ORIGINAL MOUNTING SCREWS FOR LOWER CORNER DASH PANELS E-BODY
#2068430
05/06/16 05:16 PM
05/06/16 05:16 PM
Posts: 1,558 Sweden
71redcuda
Sweden
Hi everyone,
Can anyone show me the correct original mounting screws for the left lower dash panel?
The bottom + the upper left screw..
Also want to see upper right screw on the right panel..
Im guessing its pan head screws but want to know if it is clear zinc or black zinc..
Thanks Nicklas
Re: ORIGINAL MOUNTING SCREWS FOR LOWER CORNER DASH PANELS E-BODY
[Re: 71redcuda]
#2068523
05/06/16 09:29 PM
05/06/16 09:29 PM
Posts: 2,963 Wisconsin
Stewpar
Wisconsin
If I don't get to them tonight, I will take pics in the morning........
Admiration For Multiple Carburetor Vehicles...
[Re: Stewpar]
#2068700
05/07/16 03:04 AM
05/07/16 03:04 AM
Posts: 1,558 Sweden
71redcuda
Sweden
If I don't get to them tonight, I will take pics in the morning........ Alright! Appreciate that.
[Re: 71redcuda]
#2068771
05/07/16 10:26 AM
05/07/16 10:26 AM
Stewpar
Wisconsin
Here you go! Your catching me at the right time as I am putting my dash together!
[Re: 71redcuda]
#2068791
05/07/16 11:10 AM
05/07/16 11:10 AM
Posts: 1,558 Sweden
71redcuda
Sweden
Perfect, thanks!
Im guessing the 2 screws at the top in your picture is the lower panel screws.. and the other one is the upper?
Thanks Nicklas
[Re: 71redcuda]
#2068889
05/07/16 03:10 PM
05/07/16 03:10 PM
Posts: 1,087 Long Island, NY
70plymA34
Long Island, NY
When i pulled my dash apart on my 70 LA built cuda all the trim screws that fastened that plastic bezel to the dash frame were black zinc versions of the bottom oval head type screw shown in that picture. If i remember correctly there is another hole on the side that faces the A pillar that was fastened with a oval head type stainless screw as well.
There are also two zinc coated screws that hold it from behind the dash frame as well that are not visible from the front of the bezel. I believe all exposed screws on this one are all black zinc with the exception of one stainless on the A pillar side. I hope this helps but as always there is variation found in everything Mopar
Super Commando
