Re: Fast leaf spring guys inside
[Re: WHITEDART]
#2074179
05/15/16 10:23 PM
05/15/16 10:23 PM
Posts: 3,696 jersey
Spaceman Spiff
jersey
$1,000 on the Nova, because you'll spin.
526 cubes of angry wedge, pushbutton shifted, 9 passenger killer!
[Re: WHITEDART]
#2074197
05/15/16 10:45 PM
05/15/16 10:45 PM
Posts: 3,036 bean town ....Ca
WHITEDART
bean town ....Ca
2 dominators fiberglass fenders fiberglass doors lexan windows. Leaf spring
In the 8s N/A.with Brett miller W8's 5.07 at 133 at 2700lb
[Re: 340_Dart]
#2074218
05/15/16 11:17 PM
05/15/16 11:17 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Dumb question... Probably not related the the OP's post, but does the location of the front spring eyelet, on other words angle of the front leaf segment to the ground or chassis, have an affect on axle rotation with a cal trac?
I'm know with a ladder bar car lowering the front heim into a lower adjustment hole Softens the hit on the tire, and vise versa, raising the heim attachment makes it more violent on the tire Yes it makes a difference if the spring eye is higher or lower.. that is the IC.. on a leaf you cant cant the IC length(unless you change the length of the spring)but you can change the height... just like a ladder bar... but it can change if the spring is rapping up
[Re: WHITEDART]
#2074227
05/15/16 11:31 PM
05/15/16 11:31 PM
Posts: 6,890 North Alabama
Monte_Smith
North Alabama
Everyones common response when you are not saying what they want to hear............"well what do you have, or come show me".
HOW to FIX the car has been covered in depth, by more than just me. We are ALL telling you the same thing, but you refuse to listen........ Aside from the spring issue, the car does NOT need wheelie bars. If it is riding the bumper and crushing pans, it's not set up right. We got guys going 3.90s on radials, not crushing oil pans with no bars, don't see why yours needs them. Last time you brought that up, I told you it needed more front percentage, better shocks and learn how to use them. You didn't listen to that either. You put bars on it and now have another issue, because of trying to "crutch" the first issue
But yes, you are 100% correct. I do NOT currently have N/A, leafspring, smallblock, small tire car. So I am in no way shape or form qualified to give suggestions on how to make one work............I'm out
[Re: MR_P_BODY]
#2074242
05/15/16 11:48 PM
05/15/16 11:48 PM
WHITEDART
bean town ....Ca
I have posted Time Slips before 1.24 is the best so far many 1.25 then I relocated the shocks and added wheelie bars and got lost.. the guys that I run against Run there Wheeled bars 16 to 18 inches high. Not possible with the long trunk of the Dodge Dart I'm at 13 inches Max I even had to cut the back bumper. I'm going to pick up a stiffer front segment and replace the front and rear at the same time.. also shorten the wheelie bars. I'm not sure about getting rid of the lowering blocks just yet I run the flattest leaf spring the Calvert sales already.. the lower I get the car the better mph seems to get.. if I cut the frame rail and move the slider up into the frame. I'll be able to get rid of some lowering blocks... I'm currently making some changes that could possibly take some of the hit at the starting line away.. and I appreciate everybody's input positive and negative...
[Re: Monte_Smith]
#2074245
05/15/16 11:54 PM
05/15/16 11:54 PM
Posts: 4,457 Washington
madscientist
Washington
But yes, you are 100% correct. I do NOT currently have N/A, leafspring, smallblock, small tire car. So I am in no way shape or form qualified to give suggestions on how to make one work............I'm out Did he post his f/r percentages? If so I can't find them. I know many want all the weight on the rear they can get but you can make a bunch of grief going to much. There is a reason why pro cars are built under minimum weight and made to move weight around 25 pounds from rear to front is a big move. Best of luck to the OP. Sounds like a monkey see monkey do guy. All his buddies have wheelie bars.
[Re: WHITEDART]
#2074496
05/16/16 01:34 PM
05/16/16 01:34 PM
Posts: 19,395 Las Vegas
Al_Alguire
Las Vegas
AS to the NA question. The ONLY way these cars go fast is hit them with everything from the get go. Thought I covered this but maybe not. NA cars do not respond well from having timing pulled, pulling timing is a badaid for bad set up or poor track. NA cars do not have the luxury of ramping in hundreds of horsepower and pouring the coals to it.
