Re: How fast will it run?
[Re: mechanic190]
#2072755
05/13/16 05:24 PM
05/13/16 05:24 PM
Posts: 14,515 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
Hopefully you upgraded the valve springs to go along with that cam.
With a completely untested combo, the first outing could go a few different ways. And a lot of the performance potential of any given combination often comes down the skill level of the one wrenching on it.
Based on that, I think it should run somewhere between 14.50 and 15.50.
[Re: mechanic190]
#2072854
05/13/16 08:08 PM
05/13/16 08:08 PM
Posts: 1,942 Metro Detroit
OUTLAWD
Metro Detroit
I had a similar combo in my Dart ages ago. 3.23's but with a 26" tire.
Ran 15.4 with cast manifolds, RV cam, 4bbl iron intake and a 600 holley. Ran 14.0 with headers, LD340, and summit .441 cam
Later ran high 12's with home ported heads, XE268, and higher compression. Ran 12.16 @ 116 with a .047 pill in a plate
I would hold off on gears if you actually plan to drive it, and suggest the following, not necessarily in order:
intake head work N2O/Ebay turbo
As for now...9.80 in the 1/8
Faster, Faster until the thrill of speed overcomes the fear of death...
71 Swinger - slowly collecting dust/parts 66 Belv. II - just a streetcar 88 Mustang - turbo LS beater
[Re: mechanic190]
#2072929
05/13/16 10:14 PM
05/13/16 10:14 PM
Posts: 4,243 Charlotte, North Carolina
sgcuda
Remove front sway bar. Relocate battery. What size carb do you have. More than likely, a 1" 4 hole spacer will help throttle response. Good second hand 3,000 stall converter. Gears, if strictly race, and 1/8 mile.
[image][/image]
[Re: mechanic190]
#2073107
05/14/16 08:43 AM
05/14/16 08:43 AM
Posts: 10,037 Frostbitefalls MN (Rocky&Bullw...
gregsdart
What converter is it you have? An increase in stall from a well built converter will help. Find out if it is lower stall than a stock type 340 converter, and if it is, that might be a cheap upgrade.
8.582, 160.18 mph best, 2905 lbs 549, indy 572-13, alky
[Re: mechanic190]
#2073164
05/14/16 11:45 AM
05/14/16 11:45 AM
sgcuda
Carb is good size but should be swapped for a double pumper. 3 keyway timing kit, install cam on advance setting. Disconnect vacuum advance, install lightweight spring kit and set full timing 32-36. Bolt a 12-18" tailpipe on the back of the headers.
[image][/image]
[Re: gregsdart]
#2073853
05/15/16 02:29 PM
05/15/16 02:29 PM
OUTLAWD
Metro Detroit
What converter is it you have? An increase in stall from a well built converter will help. Find out if it is lower stall than a stock type 340 converter, and if it is, that might be a cheap upgrade. This. I ran a factory "high stall" 340 converter with the external balanced weight...stalled to ~2400 behind by mild 360. Swapped to a used 10" ATI and saw virtually no gains...
[Re: mechanic190]
#2073877
05/15/16 03:33 PM
05/15/16 03:33 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Not sure on the brand but it's an aftermarket smaller neutral balance (running with a weighted b&m flex plate, before somebody says something about it) I do need to time the cam right now it is in there as it came with a double roller timing chain. Timing is set at 21 initial and 37 total I believe. With vac advance hooked up.
Honestly I built this engine back in early 2015 and just broke it in 4 months ago. All of my part choices were what I had in the garage at the time. My biggest complaint on hoe it runs now even after accelerator pump tuning is it is sluggish off the line but 3500 she takes off decent till about 5500 You might want to advance that cam 4* or more to help with low end torque especially with the gear and the conv in it now ![wave wave](/ubbthreads/images/graemlins/custom/wave.gif)
