Page 2 of 3 1 2 3
Re: bearing clearance math [Re: mopar dave] #2066344
05/03/16 02:37 AM
05/03/16 02:37 AM
Mt Morris Michigan
mopar dave Offline OP
Mt Morris Michigan
ok, heres something interesting. I measured the rod bearing with the snap gauge again and measured snap gauge with mic, I then 0 bore gauge in the mic with that measure(I think 2.225) and then inserted bore gauge in rod bearing and bore gauge reads .0095 reading gauge clockwise. I then measure rod journal with mic and 0 bore gauge in mic and then insert bore gauge in rod bearing and bore gauge reads .0061. if you subtrack (.0095-.0061=.0034)you get .0034. can you do it that way?
I also tried 3 others dial indicators and get .004 with two of them and .0038 with the other reading to left of 0.
If I read the shars indicator from the left of 0 or counter clockwise I get .0039.
so now my question is would .0035"-.0039" be too much rod bearing clearance? sorry to confuse anyone here. Thanks guys
Re: bearing clearance math [Re: mopar dave] #2066380
05/03/16 09:14 AM
05/03/16 09:14 AM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
My head hurts. biggrin
Re: bearing clearance math [Re: mopar dave] #2066434
05/03/16 11:16 AM
05/03/16 11:16 AM
Its a TRAP!
DARTH V8Я Offline
Oh No!! I just had a moron attack!
DARTH V8Я  Offline
Its a TRAP!
Perfect if you running blown alcohol with 70wt oil. .0025" is plenty. Depending on what your building.
When it takes more than a sweet mullet to prove you rule at the trailer park..
Re: bearing clearance math [Re: justinp61] #2066444
05/03/16 11:34 AM
05/03/16 11:34 AM
Mt Morris Michigan
Mt Morris Michigan
LOL! I hear ya. I'm sick of it myself.
Re: bearing clearance math [Re: mopar dave] #2066513
05/03/16 02:20 PM
05/03/16 02:20 PM
Fulton County, PA
CMcAllister Online content
Mr. Helpful
CMcAllister  Online Content
Mr. Helpful
Fulton County, PA
Snap gages are not precise enough for this. Put them back in the box. Correctly measure the journal with a mic and lock it down. Use the mic to set up the dial bore gage. Use the anvil that will spin the indicator half a turn or a turn. Clamp the mic down or in a vice. Rock the dial bore gage in the mic to find the square spot and zero the indicator. Drop the dial bore gage into the bearing bore and rock it to find the square spot (smallest dimension making certain you're on the exact centerline of the bore). The distance from zero is the clearance. All measuring tools should have a .0001 resolution and cost more than $19.99. Don't trust your tools or yourself until you can go through the procedure 3 or 4 times and come up with the same number to the .0001th. No calculator or math needed.
Re: bearing clearance math [Re: mopar dave] #2066541
05/03/16 03:08 PM
05/03/16 03:08 PM
Mt Morris Michigan
Mt Morris Michigan
ok, enough confusion. I called the dial company(shars). they tell me if the needle is on the left side of the gauge while reading your clearance that you count counterclockwise from 0 and if needle is on right side of gauge you count clockwise. so at that I remeasured crank and being careful to not crank down on the mic with the clutch(just get the air gap out) I reset mic, re 0 bore gauge insert in rod bearing, read the left side of gauge I get .0033"-.0034". I think that's the most accurate I can get.
take a look at the pic of the gauge and you will understand.
rod bolts are tq 30ftlb and clocked 60* Thanks guys
Re: bearing clearance math [Re: CMcAllister] #2066553
05/03/16 03:21 PM
05/03/16 03:21 PM
Washington
madscientist Offline
Washington
No one said snap gauges are precise, but when the OP is questioning between .0026 and .026 then a snap gauge can help him find his way.
Sometimes you have to look at other options to get your numbers correct. No body said use a snap gauge to finalize bearing clearance. Damn.
Re: bearing clearance math [Re: mopar dave] #2066554
05/03/16 03:23 PM
05/03/16 03:23 PM
Washington
Washington
That is a bit loose for my taste. A .001 under bearing would be nice. Or, if the rods are on the high side, you can size them to the low side, or a bit under and get it to .0026-.0028ish.
Re: bearing clearance math [Re: mopar dave] #2066675
05/03/16 07:52 PM
05/03/16 07:52 PM
Monroe NC
Luvcars69 Offline
Luvcars69  Offline
Monroe NC
I think it's time to take it to your machinist so you really know what you have!
Maybe take your gave n if he's nice n has time he can school you how to read your gages
Making cars faster one at a time!
