Page 25 of 45 1 2 23 24 25 26 27 44 45
Re: Trick Flow heads [Re: AndyF] #2052942
04/12/16 06:10 PM
04/12/16 06:10 PM
Jamie McGrath Offline
Originally Posted By AndyF
I haven't compared intake runner volumes. I have a stock M1 intake here so I'll give that a try. Might be interesting to see the volume difference if I can figure out a way to measure it accurately.
No flow sheet with the intake, never thought to ask them for one. I don't know if they flow them after porting or not.
Grease and some plexglass too block the runners and fill it with some water from the beaker, well a few beakers anyway. I bet the difference in volume between the two is significant.
Re: Trick Flow heads [Re: fast68plymouth] #2053018
04/12/16 08:10 PM
04/12/16 08:10 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
Andy, what LSA is the cam?
I have my old 264/264 HXL cam on 112 LSA sitting on the shelf if you want to try it?
Re: Trick Flow heads [Re: fast68plymouth] #2053873
04/13/16 09:12 PM
04/13/16 09:12 PM
Wichita Kansas
B Dartman Offline
B Dartman  Offline
Wichita Kansas
Good deal! Nice looking engine but that Pep Boys throttle return spring has to go. Send me your address and I'll shoot you a proper Mopar throttle return spring setup.
beer Thanks Andy!! wrench Mission complete. wave
B Dartman's 71 Dart Swinger in Mopar Muscle (Sold Dec 2021): https://www.hotrod.com/articles/1971-dodge-dart-destiny-determination/
B Dartman's 71 Dart Swinger in Dodge Garage (Sold Dec 2021): https://www.dodgegarage.com/news/article/showcase/2019/04/destiny-determination.html
B Dartman's 71 Dart Swinger early build pictures (Sold Dec 2021): https://s165.photobucket.com/user/Billswild440dart/library/
Re: Trick Flow heads [Re: AndyF] #2063703
04/29/16 12:08 AM
04/29/16 12:08 AM
AndyF Offline
AndyF  Offline
Cab was kind enough to loan me a tunnel ram. Not sure when I'll get back on the dyno but when I do I'll give this setup a whirl. These are a pair of 1000 cfm carbs so probably overkill for this little pump gas motor but we'll try it anyway.
Re: Trick Flow heads [Re: Jamie McGrath] #2063707
04/29/16 12:13 AM
04/29/16 12:13 AM
AndyF Offline
AndyF  Offline
Here is an outside shot of a stock intake and then the second picture shows the outside of the ported intake. It appears that Wilson welded up the outside so they could open up the ports. The stock intake has almost an inch between the center runners while the Wilson intake has a V between the runners.
Andy, I was waiting for someone else too ask and seeing as no one has, I will. What was the stock M1 intake volume compared too the reworked Wilson M1 intake volume? Just wondering as it really picked up after reworking it looks huge inside but it must also be moving plenty of air pretty fast.
Did they give you some type of flow sheet?
I did measure the volume of the intakes. (measured the weight of the water and converted to volume) The stock M1 was 192 cubic inches while the ported version is 213 cubic inches. So an 11% increase in volume due to the porting.
Re: Trick Flow heads [Re: AndyF] #2063711
04/29/16 12:20 AM
04/29/16 12:20 AM
The Pale Blue Dot
Skeptic Offline
Skeptic  Offline
The Pale Blue Dot
Glad that worked out for you Andy. I'm looking forward to the results. That being said you really to top it off with a pair of CarterBrocks. twocents
Re: Trick Flow heads [Re: fast68plymouth] #2063712
04/29/16 12:21 AM
04/29/16 12:21 AM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
thanks Andy ,
I remember filling and measuring my Modman - it was right around 5 litres so just over 300ci . Even after fabbing a filler it was 4 litres . No wonder it was soft down low on the strip with only a 440ci . I will try it on my 505 at some point .
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
Re: Trick Flow heads [Re: AndyF] #2063956
04/29/16 01:07 PM
04/29/16 01:07 PM
Thanks, for the follow up.
Re: Trick Flow heads [Re: fast68plymouth] #2067866
05/05/16 06:26 PM
05/05/16 06:26 PM
AndyF Offline
AndyF  Offline
Anyone running 7/16 pushrods yet with the Trick Flow heads? I mocked it up the other night and it looks like they will clear if the rocker arm is positioned just so.
Re: Trick Flow heads [Re: AndyF] #2071335
05/11/16 10:24 AM
05/11/16 10:24 AM
Madison, Wisconsin
chrisnben Offline
chrisnben  Offline
Madison, Wisconsin
Hi Guys- as some of you know I'm just about done with this 470 low deck with Trickflows (very similar to AndyF's engine) except with a Comp solid cam from Dwayne P. on a 1.6 rocker. This will be a bracket engine going in my '65 Plymouth.
