Re: NOT!!! How you want your race season to start off... (LONG)
[Re: dizuster]
#2077947
05/21/16 10:47 PM
05/21/16 10:47 PM
Posts: 1,894 Spahn Ranch
RMCHRGR
Spahn Ranch
Man, that stinks.
I feel your pain. I dropped a screw down the dist. hole while finishing up my motor about two months ago, heard it go into the pan. Did the exact same thing you did, tried to fish it out with a flexible magnet, couldn't get it out, had to take the pan off. When I turned the motor over, it got lodged between a piston and pin, had to wiggle it carefully to dislodge it, was sweating bullets not to nick anything. Again, luckily it was on the stand but still a huge P.I.T.A.
Hope you get it all back together soon.
'71 Duster '72 Challenger '17 Ram 1500
[Re: dizuster]
#2077989
05/21/16 11:27 PM
05/21/16 11:27 PM
Posts: 4,243 Charlotte, North Carolina
sgcuda
Better to have it happen at an idle as opposed to being up at rpm. Could have been a lot worse. Did you figure out where the washer came from
[image][/image]
[Re: sgcuda]
#2078006
05/21/16 11:44 PM
05/21/16 11:44 PM
Posts: 4,704 Wichita
GY3
Wichita
Better to have it happen at an idle as opposed to being up at rpm. Could have been a lot worse. Did you figure out where the washer came from This ¿!
[Re: dizuster]
#2078009
05/21/16 11:49 PM
05/21/16 11:49 PM
Posts: 903 S.E. Minnesota
gtsdude
S.E. Minnesota
Dang! Hope your luck changes! Washer from the turbo clamp that broke?
[Re: dizuster]
#2078212
05/22/16 12:54 PM
05/22/16 12:54 PM
Posts: 3,635 Oakland, MI
dizuster
Oakland, MI
Yeah it'll all be ok. It's just racing... not what you want to happen on a new build, but it happens.
Biggest concern is the bore. My machinist buddy is going to come over and take a look at it. See if it'll clean up with the portable hone real quick, if so I'll put it back together... if not it comes apart. Neither of the pistons pinched the rings, skirts look fine... and I do have one more spare piston so even if one of them is junk I have that going for me.
Depending on what my buddy thinks, we'll either just re-cut the head, or weld it up. The chamber itself looks ok, its really just the quench pad that looks bad. Obviously we'll take a look at the seat when we pop the heads apart. Bearings looked fine.
Honestly I have NO idea where that washer (or at least what looks like a washer) came from. It definitely didn't come from the turbo clamp because the nut was still on the T-bolt. Bothers me that I don't know where the other 1/2 of it is too! It's sort of a pain in the butt, but I think I'll take the hotside off and make sure it's not in the crossover. I looked at the turbine wheel, no signs of it exiting the motor. So it COULD be in the downpipe/exhaust too I suppose. Just need to carefully look at everything, and get it back together. Sucks... but that's racing right!
I find it amazing that the car got ~15 street miles on it before we heard the noise at Milan. It's strange because the #7 plug was hit and closed the gap up. But it must have happened VERY early in the new build because it doesn't look like it's ever been fired at all. ZERO HEAT. So that washer had to be in there from the beginning, hit the plug, and then disappeared back into the intake? Not really sure. I have no idea where it started from. The only thing I can think is that maybe a washer got into the air filter. But you'd think the turbo would show signs of eating something that big through the compressor wheel. Hard to say...
Leading contenders among my friends where the washer came from was...
Ryan did it - So he could come over and drink more of my beer putting it back together.
Dave did it - So he could get more of my money for machine work.
Obama did it - Because he was mad that he missed out on this car the last time cash for clunkers came around.
[Re: dizuster]
#2078221
05/22/16 01:04 PM
05/22/16 01:04 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I sure hope he can hone it for ya...best of luck on it Scott... yeah eyeball EVERYTHING to see if you can find the remaining chunk... I'm GUESSING that its down in the exhaust or muff... might want to smack the muff with your hand to see if you can hear it ![wave wave](/ubbthreads/images/graemlins/custom/wave.gif)
[Re: dizuster]
#2078734
05/23/16 11:16 AM
05/23/16 11:16 AM
Posts: 13,402 Marion, South Carolina [><]
an8sec70cuda
Sorry to hear that! Hope you get it back together soon and find the bores are ok.
[Re: b1dartsport]
#2078938
05/23/16 05:34 PM
05/23/16 05:34 PM
fullmetaljacket
DVW did it! He's your envious Brother. Just kiddin' just kiddin'
Sorry for the mess, but it can all be put back together, stronger, meaner and cleaner. My good buddy here "Glasses" who has built many many a small block Chrysler over the years once installed the Pistons back wards in one of the banks. Did not notice till he got a few runs in and it all was down hill, but without much damage. He now keeps the grotto closed when he is doing assembly. I do the same when working on my junk yard dog. It's always fun when chatting with the guys while assembly, but not fun when that foreign sound from within amplifies through your heart.
You'll be back. We all look forward to it.
[Re: dizuster]
#2079143
05/24/16 12:52 AM
05/24/16 12:52 AM
Posts: 417 reynoldsburg,ohio
poppaj
reynoldsburg,ohio
Sorry to hear this Scotty, let us know if we can help out in any way.
AA/NSS 65'Coronet "Whompin Wedge" Pop & Son Performance 557" B-1 power John Holt Chassis
