Re: Place your bets, Dyno scheduled this Friday
[Re: Wookie316]
#2072773
05/13/16 05:58 PM
05/13/16 05:58 PM
Posts: 2,422 Pittsburgh PA
Eric
Pittsburgh PA
I'd try a Domi on mine...but off the stop i like the throttle response of the 4150. Mine's 1000cfm AED.
5.53 @ 125 1/8th on the launch control..more left in her!
[Re: Eric]
#2072799
05/13/16 06:36 PM
05/13/16 06:36 PM
Thumperdart
State of confusion
I'd try a Domi on mine...but off the stop i like the throttle response of the 4150. Mine's 1000cfm AED. Did you see/hear the throttle response on the 358 w/an 1150 I did? Stupid responsive..............Too many wives tales we need to squish about too many subjects w/LOTS of untested speculations......... ![beer beer](/ubbthreads/images/graemlins/custom/beer.gif)
[Re: Eric]
#2072806
05/13/16 06:43 PM
05/13/16 06:43 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I'd try a Domi on mine...but off the stop i like the throttle response of the 4150. Mine's 1000cfm AED. I dont know why you dont run a Dom on it Eric.. it would be just a change on the throttle stop but it would have more MPH which is what you guys like.... JMO ![wave wave](/ubbthreads/images/graemlins/custom/wave.gif)
[Re: MR_P_BODY]
#2072813
05/13/16 06:51 PM
05/13/16 06:51 PM
Posts: 1,169 Virginia Beach, VA
Old School
Virginia Beach, VA
I'm guessing 590hp.......
68 cuda formula S 588" bb 5sp 70 CUDA CONVERT 500" 5SP (SUBLIME) 70 CUDA CONVERT 500" 5SP (PLUMCRAZY):TOO MUCH HORSEPOWER, IS ALMOST ENOUGH!
[Re: Thumperdart]
#2072821
05/13/16 07:01 PM
05/13/16 07:01 PM
Posts: 2,154 Its a TRAP!
DARTH V8Я
Oh No!! I just had a moron attack!
Its a TRAP!
Too many wives tales we need to squish about too many subjects w/LOTS of untested speculations......... Calculated on a 408 solid roller, single plane at 927 to 1,180 cfm. So carb up until I get less than 1"Hg at max rpm? Or just get a 1050 Dominator & be done with it??
When it takes more than a sweet mullet to prove you rule at the trailer park..
[Re: DARTH V8Я]
#2072830
05/13/16 07:21 PM
05/13/16 07:21 PM
MR_P_BODY
Too many wives tales we need to squish about too many subjects w/LOTS of untested speculations......... Calculated on a 408 solid roller, single plane at 927 to 1,180 cfm. So carb up until I get less than 1"Hg at max rpm? Or just get a 1050 Dominator & be done with it?? I ran a 1050 on my 395ci it ran 9.56 in the 1/4.. every carb that I went larger was quicker and faster EDIT I started with a 750. 850, reworked 950 and the 1050.. on my 416 I went with EFI and that is a 1000 cfm with multi port.. when I dynoed that it was with a 850 and it was 560hp with some issues(pump gas engine)... went back later on the dyno and it made 590hp and 525 tq
[Re: MR_P_BODY]
#2072836
05/13/16 07:34 PM
05/13/16 07:34 PM
DARTH V8Я
Its a TRAP!
Too many wives tales we need to squish about too many subjects w/LOTS of untested speculations......... Calculated on a 408 solid roller, single plane at 927 to 1,180 cfm. So carb up until I get less than 1"Hg at max rpm? Or just get a 1050 Dominator & be done with it?? I ran a 1050 on my 395ci it ran 9.56 in the 1/4.. every carb that I went larger was quicker and faster EDIT I started with a 750. 850, reworked 950 and the 1050.. on my 416 I went with EFI and that is a 1000 cfm with multi port.. when I dynoed that it was with a 850 and it was 560hp with some issues(pump gas engine) To what extent does a single four become impractical? Is there a point on a small block when a Twin carb T-ram would be the better route?
