Re: Power Nation/Engine Power 512?
[Re: 451Mopar]
#2065611
05/01/16 11:50 PM
05/01/16 11:50 PM
Posts: 89 Cedar Rapids, IA
69Mcode440
Cedar Rapids, IA
The rockers were 1.6 ratio.
Mike 69 440 Cuda 71 Dart drag car 70 Duster drag car Best et 9.32, 145.9 mph 2019 Ram 2500 4x4
[Re: 451Mopar]
#2065857
05/02/16 01:01 PM
05/02/16 01:01 PM
Posts: 14,531 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
For the lifts they're saying you'd need lobes that are .400/.420. I don't show any hyd roller lobes from them that are .420 lift, but my lobe catalog is a couple of years old.
For that type of motor, with decent exhaust ports and headers, where you're only planning on turning it 6k......... it didn't need a 112lsa, or being installed straight up, or 10deg of split. I thought the TQ seemed kinda low....... I had forgotten they put the cam in at 112. With the low-ish range they were testing the motor, it's likely one of those situations where if you start higher(TQ output), you end higher. I think the cam on a 110, in at 106..... With less split, would have made more power within that operating range. It's just speculation...... We'll never know.
[Re: 451Mopar]
#2082280
05/29/16 12:54 PM
05/29/16 12:54 PM
Posts: 12,802 Benton, IL.
DaveRS23
Master of nothing...
Benton, IL.
I didn't catch the size of the carb they dropped on. Did I miss it?
And if that 4150 beat the EFI, then the advertisers certainly don't want a Dominator on their "512".
Master, again and still
[Re: DaveRS23]
#2082294
05/29/16 01:31 PM
05/29/16 01:31 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Being the injection is a self learning..it will take more than a couple of minutes...plus on my injection.. it doesnt start to learn until its above 160*... what water temp were they running.. if it was 160* or below(like some dynos like to run for the big numbers) it would never learn... plus the injection will try to drive it to stoichiometric vs a richer point for power..unless you change the program on the upper end
[Re: 451Mopar]
#2082793
05/30/16 01:24 PM
05/30/16 01:24 PM
fast68plymouth
So. Burlington, Vt.
I talked with someone who tested 500" (4.380 x 4.15) with the TF heads last week. 256/262-112 solid cam, .567/.585 w-1.5 rockers, 6bbl, 2" tti headers, 11:1. I had told him it should make 645tq/625hp, made 649tq/628hp. I would think with the TF intake and a big 4150 carb, maybe some sort of spacer, it would make another 25hp or so.
[Re: fast68plymouth]
#2082796
05/30/16 01:27 PM
05/30/16 01:27 PM
Thumperdart
State of confusion
I talked with someone who tested 500" (4.380 x 4.15) with the TF heads last week. 256/262-112 solid cam, .567/.585 w-1.5 rockers, 6bbl, 2" tti headers, 11:1. I had told him it should make 645tq/625hp, made 649tq/628hp. I would think with the TF intake and a big 4150 carb, maybe some sort of spacer, it would make another 25hp or so. And MORE w/a 1050 dommy...............
