Dominator throttle with stock pedal, can't get WOT
#2068914
05/07/16 05:22 PM
05/07/16 05:22 PM
Posts: 5,207 Menomonee Falls
DemonDust
Menomonee Falls
So I have the jegs dual spring throttle bracket and a nice Lokar cable with the stock A body throttle pedal. Now I can adjust it and get WOT, but when you let off there isn't enough slack to return to the idle circuit. If I adjust so I have idle then I only get about 30% throttle. And that's not any fun. I thought about maybe putting the throttle stud in the rear hole that is open but at WOT that hole goes below the bracket. Any suggestions or ideas would be greatly appreciated. ![](http://i410.photobucket.com/albums/pp184/jkloth81/IMG_20160507_141758751_HDR.jpg)
Re: Dominator throttle with stock pedal, can't get WOT
[Re: DemonDust]
#2068917
05/07/16 05:33 PM
05/07/16 05:33 PM
Posts: 20,217 Park Forest, IL
slantzilla
Park Forest, IL
Is the lever on the pedal itself bent? Can you bend it so the pedal itself sits higher and has more travel?
Not a Dominator expert, didn't even stay at a Holiday Inn either.....
[Re: DemonDust]
#2068925
05/07/16 05:44 PM
05/07/16 05:44 PM
Posts: 52,972 Romeo MI
MR_P_BODY
For one thing.. move the return springs to the hole that you have the cable in... put the cable in the top hole.. then move the cable housing mount if needed ![wave wave](/ubbthreads/images/graemlins/custom/wave.gif)
[Re: DemonDust]
#2068941
05/07/16 06:27 PM
05/07/16 06:27 PM
fast68plymouth
So. Burlington, Vt.
If he puts the cable in the top hole it should take even more pedal travel to get wot.
[Re: fast68plymouth]
#2068943
05/07/16 06:30 PM
05/07/16 06:30 PM
MR_P_BODY
If he puts the cable in the top hole it should take even more pedal travel to get wot. This is true... BUT.. how do you pull up hill when it still needs to down farther.. I didnt have any problems using a stock pedal on my doms EDIT make sure the top of the pedal is against the fire wall... or add length to the top of the pedal to change the ratio
[Re: Leigh]
#2069006
05/07/16 08:39 PM
05/07/16 08:39 PM
Posts: 3,036 bean town ....Ca
WHITEDART
bean town ....Ca
The simple way is reach down and bend the pedal arm up away from the floor...this is what I do
In the 8s N/A.with Brett miller W8's 5.07 at 133 at 2700lb
[Re: DemonDust]
#2069031
05/07/16 09:56 PM
05/07/16 09:56 PM
Posts: 1,030 ohio
67mprfan
ohio
Here's mine any time I take it loose I always forget which hole to put it back in
71 demon stock stroke 440/indy ez-1 running 10.10 @ 132.14 mph in the 1/4 and 6.36 @ 107.46 mph in the 1/8 not in the same weekend but It did it then I sold it. 67 Belvedere that worked it's way in the 10's
[Re: WHITEDART]
#2069035
05/07/16 10:01 PM
05/07/16 10:01 PM
DemonDust
Menomonee Falls
The simple way is reach down and bend the pedal arm up away from the floor...this is what I do So you're bending the end that the pedal attaches to or the end the cable attaches to?
[Re: DemonDust]
#2069043
05/07/16 10:18 PM
05/07/16 10:18 PM
MR_P_BODY
I prefer to add to the top length of the pedal so I dont have a long distance of my foot.. this is just a ratio... from idle to wot measure that distance.. then on the top of the pedal arm at the hole measure that from the firewall.. that top part of the pedal has to travel the amount of the carb EDIT Or put a spacer behind the pedal to get more travel
[Re: MR_P_BODY]
#2069059
05/07/16 10:41 PM
05/07/16 10:41 PM
dartman366
Mt. Vernon, Ohio
The closer you have the cable to the centerline of the throttle shaft the quicker it works and uses the least amount of travel to get there, if the hole go's below the bracket try putting the cable mount on the bottom of the bracket.
[Re: DemonDust]
#2069100
05/08/16 12:14 AM
05/08/16 12:14 AM
Posts: 12,592 Great Neck,LI,new york
hemi-itis
I had a similar issue,broke 2 stock pedals before installing a lokar pedal.
