Re: Scrapping the Apache for the Eagle
[Re: sixpackgut]
#2077096
05/20/16 01:37 PM
05/20/16 01:37 PM
Posts: 46 texas
462hemi
texas
I know 100 percent you have to change the seats to put a valve larger than 2.10 in the eagle heads. Alex p.......that whole ultra high velocity, low flowing early 5.7 head was cobbled up by Craig at gtp. It has been proven wrong for years. If that were the case, the 6.4 Apache head would be a lot smaller. They went exactly the opposite direction for a reason. I'll trade velocity any day of the week for a properly designed larger csa head that flows 60cfm more. Take your "max ported early 5.7 head and throw it on a 426, then swap out for a set of thiteks with 2.20 vales and MUCH lower velocity numbers and the motor will make 70-80hp more with the thiteks
462 gen 3 hemi daily driven
[Re: 462hemi]
#2077111
05/20/16 02:05 PM
05/20/16 02:05 PM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
I know 100 percent you have to change the seats to put a valve larger than 2.10 in the eagle heads. Alex p.......that whole ultra high velocity, low flowing early 5.7 head was cobbled up by Craig at gtp. It has been proven wrong for years. If that were the case, the 6.4 Apache head would be a lot smaller. They went exactly the opposite direction for a reason. I'll trade velocity any day of the week for a properly designed larger csa head that flows 60cfm more. Take your "max ported early 5.7 head and throw it on a 426, then swap out for a set of thiteks with 2.20 vales and MUCH lower velocity numbers and the motor will make 70-80hp more with the thiteks Im not really sure what your talking about. Who said they were putting the old smaller heads on a 426? and you comparing them to thiteks with a 2.20 valve.
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
[Re: sixpackgut]
#2077286
05/20/16 08:16 PM
05/20/16 08:16 PM
Posts: 46 texas
462hemi
texas
I was referring to Alex p's talks about using gen 1 5.7 heads to make more power than larger heads. It's a idea that Craig at gtp swears by. He swears a set of gen1 5.7 heads will make way more power than bigger heads. His philosophy is velocity over flow and csa. Alex knows what I am talking about. If you read his post it will make more sense to you
[Re: AlexP]
#2077289
05/20/16 08:19 PM
05/20/16 08:19 PM
Posts: 46 texas
462hemi
texas
High velocity works. Don't know who you are, what your relationship is with Craig or if you have any more experience than vendor shopping people for information and comparing notes but I'm happy with my small port Eagles. I'd be happy with a worked up set of early 5.7 heads too. No reason for me to own a thitek, ever.
I put my money on that gamble and I know what my expectations are. I was working on and porting 5.7 and 6.1 heads before even gremlin Steve Alex. Steveo is a bright dude and a helluva guy. But The thought that a motor won't benefit from a larger better flowing port with a larger csa is silly. I only speak of what i personally know to be true from experience.
[Re: sixpackgut]
#2077293
05/20/16 08:30 PM
05/20/16 08:30 PM
Posts: 46 texas
462hemi
texas
Sixpack.....bes did something similar to what you are talking about doing with their engine masters 417ci motor. 2.19 intake valves with new seats.....they actually sunk the intake valves a good bit to help with p to v. Wouldn't milling the head and sinking the valves on the apaches be a bit easier?
[Re: 462hemi]
#2077304
05/20/16 08:55 PM
05/20/16 08:55 PM
Posts: 10,645 Houston, Tx
AlexP
Houston, Tx
I put my money on that gamble and I know what my expectations are. I was working on and porting 5.7 and 6.1 heads before even gremlin Steve Alex. Steveo is a bright dude and a helluva guy. But The thought that a motor won't benefit from a larger better flowing port with a larger csa is silly. I only speak of what i personally know to be true from experience. I just figured out who you are. You've said enough.
[Re: 462hemi]
#2077525
05/21/16 03:07 AM
05/21/16 03:07 AM
Posts: 723 Houston Tx
Uhcoog1
Houston Tx
next thing I want to try and big Thanks to Dustin for sending some banged up heads, is stuffing the 03-08 5.7 head with a 6.1 valve. I really think the original 5.7 heads can be an awesome high velocity head which I would think 320cfm around .6 is easily possible because I hit 312 opening the throat probably a little to far 330 on Craig's bench, 310 through the Hilborn. I'll go find the printout if you'd like. I know 100 percent you have to change the seats to put a valve larger than 2.10 in the eagle heads. Alex p.......that whole ultra high velocity, low flowing early 5.7 head was cobbled up by Craig at gtp. It has been proven wrong for years. If that were the case, the 6.4 Apache head would be a lot smaller. They went exactly the opposite direction for a reason. I'll trade velocity any day of the week for a properly designed larger csa head that flows 60cfm more. Take your "max ported early 5.7 head and throw it on a 426, then swap out for a set of thiteks with 2.20 vales and MUCH lower velocity numbers and the motor will make 70-80hp more with the thiteks Send me some thiteks or apaches. I'll run em back to back with my early 5.7 heads and will report back the numbers.
-'02 Dodge Viper Ex-World Challenge racecar -'73 Duster, 6.1 based 392 hilborn hemi, tko600, full floater rear 9", Hellwig custom bars, viper brakes, built for road course
[Re: Uhcoog1]
#2077599
05/21/16 11:22 AM
05/21/16 11:22 AM
Posts: 46 texas
462hemi
texas
Lol.....I actually would if I had a set of each not in use ......on my 423 a set of thiteks was worth 40 horsepower at the wheels over ported 6.1s with stock valves. The thiteks had 2.20s. I still love your duster.....One of these I will get to see that beast
[Re: 462hemi]
#2078101
05/22/16 03:20 AM
05/22/16 03:20 AM
Uhcoog1
Houston Tx
Lol.....I actually would if I had a set of each not in use ......on my 423 a set of thiteks was worth 40 horsepower at the wheels over ported 6.1s with stock valves. The thiteks had 2.20s. I still love your duster.....One of these I will get to see that beast That's impressive! The next time I blow a motor I'll be looking for a different set of heads. What part of Texas are you in? Austin? We'll have to meet up and talk cars.
[Re: Uhcoog1]
#2078148
05/22/16 11:03 AM
05/22/16 11:03 AM
Posts: 46 texas
462hemi
texas
Lol.....I actually would if I had a set of each not in use ......on my 423 a set of thiteks was worth 40 horsepower at the wheels over ported 6.1s with stock valves. The thiteks had 2.20s. I still love your duster.....One of these I will get to see that beast That's impressive! The next time I blow a motor I'll be looking for a different set of heads. What part of Texas are you in? Austin? We'll have to meet up and talk cars. Hey brother, we have actually talked quite a few times before. I am here in Houston too. You were intrested in buying my 440" rotating assembly I had for sale for a while. I'll pm you number
