Re: Power Nation/Engine Power 512? [Re: 451Mopar] #2065611
05/01/16 11:50 PM
05/01/16 11:50 PM
Cedar Rapids, IA
69Mcode440 Offline
69Mcode440  Offline
Cedar Rapids, IA
The rockers were 1.6 ratio.
Mike
69 440 Cuda
71 Dart drag car
70 Duster drag car Best et 9.32, 145.9 mph
2019 Ram 2500 4x4
Re: Power Nation/Engine Power 512? [Re: 451Mopar] #2065857
05/02/16 01:01 PM
05/02/16 01:01 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
For the lifts they're saying you'd need lobes that are .400/.420.
I don't show any hyd roller lobes from them that are .420 lift, but my lobe catalog is a couple of years old.
For that type of motor, with decent exhaust ports and headers, where you're only planning on turning it 6k......... it didn't need a 112lsa, or being installed straight up, or 10deg of split.
I thought the TQ seemed kinda low....... I had forgotten they put the cam in at 112.
With the low-ish range they were testing the motor, it's likely one of those situations where if you start higher(TQ output), you end higher.
I think the cam on a 110, in at 106..... With less split, would have made more power within that operating range. It's just speculation...... We'll never know.
Re: Power Nation/Engine Power 512? [Re: 451Mopar] #2082250
05/29/16 12:15 PM
05/29/16 12:15 PM
Mo.
racerx Offline
racerx  Offline
Mo.
It is just an advertising tool for the manufacturers
^^^well that little advertising doesn't look good for fitech^^^
Re: Power Nation/Engine Power 512? [Re: 451Mopar] #2082280
05/29/16 12:54 PM
05/29/16 12:54 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
I didn't catch the size of the carb they dropped on. Did I miss it?
And if that 4150 beat the EFI, then the advertisers certainly don't want a Dominator on their "512".
Master, again and still
Re: Power Nation/Engine Power 512? [Re: DaveRS23] #2082294
05/29/16 01:31 PM
05/29/16 01:31 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Being the injection is a self learning..it will
take more than a couple of minutes...plus on my
injection.. it doesnt start to learn until its
above 160*... what water temp were they running..
if it was 160* or below(like some dynos like to run
for the big numbers) it would never learn... plus
the injection will try to drive it to stoichiometric
vs a richer point for power..unless you change the
program on the upper end
wave
Re: Power Nation/Engine Power 512? [Re: 451Mopar] #2082459
05/29/16 07:54 PM
05/29/16 07:54 PM
Mo.
racerx Offline
racerx  Offline
Mo.
I could be wrong but, thought they said it was a 950cfm carb.
Re: Power Nation/Engine Power 512? [Re: 451Mopar] #2082793
05/30/16 01:24 PM
05/30/16 01:24 PM
So. Burlington, Vt.
So. Burlington, Vt.
I talked with someone who tested 500" (4.380 x 4.15) with the TF heads last week.
256/262-112 solid cam, .567/.585 w-1.5 rockers, 6bbl, 2" tti headers, 11:1.
I had told him it should make 645tq/625hp, made 649tq/628hp.
I would think with the TF intake and a big 4150 carb, maybe some sort of spacer, it would make another 25hp or so.
Re: Power Nation/Engine Power 512? [Re: fast68plymouth] #2082796
05/30/16 01:27 PM
05/30/16 01:27 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
And MORE w/a 1050 dommy...............
