Re: GTS meets motor, pics.
[Re: sst404b]
#207581
02/02/09 08:56 PM
02/02/09 08:56 PM
Posts: 43,637 Round Lake Beach, Illinoisy
Rhinodart
Rhinotruck
Rhinotruck
Rhino, The crank pulley was blasted and had not been painted and there was not a water pump pulley,I was tired of waiting for parts and decided to just put it in the car and change out parts later.One question I have is #5 plug wire is right on the power steering box,did I miss something?Everything is in line and appears to fit nicely except that spark is real close.Also could the Mods move this to Members as suggested eariler? I will post more pics later. Thanks, Ray
I have found that the reproduction wire sets that are sold have the wrong length wires for the driver's side. The only one's I have found that are right are from these guys:
http://cgi.ebay.com/ebaymotors/ws/eBayIS...RTQ:MOTORS:1123
I had trouble with the #5 and #7 routing with the typical repro sets, this set has the correct length, especially for the #7 wire! ![](/ubbthreads/images/graemlins/wave.gif)
JB Rhinehart, Realist
A-Body's RULE!
[Re: Rhinodart]
#207582
02/03/09 12:37 PM
02/03/09 12:37 PM
Posts: 75,098 A Banana Republic near you.
JohnRR
You need a set for a C Barge with a 383 HP engine . I used a repop set I think I got from Jacks for my Bee , the only one that was too short was #7 which makes sense , it needed to be about 5 inches longer than the non c body set , the other wires seemed to be fine .
Another note , not to be nit picky, but the OP has a 68 right side valvecover .
