Re: How much clearancey between lifter link/rivets and block?
[Re: 416challenger]
#2063474
04/28/16 04:41 PM
04/28/16 04:41 PM
Posts: 43,233 Bend,OR USA
Cab_Burge
[Re: kielbasa]
#2063491
04/28/16 05:22 PM
04/28/16 05:22 PM
Posts: 14,506 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
59* block, link bars next to the valley wall, like in the pic. If it has a true .015 clearance, I'd run it . If something wears to the point where that .015 goes away, you've got other problems.
Check every pair, it's often the case where some clear, some don't.
