Re: Fast leaf spring guys inside.pic added
[Re: 1967dartgt]
#2069746
05/08/16 11:45 PM
05/08/16 11:45 PM
Posts: 3,036 bean town ....Ca
WHITEDART
bean town ....Ca
Front segment goes solid when caltracs bar rotates. Your shocks control how much it separates. I think you need better rear shocks. I would say normally you would be right but this pic if you look closely the rear end has less than a half inch separation..the wheelie bars rotated down 9 inches plus.... and you can see the back of the leaf spring twisted out of the bottom of the car... this is not a progressive setup I'm trying to hit it with all the horsepower at the hit..I was told..that this is a common problem for A body Mopar the long rear segment .. we tried to put a GoPro. Down there but it snapped the bracket at lanch ...also I run two inches of lowering block. Which is probably helping to leverage the spring
In the 8s N/A.with Brett miller W8's 5.07 at 133 at 2700lb
[Re: WHITEDART]
#2069754
05/08/16 11:51 PM
05/08/16 11:51 PM
Posts: 5,486 SoCal
Brian Hafliger
SoCal
You might try 1" block instead of 2"...
Brian Hafliger
[Re: WHITEDART]
#2069757
05/08/16 11:53 PM
05/08/16 11:53 PM
Posts: 3,978 Hilltown Pa
1967dartgt
Hilltown Pa
But it is still rotating your housing causing your shock to separate. Where and how are your rear shocks mounted.
Brett Miller W9 cnc'd heads STR Chassis fabraction
[Re: 1967dartgt]
#2069765
05/08/16 11:56 PM
05/08/16 11:56 PM
Posts: 5,207 Menomonee Falls
DemonDust
Menomonee Falls
But it is still rotating your housing causing your shock to separate. Where and how are your rear shocks mounted. I agree, if you tighten up the extension it will be harder for the pinion to roll up. If you can't get it any tighter you need better shocks.
[Re: 1967dartgt]
#2069766
05/08/16 11:56 PM
05/08/16 11:56 PM
WHITEDART
bean town ....Ca
The shocks have been relocated they're straight up and down
[Re: WHITEDART]
#2069768
05/08/16 11:59 PM
05/08/16 11:59 PM
1967dartgt
Hilltown Pa
Are you full tight on your extension?
[Re: 1967dartgt]
#2069771
05/09/16 12:03 AM
05/09/16 12:03 AM
WHITEDART
bean town ....Ca
I have been running 2 or 3 on extension and 10 or 12 on compression.. if I go too aggressive an extension the car will not plant the tire.. the car will not even move 3 inches before blowing the tire off
[Re: WHITEDART]
#2069778
05/09/16 12:13 AM
05/09/16 12:13 AM
1967dartgt
Hilltown Pa
What hole on caltrac do you use? Why so loose on compression? What does it do if that's tighter?
[Re: 1967dartgt]
#2069790
05/09/16 12:29 AM
05/09/16 12:29 AM
WHITEDART
bean town ....Ca
Leafs in lower hole .and caltracs bars in Lower hole.. if I tighten extension past 5 with these shocks the car will not move forward it will instantly blow the tire off
[Re: WHITEDART]
#2069797
05/09/16 12:37 AM
05/09/16 12:37 AM
1967dartgt
Hilltown Pa
I would try going to your upper hole and tighter on the extension and compression. All adjustments on shocks are made from full tight, so if I were to say 6 and 12 they would be clicks from for tight. Brett's are going to be run at 2/4 when he brings out the new motor.
[Re: WHITEDART]
#2069799
05/09/16 12:39 AM
05/09/16 12:39 AM
1967dartgt
Hilltown Pa
You watch a Rod Rhoads pass on you tube,you will see how little his rear moves on launch.
[Re: 1967dartgt]
#2069825
05/09/16 01:12 AM
05/09/16 01:12 AM
WHITEDART
bean town ....Ca
You watch a Rod Rhoads pass on you tube,you will see how little his rear moves on launch. just to be clear Ron Rhodes Johnnie Coleman Al Jimenez, do not run standard caltracs Springs .
[Re: WHITEDART]
#2069828
05/09/16 01:15 AM
05/09/16 01:15 AM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
Ron Rhoads front segment is much longer and probably set as low as possible.
Despite all the guys saying springs just hold a car up, a stiffer spring will increase leverage and might be just what you need to do. But, with you not being able to set rebound stiffer, it might create another problem
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
[Re: WHITEDART]
#2069855
05/09/16 01:59 AM
05/09/16 01:59 AM
Posts: 6,890 North Alabama
Monte_Smith
North Alabama
Couple things...........if you have lowering blocks now, you either have the wrong spring, or them mounted wrong. If the car sits too high without blocks, do something else, because blocks are BAD. Two, a stiffer rear segment won't do dick to solve your problem. The bars are welded to the housing. If they rotate and hit, it's because the front segment is letting the housing wind up. The front segment is too flimsy and or bars are not adjusted right. The purpose of a cal-track or similar device is to stiffen the front segment. The rear segment does NOTHING, but hold the car up.
We have a Nova we run that doesn't even have a rear segment. We use the front half of the spring only, with coilovers. I have it so stiff, it's like a mini ladder bar
[Re: sixpackgut]
#2069893
05/09/16 04:33 AM
05/09/16 04:33 AM
Posts: 6,150 Melbourne , Australia
LA360
Ron Rhoads front segment is much longer and probably set as low as possible. It would be 24" or 25" (S10) as apposed to 20" for A Body Mopars I'm not an expert, but I'd say your shocks aren't valved correctly.
Alan Jones
[Re: MR_P_BODY]
#2069969
05/09/16 11:04 AM
05/09/16 11:04 AM
WHITEDART
bean town ....Ca
Someone mentioned Ron Roads so I figured I'd post a picture of the bottom of his car I believe this device is used for controlling rotation Maybe but I'm not a hundred percent sure
[Re: v cummins]
#2069973
05/09/16 11:09 AM
05/09/16 11:09 AM
WHITEDART
bean town ....Ca
Also this is an image of a heavier leaf spring. If you notice it's about an inch thick I'll keep you guys informed on how this works.for me
[Re: WHITEDART]
#2070004
05/09/16 11:55 AM
05/09/16 11:55 AM
Posts: 625 Indianapolis In. usa
Quickrunner
Someone mentioned Ron Roads so I figured I'd post a picture of the bottom of his car I believe this device is used for controlling rotation Maybe but I'm not a hundred percent sure In this pic that is a wishbone, its used to control housing left to right movement, basically keep it centered in the chassis. He also has a anti-roll bar to control body roll. And Smith bars instead of caltracks. Not real sure why the wishbone with leafs but it certainly would not hurt.
05 Ram 1500 Daytona package 71 Demon Gen3 hemi drag radial project
Missin' my 9 second 70 runner!
