Re: bearing clearance math
[Re: mopar dave]
#2066434
05/03/16 10:16 AM
05/03/16 10:16 AM
Posts: 2,154 Its a TRAP!
DARTH V8Я
Oh No!! I just had a moron attack!
Its a TRAP!
= so now my question is would .0035"-.0039" be too much rod bearing clearance Perfect if you running blown alcohol with 70wt oil. .0025" is plenty. Depending on what your building.
When it takes more than a sweet mullet to prove you rule at the trailer park..
[Re: mopar dave]
#2066513
05/03/16 01:20 PM
05/03/16 01:20 PM
Posts: 12,598 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Snap gages are not precise enough for this. Put them back in the box. Correctly measure the journal with a mic and lock it down. Use the mic to set up the dial bore gage. Use the anvil that will spin the indicator half a turn or a turn. Clamp the mic down or in a vice. Rock the dial bore gage in the mic to find the square spot and zero the indicator. Drop the dial bore gage into the bearing bore and rock it to find the square spot (smallest dimension making certain you're on the exact centerline of the bore). The distance from zero is the clearance. All measuring tools should have a .0001 resolution and cost more than $19.99. Don't trust your tools or yourself until you can go through the procedure 3 or 4 times and come up with the same number to the .0001th. No calculator or math needed.
[Re: CMcAllister]
#2066553
05/03/16 02:21 PM
05/03/16 02:21 PM
Posts: 4,457 Washington
madscientist
Washington
Snap gages are not precise enough for this. Put them back in the box. Correctly measure the journal with a mic and lock it down. Use the mic to set up the dial bore gage. Use the anvil that will spin the indicator half a turn or a turn. Clamp the mic down or in a vice. Rock the dial bore gage in the mic to find the square spot and zero the indicator. Drop the dial bore gage into the bearing bore and rock it to find the square spot (smallest dimension making certain you're on the exact centerline of the bore). The distance from zero is the clearance. All measuring tools should have a .0001 resolution and cost more than $19.99. Don't trust your tools or yourself until you can go through the procedure 3 or 4 times and come up with the same number to the .0001th. No calculator or math needed. No one said snap gauges are precise, but when the OP is questioning between .0026 and .026 then a snap gauge can help him find his way. Sometimes you have to look at other options to get your numbers correct. No body said use a snap gauge to finalize bearing clearance. Damn.
[Re: mopar dave]
#2066554
05/03/16 02:23 PM
05/03/16 02:23 PM
madscientist
Washington
ok, enough confusion. I called the dial company(shars). they tell me if the needle is on the left side of the gauge while reading your clearance that you count counterclockwise from 0 and if needle is on right side of gauge you count clockwise. so at that I remeasured crank and being careful to not crank down on the mic with the clutch(just get the air gap out) I reset mic, re 0 bore gauge insert in rod bearing, read the left side of gauge I get .0033"-.0034". I think that's the most accurate I can get. take a look at the pic of the gauge and you will understand. rod bolts are tq 30ftlb and clocked 60* Thanks guys That is a bit loose for my taste. A .001 under bearing would be nice. Or, if the rods are on the high side, you can size them to the low side, or a bit under and get it to .0026-.0028ish.
[Re: mopar dave]
#2066675
05/03/16 06:52 PM
05/03/16 06:52 PM
Posts: 641 Monroe NC
Luvcars69
Monroe NC
I think it's time to take it to your machinist so you really know what you have! Maybe take your gave n if he's nice n has time he can school you how to read your gages
Making cars faster one at a time!
19 Challenger Scat Pack white 16 Ram Sport SB Regular cab black 14 Charger Pursuit silver 78 Magnum 400 gray 69 SuperBee 512 Passion 4-speed 4:10
[Re: mopar dave]
#2066859
05/03/16 10:58 PM
05/03/16 10:58 PM
madscientist
Washington
ok. Be working in the basement. Do you think cold tools might show wide clearances. As long as everything is at ambient it should be ok. I worked in a shop that had a huge roll up door on the east end. During the winter, when the wind was blowing, the office retards would open that door and in a minute you could start to see ambient temp starting to tighten up the bores while I was honing the blocks. Keep everything the same temp.
[Re: mopar dave]
#2067213
05/04/16 02:26 PM
05/04/16 02:26 PM
madscientist
Washington
paid a visit to my machinest today. I took two rods with me with bearings torqued up to spec using angle method.I set my mic to a journal, 0 bore gauge and measured rod bearing at .0033 before I left the house. He measured .0033 with his bore gauge 0 ing it in my mic. so I am reading the gauge correctly and my gauge is accurate enough IMO. something he showed me though was the bearings have taper in them. .0033 in middle and .0036 off to each side. said to get new bearings, should not have any taper. as far as the .0033 rod bearing clearance, he told me not to get caught up in .0001 of an inch measures. he would run that clearance with heavier oil if that's what he had. these are King bearings, thought they were suppose to be perfect accuracy? Vertical oil clearance is what matters, so the extra clearance won't hurt a thing. In fact, I'm not so sure even the best rods get out of round at higher RPM, regardless of bob weight. I also disagree with running a heavy oil. There is ZERO reason to do it any more. Unless you are running alcohol or nitro. I'd get the right bearings and have the clearance .001 less and run a 30 grade oil.
[Re: mopar dave]
#2067433
05/04/16 08:37 PM
05/04/16 08:37 PM
Posts: 43,913 Bend,OR USA
Cab_Burge
[Re: mopar dave]
#2094681
06/19/16 10:26 PM
06/19/16 10:26 PM
Posts: 561 USA
B3RE
USA
Dave, Use one std shell, and one +.001 shell, and you should be right around .0026". It's common practice.
Mike Beachel
I didn't write the rules of math nor create the laws of physics, I am just bound by them.
[Re: B3RE]
#2094685
06/19/16 10:32 PM
06/19/16 10:32 PM
Posts: 11,704 W. Kentucky
justinp61
W. Kentucky
Dave, Use one std shell, and one +.001 shell, and you should be right around .0026". It's common practice. That's what I did on my mains.