19 Challenger Scat Pack white
16 Ram Sport SB Regular cab black
14 Charger Pursuit silver
78 Magnum 400 gray
69 SuperBee 512 Passion 4-speed 4:10
Re: bearing clearance math [Re: Luvcars69] #2066693
05/03/16 08:20 PM
05/03/16 08:20 PM
Mt Morris Michigan
Mt Morris Michigan
i believe the measures. The bearings are +.001 bearings. Ill just have to get another set. Standard bearings would put clearance at .0025 zone. I ordered +.001 because all the other engines i put together had tight clearances.
Re: bearing clearance math [Re: mopar dave] #2066710
05/03/16 08:57 PM
05/03/16 08:57 PM
Let us know what clearances you find with the new bearings thumbs Is this a BB Chevy journal rod size? If so anything from .0020 to .0028 should work fine with non thick oil thumbstwocents
Re: bearing clearance math [Re: Cab_Burge] #2066723
05/03/16 09:17 PM
05/03/16 09:17 PM
Mt Morris Michigan
Mt Morris Michigan
ok. Be working in the basement. Do you think cold tools might show wide clearances.
Re: bearing clearance math [Re: mopar dave] #2066859
05/03/16 11:58 PM
05/03/16 11:58 PM
Washington
Washington
As long as everything is at ambient it should be ok.
I worked in a shop that had a huge roll up door on the east end. During the winter, when the wind was blowing, the office retards would open that door and in a minute you could start to see ambient temp starting to tighten up the bores while I was honing the blocks.
Keep everything the same temp.
Re: bearing clearance math [Re: madscientist] #2067192
05/04/16 03:08 PM
05/04/16 03:08 PM
Mt Morris Michigan
Mt Morris Michigan
paid a visit to my machinest today. I took two rods with me with bearings torqued up to spec using angle method.I set my mic to a journal, 0 bore gauge and measured rod bearing at .0033 before I left the house. He measured .0033 with his bore gauge 0 ing it in my mic. so I am reading the gauge correctly and my gauge is accurate enough IMO. something he showed me though was the bearings have taper in them. .0033 in middle and .0036 off to each side. said to get new bearings, should not have any taper. as far as the .0033 rod bearing clearance, he told me not to get caught up in .0001 of an inch measures. he would run that clearance with heavier oil if that's what he had. these are King bearings, thought they were suppose to be perfect accuracy?
Re: bearing clearance math [Re: mopar dave] #2067213
05/04/16 03:26 PM
05/04/16 03:26 PM
Washington
Washington
Vertical oil clearance is what matters, so the extra clearance won't hurt a thing. In fact, I'm not so sure even the best rods get out of round at higher RPM, regardless of bob weight.
I also disagree with running a heavy oil. There is ZERO reason to do it any more. Unless you are running alcohol or nitro. I'd get the right bearings and have the clearance .001 less and run a 30 grade oil.
Re: bearing clearance math [Re: madscientist] #2067223
05/04/16 03:44 PM
05/04/16 03:44 PM
Mt Morris Michigan
Mt Morris Michigan
all measures were vertical.
Re: bearing clearance math [Re: mopar dave] #2067433
05/04/16 09:37 PM
05/04/16 09:37 PM
I ran .0035+ rod and main bearing clearances on my old 518 pump gas stroker motor, it would idle at 18 to 25 lbs at 650 RPM with 5W20Wt oil at 180F + oil temps, 30 lbs at 1200 RPM, 65 lbs at 6500 RPM shruggy work
Your fine with .0035 clearnces on the rods thumbs twocents I had to use the King rod bearings on the B1 motor I built last year to get the clearances oI wanted,(.0025+ to .0030) every other brand was to tight work If your going to use a motor with 2.200 rod journal sizes and want to safely rev it up past 5500 RPM reguraly your way better off with .0030+ bearing clearances, no matter what weight oil, than having .0020 oil clearances up twocents
Re: bearing clearance math [Re: Cab_Burge] #2094218
06/19/16 12:21 AM
06/19/16 12:21 AM
Mt Morris Michigan
Mt Morris Michigan
ok, I now have the new King standard rod bearings and I torqued one up in a rod and measured. .002". its looking like I will need the other .001" larger bearings which measured .0033". better too loose than too tight.
Re: bearing clearance math [Re: mopar dave] #2094681
06/19/16 11:26 PM
06/19/16 11:26 PM
USA
B3RE Offline
B3RE  Offline
USA
Dave,
Use one std shell, and one +.001 shell, and you should be right around .0026". It's common practice.
Mike Beachel
I didn't write the rules of math nor create the laws of physics, I am just bound by them.
Re: bearing clearance math [Re: B3RE] #2094685
06/19/16 11:32 PM
06/19/16 11:32 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
Originally Posted By B3RE
Dave,
That's what I did on my mains.
Page 2 of 3 1 2 3
