Re: Pump Gas Gen 2 Hemis [Re: DaveRS23] #2074811
05/16/16 11:11 PM
05/16/16 11:11 PM
Pa
Hot 340 Offline OP
Hot 340  Offline OP
Pa
Originally Posted By DaveRS23
I bought my 540 reciprocating assembly and cam from Ray Barton. He spec'd the CR @ 10.5 for this aluminum headed street/strip motor. I asked him about more comp since I have ran 11:1 in my aluminum headed 499 wedge for years with no problems. He said there wasn't enough additional power for a primarily street driven engine to warrant the extra hassles.
Dave, what would be the extra hassle he is reffering to? If you have to get pistons anyway, would cost much more to bump it some i wouldnt think
Re: Pump Gas Hemis [Re: Hot 340] #2074829
05/16/16 11:35 PM
05/16/16 11:35 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
Originally Posted By Hot 340
Originally Posted By 72Swinger
What pump gas? Non ethanol? 91 or 93? 11.1 with aluminum heads is about the max in the REAL world IMO.
whats your combination? Are you seeing detonation at 11?
I ran 11.6:1 in my 484 with no issues for years. I have a 605 hemi now, and I am right around 11.0-11.1:1 with no issues. The Hemi's are very resistant to having issues with detonation. I would be very comfortable running 12:1 on 93 and watching my timing and tune up. What we use around here is E10, so until they get rid of it, that's what I am running mine on.
I would not run any lower than 11:1 on pump gas with a hemi. If your building it, build it for 12:1 with .027 head gaskets, and switch to thicker ones if you have to.
any trouble with 12:1 on a hot day? That would be my concern.
Never had an issue at 11.6 and I drove it a bunch in 90 temps.....You have to remember anything with aluminum heads that heats up loses compression as it gets to temp...The Hemi has a huge combustion chamber....And drops compression a little at temp. Its not really 12:1 at 185 degress anymore.
Re: Pump Gas Gen 2 Hemis [Re: Hot 340] #2075012
05/17/16 11:17 AM
05/17/16 11:17 AM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
I think he was referring to issues with gasoline quality and detonation.
Master, again and still
Re: Pump Gas Hemis [Re: ta3834bbl] #2075075
05/17/16 12:57 PM
05/17/16 12:57 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
Originally Posted By ta3834bbl
Yes, I am very interested in your combo as well. I love to learn new stuff that works.
Originally Posted By cudadoug
Originally Posted By 6PKRTSE
Just finished and dyno'd my 528 with a true 10.5:1 and it almost made 840 hp and 671 TQ.
Care to share the combo?
Mine is nothing special. Mopar Mega block, 4.500 bore x 4.150 stroke, Mopar Performance heads, with Barton valvetrain, .800 solid roller cam with 4/7 swap. Indy intake.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: Pump Gas Hemis [Re: 6PKRTSE] #2078183
05/22/16 12:09 PM
05/22/16 12:09 PM
pa
572charger Offline
572charger  Offline
pa
ive been at 12.2 to one with my 606 cu hemi runs on 93 octane no problems , but the big motors with good heads don't like much timming either that helps out
606 hemi pump gas best 9.60 at 142mph on motor
05 hemi daytona 1500 go-mango 4wd quadcab
2007 hotrod mag pump gas drags runner up, roadkill nights dodge big tire winner 2018 2019 back to back
Re: Pump Gas Hemis [Re: 572charger] #2078188
05/22/16 12:16 PM
05/22/16 12:16 PM
Dragula Offline
Dragula  Offline
Yup 29-30 degrees is what have seen.
Re: Pump Gas Hemis [Re: Dragula] #2078204
05/22/16 12:38 PM
05/22/16 12:38 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
My 10.5 540 liked 30* on the dyno this week.
Re: Pump Gas Hemis [Re: DaveRS23] #2078852
05/23/16 02:55 PM
05/23/16 02:55 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
Mine liked 33 Degrees best. Lost some power at 32 or less & also lost some at 34+.
Re: Pump Gas Hemis [Re: Hot 340] #2078861
05/23/16 03:05 PM
05/23/16 03:05 PM
an8sec70cuda Offline
My 572 likes 34°. Atleast it did...I have not changed my base timing in 10 years, lol.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Pump Gas Hemis [Re: an8sec70cuda] #2079482
05/24/16 06:38 PM
05/24/16 06:38 PM
Pa
Hot 340 Offline OP
Hot 340  Offline OP
Pa
Thanks for all the info here guys.
Re: Pump Gas Hemis [Re: Hot 340] #2108886
07/12/16 06:49 PM
07/12/16 06:49 PM
Dragula Offline
Dragula  Offline
We put nearly 15 dyno pulls on my buddy's all aluminum 572 Hemi and it liked 29 the best. Lost 20hp & 20 torque at 30 degrees....My 605 is 32-33 and I have not played with it. So far best 1/8th mile was 6.32 spinning....Lots more in it, but I am only legal to 6.50, so we left the timing where it was, and the mufflers on it.
Vid of one of the 572 dyno pulls
https://www.youtube.com/watch?v=5QjkTW-o1QY
My 6.36 pass against y buddies slower full race car....
https://www.youtube.com/watch?v=NVTE82X6ZQ8
