Spool, truetrac, clutch sure grip or other for street/strip?
#2080259
05/25/16 09:11 PM
05/25/16 09:11 PM
Posts: 4,689 Wichita
GY3
Wichita
I have a new Auburn unit in the car (complete 3rd member from Manciniracing) that's already starting to make noises going around corners. Less than 2k miles. It's in an 8 3/4 with 3.55 gears and I'm pushing 600 horsepower with ET Street Pro's. I'm not a fan of the Detroit locker because of the noises it makes in a friend's 9 inch. I've thought about a spool but not excited about corners on the street with one. Is the truetrac okay for this level of horsepower and sticky tires? I've started gathering Dana 60 parts and may just upgrade the whole rear.
Re: Spool, truetrac, clutch sure grip or other for street/strip?
[Re: GY3]
#2080266
05/25/16 09:29 PM
05/25/16 09:29 PM
Posts: 4,457 Washington
madscientist
Washington
You want it all and the cake too? You can't have it. They make lockers that aren't as noises around corners.
You need a locker or a spool.
[Re: GY3]
#2080275
05/25/16 09:44 PM
05/25/16 09:44 PM
Posts: 2,467 Sydney,Australia
tex013
Sydney,Australia
I have a S60 with locker , don't even know its there
Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
[Re: GY3]
#2080302
05/25/16 10:22 PM
05/25/16 10:22 PM
Thumperdart
State of confusion
Love my spool for many years..........
[Re: GY3]
#2080324
05/25/16 10:57 PM
05/25/16 10:57 PM
Posts: 2,865 Pattison Texas
CSK
Pattison Texas
No Eaton true trac in an 83/4 they are JUNK !! the axle side gears move all around & dont support the axle end & makes all kinds of noise when slowing down. I have so much time & money in this crappy 8 3/4 NEVER AGAIN,,, Dana 60 is the only way to go. check this link link to true junk
[Re: GY3]
#2080340
05/25/16 11:14 PM
05/25/16 11:14 PM
Posts: 3,635 Oakland, MI
dizuster
Oakland, MI
I have a spool, I was really worried about it before I put it in. But once I got it in the car it's really zero issue. 3.55 gear with 275 drag radials. This drive around video shows the car turning around a tight corner (7min mark). No binding , no sqeeling, no problems. https://youtu.be/vqJoG_2wdMQJust respect the car in the corners before you're on the throttle hard and you won't even notice.
[Re: GY3]
#2080390
05/25/16 11:59 PM
05/25/16 11:59 PM
Posts: 1,267 North, Alabama
D-50
North, Alabama
I am running a borrowed 9 in. center section since I broke mine and it has 4.56 gears with welded spider gears (Poor mans spool). It works great and does not make any noise when street driving.
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
[Re: GY3]
#2080499
05/26/16 07:00 AM
05/26/16 07:00 AM
Posts: 27,421 Balt. Md
383man
Balt. Md
I have been running Detroit Locker for over 5 years and I love it. Most of the time I dont even know its in there. Ron
[Re: rebel]
#2080521
05/26/16 09:15 AM
05/26/16 09:15 AM
Posts: 595 Nashville, Tennessee
Tempest
Another Detroit here, can't say I've heard it making much noise on corners, it's way more friendly than the spool I had in it before. Ditto on this. The key to the Locker is knowing what RPM to shift during street driving, turns etc. Once you find what it likes, you wont notice it.
[Re: GY3]
#2080538
05/26/16 10:26 AM
05/26/16 10:26 AM
Posts: 8,028 Tulsa OK
Bad340fish
Tulsa OK
I have had a spool in my car for a long time. I had an auburn unit at one time that didn't last long at all so the spool was the next most reliable choice when I moved to 35 spline axles. My Jeep has a locker in it and while its better than a spool it is still a spool anytime your under throttle. It still chirps and barks the tires around corners and it can swap ends on you in the rain if your not careful when it goes from "open" to locked around a corner. The spool is really only annoying in parking lots and spaces that require tight turning, out on the road its a non issue.
68 Barracuda Formula S 340
[Re: GY3]
#2080541
05/26/16 10:32 AM
05/26/16 10:32 AM
Posts: 13,375 Marion, South Carolina [><]
an8sec70cuda
I've had a spool in my cuda for about 15 years, street and strip, no problems ever. Dry pavement, wet pavemet, doesn't matter. The issues some people blame on a spool ends up being from the tires they were running.
[Re: GY3]
#2080614
05/26/16 12:17 PM
05/26/16 12:17 PM
Posts: 75,060 U.S.S.A.
JohnRR
U.S.S.A.
Auburn type units are garbage, but you know that . A true trac COULD hold up to that power but you need to disassemble it when you get it and make sure it's put together properly, the one I put in a friends 8.8 was not and ate itself up in less than 15k miles with maybe 100 passes. He ended up going with a Yukon Grizzly locker that I changed the springs to lighter ones to make it more street friendly. The last time I was in it you could barely hear it making the clicking that it does when going around a corner. He isn't making the HP you are, '12 V6 mustang with a 50HP shot that runs in a 12.50 index class with slicks and a manual trans.
[Re: JohnRR]
#2080679
05/26/16 02:26 PM
05/26/16 02:26 PM
Posts: 22,696 Bitopia
jcc
Bitopia
"Auburn type units are garbage, but you know that"
I unfortunately have come to that conclusion, AFTER I bought a new Auburn, my question, is there any low enough hp application that an Auburn will survive, like a healthy slant six?