[Re: Wookie316]
#2072853
05/13/16 08:07 PM
05/13/16 08:07 PM
Posts: 326 Alberta
Wookie316
Alberta
610/565 with 750. 630/580 with 950. More details later. Off to the races now.
1971 Plum Crazy Super Bee. 572 World Aluminum block with a Cope 727 & Dana 4.10 out back. 9.88 @ 138 with a 1.35 60 NA. Dialed back to 10.0’s. 4000 lbs with me in it.
[Re: Wookie316]
#2072859
05/13/16 08:19 PM
05/13/16 08:19 PM
DARTH V8Я
Its a TRAP!
Congrats. Think fast hit it with 630hp.. I guessed 637 lol.
[Re: DARTH V8Я]
#2072876
05/13/16 08:51 PM
05/13/16 08:51 PM
MR_P_BODY
To what extent does a single four become impractical? Is there a point on a small block when a Twin carb T-ram would be the better route? [/quote] I sold my 405ci W-9.. but on it I was gonna make a cam change and go with a pair of 1050s on a T-ram..I dont know when it becomes impractical but the T-ram was gonna be my next step.. and the cam was gonna be .160 more lift I already had the pair of 1050s.... this pic is my old 340
[Re: Wookie316]
#2072902
05/13/16 09:33 PM
05/13/16 09:33 PM
Posts: 14,515 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
610/565 with 750. 630/580 with 950. Nice....... Right where it should be.
[Re: Wookie316]
#2072906
05/13/16 09:45 PM
05/13/16 09:45 PM
Posts: 326 Alberta
Wookie316
Alberta
Springs hold to 7000. Obviously my local machine shop is a little rough with the bore though according to the vac readings. Drops off bad at 7200 and its still making power. Guess you get what you pay for. Torque plates work ![laugh laugh](/ubbthreads/images/graemlins/custom/laugh.gif) On another note, tech'd and waiting to race.
[Re: DARTH V8Я]
#2072908
05/13/16 09:45 PM
05/13/16 09:45 PM
Posts: 4,243 Charlotte, North Carolina
sgcuda
Congrats. Think fast hit it with 630hp.. I guessed 637 lol. Excuse me, but since the build was with the 750, I belive I got the right guess at 610, with Al right behind me with 611. I'll take what's behind door #1 please. ![boogie boogie](/ubbthreads/images/graemlins/custom/boogie.gif)
[image][/image]
[Re: Wookie316]
#2072918
05/13/16 09:58 PM
05/13/16 09:58 PM
MR_P_BODY
Springs hold to 7000. Obviously my local machine shop is a little rough with the bore though according to the vac readings. Drops off bad at 7200 and its still making power. Guess you get what you pay for. Torque plates work ![laugh laugh](/ubbthreads/images/graemlins/custom/laugh.gif) On another note, tech'd and waiting to race. You might want to try a electric vac pump... if its dropping like that maybe the vac pump will help it.. it should EDIT Then you could turn it off when not racing
[Re: Wookie316]
#2072920
05/13/16 10:02 PM
05/13/16 10:02 PM
Posts: 326 Alberta
Wookie316
Alberta
Yes. They said pan evac Not good enough. What's the best vac pump to buy? Where do they fit if your running a p/s pump for the hydra steer?
[Re: Wookie316]
#2072991
05/13/16 11:49 PM
05/13/16 11:49 PM
fast68plymouth
So. Burlington, Vt.
Springs hold to 7000. Drops off bad at 7200 Fast rate cam, 1.6 rockers........ I'm going with valve float. When those things are "done", it's like flipping a switch. I don't know if you were measuring air flow, but if you were, you'd see it there if that's what it was.
[Re: Wookie316]
#2073009
05/14/16 12:42 AM
05/14/16 12:42 AM
Posts: 326 Alberta
Wookie316
Alberta
10.98 @ 123 1.54 60. Not bad for a 4000lbs tank. More in it yet though.