Or are you telling me that the car pictured is hitting it with everything he has right from the hit? Or is his system on a controller or timer to allow the car to get moving first before pouring the power to it. This is something an NA car simply cannot do. Been doing the NA stuff for a long time and there are occasions when we have to pull timing due to poor track conditions and it simply kills the 60' and 330 numbers. Well that aint gonna make for a fast pass at all.
As for weight bias. A lot of guys are hung up on that 50/50 number. Great for a stocker or bracket car but once you start running fast that is exactly the wrong thing 99% of the time. On a leaf sprung fairly fast it woud definitely be the wrong way to go. We have worked very hard to get to 56/44 and it has made a world of difference getting the car much happier and less violent
[Re: WHITEDART]
#2074502
05/16/16 01:56 PM
05/16/16 01:56 PM
Posts: 3,978 Hilltown Pa
1967dartgt
Hilltown Pa
Well I will tell you the fast guys are going 4.30s with there turbo cars this year in x275. Ron is going 1.04 60fts and only in the 4.40s in a heads up class that he has won many championships and ducks race in Georgia this February. So I don't think he is holding any thing back and is hitting it with all it will take and not spin. It's a sb nitrous car it is down on HP in this class compaired to bb nitrous cars and the turbo cars so he needs to out 60ft and 330 them to win. A top x275 turbo car goes 165 he only can get 155 out of his combo so he can't hold back and pour the coals to it as you guys like to say.
Brett Miller W9 cnc'd heads STR Chassis fabraction
[Re: WHITEDART]
#2074518
05/16/16 02:18 PM
05/16/16 02:18 PM
Al_Alguire
Las Vegas
Then I guess I am wrong....From my experience he is the exception not the rule.
[Re: WHITEDART]
#2074537
05/16/16 02:45 PM
05/16/16 02:45 PM
1967dartgt
Hilltown Pa
Besides we are talking caltrac set up not grid programming. Don't see a difference in your suspension set up being na.
[Re: WHITEDART]
#2074557
05/16/16 03:32 PM
05/16/16 03:32 PM
Posts: 31,105 Oregon
AndyF
Im looking for pointers what have you guys done to get your 60ft down. I'm running caltracs and A body mono leaf ,,,sliders. I'm going to try a stiffer rear segment spring to hopefully eliminate some of the rear end rotation..is it possible to get a sub-1.20 60 foot in N/A out of this setup If it was me I'd just hook up a go pro and shoot some suspension video. Send it to the boys at Calvert and get a pro opinion. If you have the money and you really want to hook the car up then set up a data system. Shouldn't be hard to mount up some motion sensors on the shocks as well as wheel speed, driveshat speed sensors. Basically you have 10 pages of arguments here since you don't have any data. If you had the data then you could just tune the car and you wouldn't need 10 pages of opinions.
[Re: AndyF]
#2074563
05/16/16 03:44 PM
05/16/16 03:44 PM
Monte_Smith
North Alabama
Im looking for pointers what have you guys done to get your 60ft down. I'm running caltracs and A body mono leaf ,,,sliders. I'm going to try a stiffer rear segment spring to hopefully eliminate some of the rear end rotation..is it possible to get a sub-1.20 60 foot in N/A out of this setup If it was me I'd just hook up a go pro and shoot some suspension video. Send it to the boys at Calvert and get a pro opinion. If you have the money and you really want to hook the car up then set up a data system. Shouldn't be hard to mount up some motion sensors on the shocks as well as wheel speed, driveshat speed sensors. Basically you have 10 pages of arguments here since you don't have any data. If you had the data then you could just tune the car and you wouldn't need 10 pages of opinions. There is SOME video data. He runs the bars as high as he can, when he drops the button, they slam the track. The housing is rolling badly. NOTHING matters until you fix THAT
[Re: Monte_Smith]
#2074577
05/16/16 04:07 PM
05/16/16 04:07 PM
WHITEDART
bean town ....Ca
I'm hoping that a stiffer front and rear segments helps in this matter. Everybody wants to throw rocks and that's fine.. but I listen to all you guys and I learn again I don't want this to be a rock throwing match I was hoping that this would be some good leaf spring information for others... as well as myself
