Re: Seats for the large driver?
[Re: DrCharles]
#2060412
04/23/16 06:51 PM
04/23/16 06:51 PM
Posts: 28,078 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
Too bad you can't slide in the seats from an Imperial. I really like the super cushy split bench in mine. It's more than roomy enough for a guy your size.
[Re: feets]
#2060427
04/23/16 07:18 PM
04/23/16 07:18 PM
Posts: 1,751 Graham, WA
Polarapete
Graham, WA
Too bad you can't slide in the seats from an Imperial. I really like the super cushy split bench in mine. It's more than roomy enough for a guy your size. I put a complete interior out of a '69 Mercury Marquis into my '64 Polara. It was a hassle...the floor had to be cut out of the Mercury to handle the seat mounts (Electric split bench for driver & manually adjusted passenger), but when it was done it looked factory and I was comfortable. The rear seat looked great and the door panels looked great and almost stock. But of course it was not numbers matching...as if I cared!!
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction 1998 Ram 2500 QuadCab, new daily driver. 2008 Honda Element 2014 Carry-On 7x14 Cargo Trailer
[Re: DrCharles]
#2060688
04/24/16 10:19 AM
04/24/16 10:19 AM
Posts: 22 Georgia
318 racer
Georgia
Look at Empi race seats. They have seats that are wider and look like race seats.... www.jeepswag.comCall them as they are updating the website. These are suspension seats.
[Re: DrCharles]
#2063953
04/29/16 01:05 PM
04/29/16 01:05 PM
Posts: 3,291 West Coast, USA
jbc426
West Coast, USA
I bought a set of Corbeau seats from Racing Seats USA. They are the wider version of their race seat. I absolutely love then. I opted for the leather version, and ordered the mounting brackets for my car. I did cut about an inch out of the brackets and re-welded them with a bit more reward tilt. They recline, slide forward and back significantly and are super comfortable with my 6'2", 260 lbs body, even on day long drives. Everyone who rides in the car wants them for their cars too.
I also ordered the shoulder/lap belts for the car, but they are not shown in this picture. They attach to the rear seatbelt mounting bolt with a single removable strap that splits into a double shoulder restraint before passing through the holes in the seatback. They connect to the lap belt. They do not have the anti-submarining strap that goes between your crotch, which is an option.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
[Re: jbc426]
#2063955
04/29/16 01:06 PM
04/29/16 01:06 PM
Posts: 4,220 West Plains, MO
DrCharles
West Plains, MO
I bought a set of Corbeau seats from Racing Seats USA. They are the wider version of their race seat. I absolutely love then. I opted for the leather version, and ordered the mounting brackets for my car. Looks nice! How much did the seats + brackets + shipping end up costing you?
[Re: DrCharles]
#2064223
04/29/16 08:25 PM
04/29/16 08:25 PM
Polarapete
Graham, WA
The Intrepid seats aren't even close to fitting the Dart floor pan. Looks like I will have to get some 2x2 1/8" angle iron and make some brackets.
The front outer hole on each seat could possibly bolt to the existing bench seat hole, and more or less centers the seat in front of the steering wheel, but the height may still be a bit low. I've got some fabricating to do! That is the name of the game... fabricate. I got a pair of 2002 Durango buckets from a yard for $60.00 and they are going into the Ramcharger. I already have the rack that is used when fitting factory buckets in the trucks and the adaptation will be easy.
[Re: DrCharles]
#2064329
04/29/16 10:22 PM
04/29/16 10:22 PM
Posts: 17,926 Akron, Ohio
ProSport
Akron, Ohio
Dodge Neon seats fit great also, all you have to do is bend the front mounting pads on the seat frames and drill new holes in the floor. They are comfortable too.
[Re: DrCharles]
#2064388
04/29/16 11:56 PM
04/29/16 11:56 PM
Posts: 4,292 Morrow, OH
markz528
Morrow, OH
I bought a set of Corbeau seats from Racing Seats USA. They are the wider version of their race seat. I absolutely love then. I opted for the leather version, and ordered the mounting brackets for my car. Looks nice! How much did the seats + brackets + shipping end up costing you? I put these Corbeaus in my GTX. They are not leather. I bought the wide version cause I'm 6' 3" 250 lbs. With brackets and submarine belt holes $1265 delivered. http://corbeau.com/reclining-seats/cr1.html
[Re: DrCharles]
#2073228
05/14/16 01:23 PM
05/14/16 01:23 PM
DrCharles
West Plains, MO
OK. Finally got the driver's seat in, after fabricating a beefy pair of brackets from 2x2 1/8" angle. The front is as low as it can go (due to the original bench seat mounting location on the floor pan) and they still sit a bit high. But I've never liked the low-rider look anyway, and getting them lower would require cutting and rewelding part of the floor pan. Will repeat the process on the passenger side. Now, what do I do for seat belts? ![work work](/ubbthreads/images/graemlins/custom/work.gif) The Intrepid seat has the female end of the buckle attached to its frame and I didn't get the belts with it (although I could). I would prefer the belts to be fastened to the body, not the seat, so that my homemade brackets aren't part of the structure under load in the event of an accident. I think I've got all the original Dart belts in the pile of boxes/bags, although 44-year-old webbing may not the safest choice! So - do I: Adapt the Intrepid belts to the Dart body? Use the original Dart belts? Buy new reproduction Dart belts? Some other kind of restraint system? Suggestions please? thanks Charles
[Re: DrCharles]
#2073247
05/14/16 01:41 PM
05/14/16 01:41 PM
feets
Senior Management
Senior Management
Irving, TX
Pop the buckle off the seat and use reproduction belts.
[Re: DrCharles]
#2073315
05/14/16 03:40 PM
05/14/16 03:40 PM
Posts: 22,782 Bitopia
jcc
Bitopia
A belt that keeps you in the seat is the better design, rather then merely attached to the floor, IMO. The theory being, if the seat moves, and the belt does not, the belt then becomes loose.
