Re: Time to change some rotating parts
[Re: FastmOp]
#2072174
05/12/16 06:28 PM
05/12/16 06:28 PM
dogdays
No to the full dish, use a D-shaped dish or reverse dome so if you now or later use a head with a squish area it can work. www.theoldone.com Somewhere in there he talks about using a supercharger on an 11.3:1 engine, something like that. If you have good combustion chamber dynamics, the engine's octane requirements go down. R.
[Re: dogdays]
#2072178
05/12/16 06:34 PM
05/12/16 06:34 PM
Posts: 4,489 northern,Ohio,USA
Clanton
northern,Ohio,USA
No to the full dish, use a D-shaped dish or reverse dome so if you now or later use a head with a squish area it can work. www.theoldone.comR. A full dish works great with my friends LS turbo,I have Edl victor heads now.
[Re: Clanton]
#2072217
05/12/16 08:03 PM
05/12/16 08:03 PM
Posts: 20,197 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Not a lover of Eagle products but I wish you luck.
[Re: Clanton]
#2072254
05/12/16 09:44 PM
05/12/16 09:44 PM
Posts: 20,197 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Not a lover of Eagle products but I wish you luck. Is there a technical point to your opinion? Eagle is one of two companies that I have had bad experiences with quality wise on engines (assemblies) that I have assembled for myself and Friends. As with all race products check to over carefully which includes testing the convertor hub in the back of the crank and taper.
[Re: pittsburghracer]
#2072294
05/12/16 10:39 PM
05/12/16 10:39 PM
Clanton
northern,Ohio,USA
Not a lover of Eagle products but I wish you luck. Is there a technical point to your opinion? Eagle is one of two companies that I have had bad experiences with quality wise on engines (assemblies) that I have assembled for myself and Friends. As with all race products check to over carefully which includes testing the convertor hub in the back of the crank and taper. Sounds like good info thanks.
[Re: Clanton]
#2073874
05/15/16 03:28 PM
05/15/16 03:28 PM
Posts: 6,591 Canton, Ohio
Sport440
Canton, Ohio
No to the full dish, use a D-shaped dish or reverse dome so if you now or later use a head with a squish area it can work. www.theoldone.comR. A full dish works great with my friends LS turbo,I have Edl victor heads now. 0 If your starting from scratch and you can get the comp low enough where you want it, absolutely the reverse dome or the D dish. Sure the full dish works, but the other has been proven to work so much better. Better more efficient combustion chamber, less chance of detonation, more HP etc. So why wouldn't you? Do it, IMO, it cant be that much more expensive.
[Re: Sport440]
#2073878
05/15/16 03:33 PM
05/15/16 03:33 PM
Clanton
northern,Ohio,USA
No to the full dish, use a D-shaped dish or reverse dome so if you now or later use a head with a squish area it can work. www.theoldone.comR. A full dish works great with my friends LS turbo,I have Edl victor heads now. 0 If your starting from scratch and you can get the comp low enough where you want it, absolutely the reverse dome or the D dish. Sure the full dish works, but the other has been proven to work so much better. Better more efficient combustion chamber, less chance of detonation, more HP etc. So why wouldn't you? Do it, IMO, it cant be that much more expensive. I did not see that info about a boosted engine and what you say seems a bit exaggerated to me.Maybe in a n/a.
[Re: Clanton]
#2073892
05/15/16 03:51 PM
05/15/16 03:51 PM
Sport440
Canton, Ohio
Its definitely not going to hurt you. You may benefit the most from the more resistance to detonation. Boosted engines can use all the help they can in that department, as boost is already heating up the mixture to begin with increasing the earlier onset of detonation.
I wouldn't just flat rule out the reverse dome or D dish until you look into it a little more.
Also what kind of supercharger do you have. Some are a lot worse then others for producing heat. I think the Eaton type have been nicknamed by some Heaters, for the excess heat they produce.
The whipple superchargers have a design where the compressors blow straight down though into the intake vs The Eatons forcing the air out and around the the inside of the blowers body taking a longer sharper turning path of the charge creating more heat.
[Re: Clanton]
#2073973
05/15/16 05:59 PM
05/15/16 05:59 PM
Sport440
Canton, Ohio
That's good about the cooler. Saw some of your prior posts. 1. Your flat tops did show some signs of detonation from the pics and in your own words. Good move on getting the new intercooler vs your other intercooler. 2. Saw you had a smoking deal on some Diamonds?? I guess your not going to use them, because your going to order Custom pistons tomorrow, stated in this post???. If your getting a deal on some dish diamonds use them you will be fine, you can make power with boost with pistons .300 down the hole. But if you really are going to pull the trigger tomorrow on some Custom pistons, Id go with the D,s with quench, hands down. But, it will run too with a dish. But The benefits of Quench and a efficient combustion chamber doesn't care if the motor is Boosted or NA. I hope you don't take this personal, either, I don't. I hope I didn't say to much.
[Re: Clanton]
#2074301
05/16/16 01:32 AM
05/16/16 01:32 AM
Sport440
Canton, Ohio
another option is to angle cut the dish on 1/2 the dish like softening the chamber but on the piston.I read that a 7* works good. So its a basically a D Dish with the flat quench part on a 7* down angle till it meets the full dish?? That sounds ok to me. Wiseco can do amazing things with there piston design abilities. From the pics on their website, they can machine any shape piston top you desire.
