bought a new Auburn, my question, is there any low enough hp application that an Auburn will survive, like a healthy slant six?
