Re: Chevy connecting rod guys
[Re: JohnRR]
#207738
01/29/09 04:08 PM
01/29/09 04:08 PM
Posts: 778 Southington Ct.
turbobitt
Southington Ct.
they make a 2.2 rod with a mopar width ???
K1 makes a rod like that. There catalog is a litle confusing because they are listed under mopar BB but don't specify the width but does specify 2.2 crankpin and carries a different P/N then the chevy version. http://k1technologies.com/Portals/0/Documents/K1Catalog.pdf Find them on page 7. Got mine from DRAM.
Allan G.
1970 Challenger w/572 Hemi street car and my pride and joy.
1986 T-Type with 272 Stage 2 Buick V6 engine - True 8 second street car. Just updated the engine and put down 928 HP @ 35# boost to the ground on chasis dyno.
1976 Cee Bee Avenger Jet Boat - 460 Ford powered.
[Re: CokeBottleKid]
#207740
01/29/09 11:05 PM
01/29/09 11:05 PM
a lot of people used to use an Eagle rod for that combo. can't remember which one though. i haven't used the rod in question in years now since there's more choices of parts for that combo.
Post deleted by Defbob
[Re: CokeBottleKid]
#207741
01/29/09 11:08 PM
01/29/09 11:08 PM
[Re: Streetwize]
#207743
01/30/09 08:21 AM
01/30/09 08:21 AM
Posts: 8,194 Detroit, MI
CokeBottleKid
Detroit, MI
A standard BBC rod is 6.135...only slightly longer than a 340 rod. Most aftermrkets are .6.385, 6.535 (very popular with 511 low decks) and 6.700's/6.800's which generally work best on 470's and were designed for the taller deck (~10.200 Vs 9.80) Merlin block BBC's (540's and 572's)
Thanks Wize, pretty much what I'm looking for here guys is a census, who's using chevy rods? Be it on a chevy width crank or a mopar width crank, what brand/length/part #? That's all I'm looking for...
[Re: CokeBottleKid]
#207744
01/30/09 08:51 AM
01/30/09 08:51 AM
Posts: 3,305 West Coast, USA
jbc426
West Coast, USA
I chose 440Source's 7.0" Chevy rods w/ Mopar width big end for my 493" RB
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
[Re: CokeBottleKid]
#207746
01/30/09 09:50 AM
01/30/09 09:50 AM
Posts: 3,547 Syracuse,NY
CompWedgeEngines
Syracuse,NY
The old Manley rod that you were referring to was a 14279-8 SPortsmaster rod, which as you know hasnt been made for about 6 or 7 years. I believe they were the only ones that made such a rod.It was the "answer" when there werent so many commercially available stroker set ups for Mopar. As Wize says, typically you'll see 6.700 or 6.800 in the combos. yes its also not incommon to use a Chevy rod width in a race motor withy Mopar journals. Runs just fine, but I wouldnt want to see it in a street combo as much.Its another topic that people will argue to death, and in the end, the run just fine, but as any experienced engone builder would agree, it wouldnt be your first choice if you had options. HAZE, it would help you to get better information if you include where you are trying to head instead of being "evasive" with your intent. I am assuming its for school reserach, but if so, just say so and people can make a better recomendation etc. Hope the info helps. My
RIP Monte Smith
[Re: CokeBottleKid]
#207747
01/30/09 09:57 AM
01/30/09 09:57 AM
Posts: 75,329 A gulag near you.
JohnRR
A gulag near you.
I'll ask another STUPID question since your question is so vaque that you have guys telling you what rods they are using on RB BUILDS whern you appear to be asking about a LOW DECK BUILD ...
what's the CH of the piston you are going to use ???
Here is what I have , and it ACTUALLY answers your question , I'll leave out the source of the rod since that is IRRELEVANT ...
3.895 crank , 1.320 CH piston works with a 6.700 rod , lots of side clearance but the prior build with this crank and 2.2 BBC big end width spec rods had no problem making over 700 HP
Now that James brought it up , Manley HAD a Sportsmater rod that was 6.765 long and had a 2.2 big end that was closer to mopar width , I'm pretty sure Andy F and 440Jim used that rod in their 470" builds .
[Re: CokeBottleKid]
#207749
01/30/09 11:30 AM
01/30/09 11:30 AM
Posts: 31,274 Oregon
AndyF
What was the hot chevy rod everyone was using years ago in the 471 strokers etc before they started making mopar width 2.2 big end rods?
The trick rod we all used years ago was a Manley rod which was Mopar width with a 2.200 rod journal size. That rod allowed us to build low cost stroker motors by offset grinding a factory crank. That rod is no longer available and not needed anymore since these days most crank mfgs make Mopar stroker cranks with Chevy pins.
[Re: turbobitt]
#207750
01/31/09 05:27 AM
01/31/09 05:27 AM
CokeBottleKid
Detroit, MI
K1's 7.0" chevy rod, chevy width and chevy .990 pin on a 4.5 stroke K1 crank.
Thank you exactly what I'm looking for. So to anymore ppl with chevy width cranks or people using chevy rods in general, what rod and part #s please.
[Re: CokeBottleKid]
#207751
01/31/09 08:33 AM
01/31/09 08:33 AM
Posts: 16,941 NC
440Jim
NC
I am running a Callies 4.250" crank with Chevy rod dimensions. The rods I am using in my low deck are Scat, 6.535", H-beam.
In my old 471 CID (3.915" x 4.375") low deck, I ran Manley Sportsmaster I-beam rods, #14279, length 6.765, BB Chevy journal with Mopar width ~1.016", .990 pin
[Re: CokeBottleKid]
#207752
01/31/09 10:08 AM
01/31/09 10:08 AM
JohnRR
A gulag near you.
eric are you building a low deck or a raised deck ?
