Re: Billet valve covers
[Re: boatracer572]
#2063757
04/29/16 01:16 AM
04/29/16 01:16 AM
Posts: 31,105 Oregon
AndyF
looks really good,you get what you pay for!! Thanks. I designed them with a 1/2 thick rail so they will seal up nice and tight. I put a #12 AN o-ring fitting on one side for the vacuum regulator but left the other side solid to eliminate leaks.
[Re: AndyF]
#2063776
04/29/16 01:41 AM
04/29/16 01:41 AM
Posts: 1,049 San Jose Ca.
boatracer572
San Jose Ca.
So do tell what would a set for a Predator deal run one I don't have any info on the Predator heads so I wouldn't have any way to design a set of valve covers for them. Indy should have the CNC data on the heads so they should be able to design a set of valve covers without much work. If I had the CAD file for the valve cover rail then it only takes an hour or so to design the cover. I could get you that, if your interested in taking on the project.....
[Re: AndyF]
#2063918
04/29/16 12:07 PM
04/29/16 12:07 PM
Posts: 2,813 Blue Ridge, VA
Plumb Wired
Blue Ridge, VA
Not to hijack this thread but there are billet W8 and B1 covers coming within the next few weeks. Stay tuned for more info.
Mike Gray
RIP Monte Smith
aka: OutlawFish '98 Bickel Dodge Dakota PST
[Re: boatracer572]
#2063931
04/29/16 12:22 PM
04/29/16 12:22 PM
AndyF
So do tell what would a set for a Predator deal run one I don't have any info on the Predator heads so I wouldn't have any way to design a set of valve covers for them. Indy should have the CNC data on the heads so they should be able to design a set of valve covers without much work. If I had the CAD file for the valve cover rail then it only takes an hour or so to design the cover. I could get you that, if your interested in taking on the project..... I could do the project but it would probably be a lot cheaper if you worked with someone like Ultra Pro who has better equipment than me. http://www.ultrapromachining.net Ultra Pro can build put a valve spring oiler system into the rail of the valve cover and do some other tricks like that which I'm not set up to do.
[Re: AndyF]
#2064047
04/29/16 03:11 PM
04/29/16 03:11 PM
Posts: 1,841 NW Indiana
fbs63
NW Indiana
Do they have clearance on the pushrod side for T&D or Jesel rockers?
[Re: AndyF]
#2064195
04/29/16 07:42 PM
04/29/16 07:42 PM
Posts: 2,154 Its a TRAP!
DARTH V8Я
Oh No!! I just had a moron attack!
Its a TRAP!
First off, very nice valve covers! But I have to ask cause my knowledge is lacking in this area, what's the difference between your $650 units and other very similar billet ones going for $250? Is it because its the initial run and will get cheaper the more you make? The 1/2" rail? Thanks.
When it takes more than a sweet mullet to prove you rule at the trailer park..
[Re: DARTH V8Я]
#2064203
04/29/16 08:01 PM
04/29/16 08:01 PM
AndyF
First off, very nice valve covers! But I have to ask cause my knowledge is lacking in this area, what's the difference between your $650 units and other very similar billet ones going for $250? Is it because its the initial run and will get cheaper the more you make? The 1/2" rail? Thanks. There aren't any "very similar" billet covers available for $250. If there were I would've bought them rather than have these built.
[Re: AndyF]
#2064207
04/29/16 08:04 PM
04/29/16 08:04 PM
DARTH V8Я
Its a TRAP!
First off, very nice valve covers! But I have to ask cause my knowledge is lacking in this area, what's the difference between your $650 units and other very similar billet ones going for $250? Is it because its the initial run and will get cheaper the more you make? The 1/2" rail? Thanks. There aren't any "very similar" billet covers available for $250. If there were I would've bought them rather than have these built. Thanks ![thumbs thumbs](/ubbthreads/images/graemlins/custom/thumbs.gif)
