Re: Car wants to stall after car wash
[Re: minivan]
#2079659
05/24/16 11:55 PM
05/24/16 11:55 PM
Posts: 206 Los Angeles CA
xyxxjx
Los Angeles CA
I took the cap off it apears to be new, and it was completely dry. The spark plug wires visually apeared ok. The idle is still not too good but appears slightly better than a few days ago so maybe something is drying up. The idle seems ok in park when the engine has warmed up a bit, but terrible for the first few minutes. When I put it in drive the rpm drops and the car is shaking a lot, feels like it wants to stall. The first video is shifting from park to drive and back again. If you turn up the sound you can hear it better. Also what is the high pitched sound over the rumble of the engine? Seems like it got a bit louder. The second video is of the firewall in the engine compartment. Even a slight amount of moisture inside your cap will cause problems, my reason for recommending a "water displacer"... Did you at least blow it out with air? Unfortunately I didn't have access to air but it felt bone dry when I ran my finger inside.
1973 Dodge Charger SE 400 automatic transmission. Curb weight: 3800 lbs. All stock so far.
Goal: Reliable everday driveable warmed up 400 as close to 400hp as possible, then a 470 stroker if need be.
Don't protect a feminist when the collapse comes!
[Re: xyxxjx]
#2079718
05/25/16 12:56 AM
05/25/16 12:56 AM
Posts: 2,154 Its a TRAP!
DARTH V8Я
Oh No!! I just had a moron attack!
Its a TRAP!
I took the cap off it apears to be new, and it was completely dry. The spark plug wires visually apeared ok. The idle is still not too good but appears slightly better than a few days ago so maybe something is drying up. The idle seems ok in park when the engine has warmed up a bit, but terrible for the first few minutes. When I put it in drive the rpm drops and the car is shaking a lot, feels like it wants to stall. The first video is shifting from park to drive and back again. If you turn up the sound you can hear it better. Also what is the high pitched sound over the rumble of the engine? Seems like it got a bit louder. The second video is of the firewall in the engine compartment. Even a slight amount of moisture inside your cap will cause problems, my reason for recommending a "water displacer"... Did you at least blow it out with air? Unfortunately I didn't have access to air but it felt bone dry when I ran my finger inside. Hairdryer.. or you can buy cans of compressed air at a computer store. Handy to have when thing get wet but not in a fun way.
When it takes more than a sweet mullet to prove you rule at the trailer park..
[Re: DARTH V8Я]
#2079785
05/25/16 02:53 AM
05/25/16 02:53 AM
xyxxjx
Los Angeles CA
I took the cap off it apears to be new, and it was completely dry. The spark plug wires visually apeared ok. The idle is still not too good but appears slightly better than a few days ago so maybe something is drying up. The idle seems ok in park when the engine has warmed up a bit, but terrible for the first few minutes. When I put it in drive the rpm drops and the car is shaking a lot, feels like it wants to stall. The first video is shifting from park to drive and back again. If you turn up the sound you can hear it better. Also what is the high pitched sound over the rumble of the engine? Seems like it got a bit louder. The second video is of the firewall in the engine compartment. Even a slight amount of moisture inside your cap will cause problems, my reason for recommending a "water displacer"... Did you at least blow it out with air? Unfortunately I didn't have access to air but it felt bone dry when I ran my finger inside. Hairdryer.. or you can buy cans of compressed air at a computer store. Handy to have when thing get wet but not in a fun way. I'll buy some compressed air in a can tomorrow and try. Would you recommend also trying to spray the bulkhead and all those wire on the firewall? Since they may also have been hit with water. I think I'll buy a set of these http://www.jegs.com/i/JEGS+Performance+Products/555/40252/10002/-1. Just to eliminate the spark plug wires.
[Re: ahy]
#2080180
05/25/16 06:35 PM
05/25/16 06:35 PM
xyxxjx
Los Angeles CA
Best on the bulkhead connector is to remove it and visually inspect. Look for signs of corrosion and heat, especially on the heavy power feed wires. After inspection, clean as best possible, grease it and re-install. I like the spray lithium grease for this but any grease will work.
If you find signs of heat and/or heavy corrosion, best to bypass using one of the many strategies (search Madd Electrical Bypass for example). This is a good idea anyhow for reliability. You mean this page? http://www.madelectrical.com/electricaltech/amp-gauges.shtml
[Re: xyxxjx]
#2080286
05/25/16 10:02 PM
05/25/16 10:02 PM
Posts: 7,664 IN
ahy
IN
If you find signs of heat and/or heavy corrosion, best to bypass using one of the many strategies (search Madd Electrical Bypass for example). This is a good idea anyhow for reliability. You mean this page? http://www.madelectrical.com/electricaltech/amp-gauges.shtml Yep... that's the one. The bulkhead connector and ammeter (if equipped) are the trouble spots. Also to a lesser extent fusible link connections near the fender relay. I have had trouble with the bulkhead and fusible link. Others have difficulties with the ammeter. The bulkhead and fusible link can be sensitive to water. There are several approaches to fix this... the madelectric way is one of the good ones.
[Re: ahy]
#2080459
05/26/16 01:45 AM
05/26/16 01:45 AM
xyxxjx
Los Angeles CA
If you find signs of heat and/or heavy corrosion, best to bypass using one of the many strategies (search Madd Electrical Bypass for example). This is a good idea anyhow for reliability. You mean this page? http://www.madelectrical.com/electricaltech/amp-gauges.shtml Yep... that's the one. The bulkhead connector and ammeter (if equipped) are the trouble spots. Also to a lesser extent fusible link connections near the fender relay. I have had trouble with the bulkhead and fusible link. Others have difficulties with the ammeter. The bulkhead and fusible link can be sensitive to water. There are several approaches to fix this... the madelectric way is one of the good ones. I tried to unhook leftmost connector on the bulk the platic clip? Broke right off, barely touched it at all. I wasn't able to locate the fusible link could you explain in detail where it is?
[Re: xyxxjx]
#2080619
05/26/16 12:23 PM
05/26/16 12:23 PM
RapidRobert
follow the main power line from the starter relay large battery stud to the bulkhead, it should have a molded tag on it to ID it. it was fine before the car wash water was introduced so I would continue to blow dry everything and the blast may have also undid something a bit that is causing this
