Check the bore in reaction shaft support where the input shaft sealing rings ride. Probably grooved up and bad there.
i know this is an old thread, but can someone explain why the bore in the reaction shaft would groove? i'v had a bushing that had grooved in the reaction shaft bore shruggy