My question to those who already have these heads running- what rocker arms/ratio are you running? Talking with Andy, there are not alot of available choices. I've mocked up my 1.6 "Harland" copies from Mancini Racing (which are supposed to be identical), but IMO are a tad too long of a sweep pattern starting right on center and running 1/8" on the stem where it starts to round again. Now, according to trickflow, these are the recommended ones- but maybe only in a 1.5 ratio??
I'm thinking the Hughes 1.6 might work (or maybe it's the same length??) If by chance there are a set of old Crane golds in 1.6 floating around- those might work as well (same length too??) Anyone try the PRW stainless 1.6's ??
Once we get this figured out- it's off to the Dyno shop. This set-up should be good for 650 HP/ 625 Ft.Lb. boogie
'70 Cuda "Badfish 2"- in the works
Home of MoPar University- We school 'em one at a time!!
Re: Trick Flow heads [Re: chrisnben] #2071376
05/11/16 11:51 AM
05/11/16 11:51 AM
USA
B3RE Offline
B3RE  Offline
USA
Ok, here's the deal on the Trick Flows, as far as rockers are concerned.
The Harland Sharp rockers recommended by TF, are way too long, as they are on most heads, and are even worse on the TFs, because they raised the rocker stands .100" from stock. That is a step in the right direction for better rocker geometry, but they didn't offset the stand when they raised it, which reduced the shaft-to-valve centerline by .025". That is why the shorter rockers seem to fit better, but if the shaft is relocated to properly set rocker geometry, any rocker will work.
Since you mentioned the PRW stainless rockers, I am doing a build right now with them, and just like any other roller rocker, I will have to move the shafts to the right location for that combination. You will need to do the same, regardless of the rocker chosen, if you want it to be right.
BTW, assuming a net valve lift of roughly .650", you should have less than .040" sweep across the valve when it is right. If I'm understanding you correctly, you're looking at .125"? No Bueno, Amigo!
Mike Beachel
I didn't write the rules of math nor create the laws of physics, I am just bound by them.
Re: Trick Flow heads [Re: fast68plymouth] #2071389
05/11/16 12:15 PM
05/11/16 12:15 PM
So. Burlington, Vt.
fast68plymouth Offline OP
So. Burlington, Vt.
The specific HS part number recommended by TF for these heads("E" at the end of part number)are shorter than the std HS rockers and should fit just fine.
The std HS rockers, along with the Mancini version, are too long.
IMO, this was a mistake made by TF when these things were on the drawing table.
They should have had the shafts located so that the std HS rockers fit properly.
Re: Trick Flow heads [Re: fast68plymouth] #2071400
05/11/16 12:32 PM
05/11/16 12:32 PM
USA
B3RE Offline
B3RE  Offline
USA
They might fit just fine, but a shorter fulcrum sweeps more, so it will actually sweep slightly more. Still no good.
Mike Beachel
Re: Trick Flow heads [Re: fast68plymouth] #2071401
05/11/16 12:33 PM
05/11/16 12:33 PM
AndyF Offline
AndyF  Offline
Hughes 1.60 rocker arms
Re: Trick Flow heads [Re: fast68plymouth] #2071402
05/11/16 12:33 PM
05/11/16 12:33 PM
AndyF Offline
AndyF  Offline
Harland rocker arms (long ones, not the E)
Re: Trick Flow heads [Re: fast68plymouth] #2071404
05/11/16 12:34 PM
05/11/16 12:34 PM
AndyF Offline
AndyF  Offline
Crane 1.60 rocker arm. Short style, discontinued.
Re: Trick Flow heads [Re: fast68plymouth] #2071434
05/11/16 01:50 PM
05/11/16 01:50 PM
So. Burlington, Vt.
So. Burlington, Vt.
Andy, retry that with the 700lbs open pressure to show the "loaded" ratio.
Is that on a .450 lobe?
Re: Trick Flow heads [Re: B3RE] #2071454
05/11/16 02:29 PM
05/11/16 02:29 PM
Alberta,Canada
605ply Offline
605ply  Offline
Alberta,Canada
....i used mikes relocation kit with my HS 1.5s that i already had
seemed to be the best and most economical solution?
Re: Trick Flow heads [Re: fast68plymouth] #2071471
05/11/16 02:43 PM
05/11/16 02:43 PM
AndyF Offline
AndyF  Offline
0.445 to be exact and zero lash. I'll recheck once I get the new springs installed. I was using a checking spring so I could verify VP with the new ratios. I'm good to go to 1.70 rocker arms with this cam. I just need to find someone who sells a high quality 1.70 rocker arm that fits the Trick Flow head.
Re: Trick Flow heads [Re: AndyF] #2071521
05/11/16 04:22 PM
05/11/16 04:22 PM
So. Burlington, Vt.
So. Burlington, Vt.
I would say a head might have to make it's way to T&D for that.
The pic of the scrub pattern with the RAS rockers on page 10 of this thread looks pretty good to me.
