Thats called positive caster(and luck)... I was on the track
and came down from a normal wheel stand and the outer tie rod
heim broke.... at the time I didnt use high angular heims..
I was doing about 70 mph... drove great due to 10 degrees of
caster... a few guys on the starting line (fiends) told me they
couldnt watch figuring it was all over for me.. they said the left
tire was flipping back and forth... I pulled over to the wall
with no issue... I changed the heim for the eliminations but
bought the new joints
