Re: Place your bets, Dyno scheduled this Friday
[Re: Wookie316]
#2073011
05/14/16 12:50 AM
05/14/16 12:50 AM
Posts: 5,170 CT
GTX MATT
CT
610/565 with 750. 630/580 with 950. More details later. Off to the races now. Do I win? I was 8 hp and 4 ft lbs off
[Re: Wookie316]
#2073033
05/14/16 01:26 AM
05/14/16 01:26 AM
Posts: 43,375 Bend,OR USA
Cab_Burge
Springs hold to 7000. Obviously my local machine shop is a little rough with the bore though according to the vac readings. Drops off bad at 7200 and its still making power. Guess you get what you pay for. Torque plates work ![laugh laugh](/ubbthreads/images/graemlins/custom/laugh.gif) On another note, tech'd and waiting to race. Is the dnyo your using a chassis or engine dyno? If a engine dyno your parts are way over achieving IMO, if on a chassis dyno your really making me jealous now ![up up](/ubbthreads/images/graemlins/custom/thumbs_up.gif)
[Re: Wookie316]
#2073038
05/14/16 01:30 AM
05/14/16 01:30 AM
Posts: 2,422 Pittsburgh PA
Eric
Pittsburgh PA
Yes. They said pan evac Not good enough. What's the best vac pump to buy? Where do they fit if your running a p/s pump for the hydra steer? Air pump off a V6 GM truck 99-03 I've run one for years. They don't make much power but they do provide evac. If you go with a mechanical pump I would look at Star or GZ.
5.53 @ 125 1/8th on the launch control..more left in her!
[Re: Wookie316]
#2073150
05/14/16 11:29 AM
05/14/16 11:29 AM
Posts: 19,403 Las Vegas
Al_Alguire
Las Vegas
As for the question of a vacuum pump. Here is my .02. Get a Moroso three vane, good pumps and will not require a relief valve. It wont make enough to get to the point of pulling to much vacuum and will provide enough to be a benfit.
[Re: Wookie316]
#2073153
05/14/16 11:32 AM
05/14/16 11:32 AM
Posts: 611 Muncie
Racebuddy
Muncie
I think 650 hp would be an achievable number. Air flow aint poo for hp estimations. nice motor, glad to see the Big blocks doing well
[Re: Wookie316]
#2073239
05/14/16 01:32 PM
05/14/16 01:32 PM
Posts: 326 Alberta
Wookie316
Alberta
Castrol May 13 2016 1971 Superbee First time out with the new combo, 10.90 bests, 123MPH & 1.54 60 foot. Not bad for 4000 + pounds. I can put more timing in it and leave harder on the brake yet. So room to grow! ![](http://i566.photobucket.com/albums/ss108/jhowdle/1971%20SuperBee/35CA8FE6-73D2-437F-95AD-A131DD1F29FD_zpsvyfilagx.jpg) ![](http://i566.photobucket.com/albums/ss108/jhowdle/1971%20SuperBee/64AFA447-AEBD-41D5-80C4-51A68C3AD910_zpswt6ney6w.jpg)
1971 Plum Crazy Super Bee. 572 World Aluminum block with a Cope 727 & Dana 4.10 out back. 9.88 @ 138 with a 1.35 60 NA. Dialed back to 10.0’s. 4000 lbs with me in it.
[Re: Wookie316]
#2073243
05/14/16 01:37 PM
05/14/16 01:37 PM
Posts: 2,086 CA
crackedback
CA
[Re: Wookie316]
#2073304
05/14/16 03:25 PM
05/14/16 03:25 PM
Posts: 326 Alberta
Wookie316
Alberta
No. 2 engines. Have a 511 low deck in the car now.
[Re: Wookie316]
#2073535
05/14/16 10:03 PM
05/14/16 10:03 PM
Cab_Burge
No. 2 engines. Have a 511 low deck in the car now. so the stock stroke motor was on a engine dyno, yes? If you don't mind my prying what brand dyno and are these results corrected to ASE instrument standard conditions or are they uncorrected results ? ![confused confused](/ubbthreads/images/graemlins/custom/confused.gif)
[Re: BradH]
#2073660
05/15/16 01:12 AM
05/15/16 01:12 AM
Posts: 6,591 Canton, Ohio
Sport440
Canton, Ohio
Let me make sure that I'm clear on this... you went from the engine dyno to installing the engine in the car to testing the car at the track ON THE SAME DAY? Good catch Brad. Wookie, what the heck!! Didn't you think that we would all think the First time out times were a reflection of the new Dyno,ed motor?? Whats the build specs and HP of the AS run 511?
[Re: Wookie316]
#2073676
05/15/16 02:00 AM
05/15/16 02:00 AM
Posts: 326 Alberta
Wookie316
Alberta
Engine build details here. https://board.moparts.org/ubbthreads/ubbt...tml#Post2057137http://amsengines.com Their new website is still under construction. I'm not 100% sure what their Dyno is but I know it is corrected.
[Re: Wookie316]
#2073772
05/15/16 11:18 AM
05/15/16 11:18 AM
Sport440
Canton, Ohio
Ok, yes I remember that very nice build. You have two great running engines. Might of been a little less confusing if you put the new track results in the matching engine build thread with its 750 hp numbers and such. But no biggie, I think its clarified now. What are you going to put this engine in? You may of already hinted, but cant remember. Im jealous here, You have two very nice built engines and a beautiful mean ask looking car. ![up up](/ubbthreads/images/graemlins/custom/thumbs_up.gif)
[Re: Wookie316]
#2073774
05/15/16 11:32 AM
05/15/16 11:32 AM
Posts: 326 Alberta
Wookie316
Alberta
Currently I'm not exactly sure? Always looking around for the right project. Have a couple ideas though. Who knows, it may end up in the Charger yet later this year and I'll find a light weight car for 511 and really go fast! My big problem is my wife is a Ford fan, so another Mopar may not find its way into my garage anytime soon. Now...... Will a 440 fit in a fox body? Hmmmm. LOL.
[Re: fast68plymouth]
#2073800
05/15/16 12:40 PM
05/15/16 12:40 PM
Posts: 561 USA
B3RE
USA
Springs hold to 7000. Drops off bad at 7200 Fast rate cam, 1.6 rockers........ I'm going with valve float. When those things are "done", it's like flipping a switch. I don't know if you were measuring air flow, but if you were, you'd see it there if that's what it was. I have to agree. Although we may disagree on the cause, when the power suddenly drops, the valvetrain is unstable, and needs attention.
Mike Beachel
I didn't write the rules of math nor create the laws of physics, I am just bound by them.
[Re: Wookie316]
#2073815
05/15/16 01:04 PM
05/15/16 01:04 PM
Posts: 326 Alberta
Wookie316
Alberta
I'm just going on the dyno operators opinion. The vacuum gauge we had showed vacuum at 7000. Then as it went higher it was pressurizing they system. But with that said I don't disagree that those aggressive lobes can drop suddenly. Perhaps a combo of both?
