Re: 440 Compression Test Results
[Re: ringo440]
#2066227
05/02/16 11:33 PM
05/02/16 11:33 PM
Posts: 1,526 North Carolina
cjskotni
North Carolina
Yeah that's pretty low. I healthy motor should be in the 130-140+ range...and fairly consistent between cylinders. Were all cylinders this low or just two? If it's two adjoining cylinders, it could be a blow head gasket. If it's pretty much all of them, new rings are probably needed. However if it just started smoking all the sudden, I would suspect a blown gasket or (hopefully not) cracked block. Check the oil and make sure it doesn't look like a milkshake indicating coolant is getting into the oil which is bad news for the rest of the motor. Good luck. ![thumbs thumbs](/ubbthreads/images/graemlins/custom/thumbs.gif)
[Re: ringo440]
#2066233
05/02/16 11:38 PM
05/02/16 11:38 PM
Posts: 21,855 Kirkland, Washington
Pacnorthcuda
Warm engine ,one plug at a time, good battery spins engine great, couple of shots of oil in cylinder only increase reading by 5 Oh man. One plug at a time? You need to do it over. Pull all plugs, open throttle and test. Remember to disable ignition!
[Re: ringo440]
#2066242
05/02/16 11:58 PM
05/02/16 11:58 PM
RapidRobert
and said it just started smoking out exhaust. smokes all the time or on decell or? If "just started" that makes me think valley pan tin gasket leaking
[Re: racerhog]
#2066267
05/03/16 12:22 AM
05/03/16 12:22 AM
Posts: 5,791 Hamilton, Ontario Canada
Magnum
Wrong stagger on the piston rings...... Numbers this low will not come up to acceptable with proper ring stagger. Smoke can come from a minor mark in a cylinder wall. For the same reasoning that a compression test is not a good tool. It's a quickie to tell if a motor is great or shot, like burnt valve shot. That engine needs a cylinder leak down tester with compressed air, 2 gauges and a regulator.
[Re: ringo440]
#2066268
05/03/16 12:23 AM
05/03/16 12:23 AM
Posts: 43,364 Bend,OR USA
Cab_Burge
[Re: ringo440]
#2066413
05/03/16 10:34 AM
05/03/16 10:34 AM
Posts: 5,169 CT
GTX MATT
CT
If it has 6 pack pistons in it that is an extremely low reading. What cam is in it?
[Re: racerhog]
#2066496
05/03/16 01:51 PM
05/03/16 01:51 PM
Posts: 2,154 Its a TRAP!
DARTH V8Я
Oh No!! I just had a moron attack!
Its a TRAP!
Wrong stagger on the piston rings...... Seen that b4. ![thumbs thumbs](/ubbthreads/images/graemlins/custom/thumbs.gif) Big cam, low compression ratio will give low readings across the board. Second thing is check with the same gauge on a known good motor. Gauges can be inaccurate. Seen plenty of motors in the 125 psi range with low compression ratios. The first thing I'd check is a poor fitting intake manifold. Dou Yep. My 8.x:1 440 with the MP 509 cam was pulling 110psi on all eight (cam was straight up).
When it takes more than a sweet mullet to prove you rule at the trailer park..
[Re: ringo440]
#2066524
05/03/16 02:32 PM
05/03/16 02:32 PM
RapidRobert
first we gotta fix the smoking. secondly improper breakin might have fubared the rings. You might read "breakin secrets" at www.mototuneusa.com for my take on that. As said I would do a leakdown. keep us updated
[Re: Jerry]
#2066543
05/03/16 03:10 PM
05/03/16 03:10 PM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
if the rings are shot, can he ball hone the cylinders and slap some new rings on and be good to go? or do we think we need to remachine the block? I don't see why not. I burned up #3 twice (cast pistons w/ 6psi of boost) all I did was pull the old unit out hit with quick hone and slap it back together. Do a leak down 1st. How do the plugs look?
[Re: Jerry]
#2066547
05/03/16 03:14 PM
05/03/16 03:14 PM
RapidRobert
I believe so with the correct grit on the ball hone. (I'd want file fit plasma moly rings and Brush Research Manufacturings' recommendation on the grit). You would wanna check taper/out of round & you'd sure think it'd be good with that few miles but I would square up a ring gap & use it to check out of round/taper at least on 1 cyl just to see where you are at or if the block is coming out then have your shop use a dial bore gauge for a spot on check
[Re: ringo440]
#2066577
05/03/16 03:54 PM
05/03/16 03:54 PM
Posts: 5,169 CT
GTX MATT
CT
I don't think its rings or it'd have come up more than 5 PSI with oil. 95 PSI is LOW no matter how you cut it.
How does the engine run and what cam is in it? I'd suspect that the pushrods are too long or lash adjusted wrong if it has adjustable rockers. OR it doesn't have six pack slugs in it.
Are you sure the gauge is good?
