Re: E Body Hemi fender Question
[Re: Paul Jacobs]
#206147
10/22/10 07:02 PM
10/22/10 07:02 PM
Posts: 2,966 Wendy, I'm home.
dstryr
Wendy, I'm home.
5.The 340 T/A and 340 Six Pac hoods were designed and built at the above mentioned studio.I worked on that project (at least 10 different versions) while we waited for more 70 Hemi e-bodies.
Did Creative have a Canadian location?
Not that I knew of but they were around until the 90's.Creative was a full service company that could do almost any type job for the OEM's.They had complete machine shop,wood shop,design,styling and engineering and more.
OK.....
So, if your statement - "The 340 T/A and 340 Six Pac hoods were designed and built at the above mentioned studio." is true, can you explain why the T/A hoods were stamped MADE IN CANADA?
Several original lift off RR hoods I have had were also stamped Made in Canada.
Paul, Can you verify that any were original to the cars you have had or not? I was told many years ago that the Made In Canada stamp on the bottom of an A12 hood indicated it was a replacement, but have never verified that claim either way.
Thanks!
dstryr, since 1986.
[Re: P1970HeMICuDA]
#206149
10/23/10 03:17 AM
10/23/10 03:17 AM
Posts: 1,668 Mi,U.S.A.
mike s
Mi,U.S.A.
It has come to my attention that my comments here have upset some in the "hobby".If anything here has been mistated I will post a retraction.100% of my posts concerning the 70 Hemi fenders are direct comment from me,the other person who did the fenders and his brother who fabricated the tooling used to do the work (20+ year Creative employee).They are 100% firsthand.Please note that they along with another brother and a very close friend (40+ yrs) all worked at the other Creative facility and worked on the following projects, Daytona's,Superbirds and A-12's.
Leave the gun.......take the Cannoli's....Mike
[Re: mike s]
#206150
10/23/10 10:16 PM
10/23/10 10:16 PM
Posts: 29,657 Hamtramck, PA
Alaskan_TA
Fluffy Balladeer
Fluffy Balladeer
Hamtramck, PA
Odd that anyone would be upset. Some of the details on these cars are extremely hard to find 40 years later. Some things are not meshing together, but hopefully we can figure them out with time. That said, I did some more digging. I have more questions than answers at this point. New wider oval 15-inch 60 series tires are standard with 340 and 426 engines; http://www.hamtramck-historical.com/images/dealerships/DealershipDataBook/1970/70_Challenger0005.jpgA66 cars show the std. wheel lip moldings are deleted; http://www.hamtramck-historical.com/images/dealerships/DealershipDataBook/1970/70_Challenger0024.jpgSame tires, so why mention the moldings being deleted only on the 340 cars if they intended to leave them off the 426 cars too? From the 1970 Hemi Challenger broadcast sheets I have here, those with scheduled production dates Dec. 16 & before are coded for the wheel lip moldings. Those with scheduled production dates from March fifth up are not, no code at all. Some AARs are coded M27 - Wheel lip molding delete. So, if the 1970 Hemi Challengers were meant to have the standard wheel lip moldings deleted, why did they not use the same code? If anyone has a broadcast sheet for a 1970 Hemi Challenger between the scheduled production dates of C16 & 305 please send me a scan or copy? Or if you have one not consistent with my findings in those date ranges? I do love a good mystery.
[Re: Alaskan_TA]
#206151
10/23/10 10:44 PM
10/23/10 10:44 PM
Posts: 17,524 Las Vegas, NV
6bblgt
Las Vegas, NV
I agree - great thread - keep the info flowing!! A66 Challengers recieved E60-15 Polyglas GT tires STANDARD (* early A66 production) HEMI Challenger R/Ts recieved F60-15 Polyglas GT tires STANDARD I'd WAG the "delete" wheel lip mouldings was a cost cutting tactic for the A66 package. Delete the wheel lip mouldings & give the cars a "performance" hood? Mike, how early in the model year did Creative start modifying HEMI 'Cuda & Challenger R/T fenders? When did they stop? HEMI R/T SPD-817 YES wheel lips on b'cast HEMI R/T SPD-A27 YES wheel lips on b'cast HEMI R/T SPD-121 no wheel lips on b'cast HEMI R/T SPD-512 no wheel lips on b'cast
[Re: Alaskan_TA]
#206156
10/23/10 11:36 PM
10/23/10 11:36 PM
6bblgt
Las Vegas, NV
Hey Dan, since you are our resident 'tire guy' do you know the actual inflated dimensions of an A66 tire (U82) vs. the U84 dimensions on the Hemi cars?
I might be able to do something like that.
[Re: 6bblgt]
#206157
10/23/10 11:42 PM
10/23/10 11:42 PM
6bblgt
Las Vegas, NV
Two 4/14/70 Chrysler 15x7.0" "rallye wheels" w/E60-15 & F60-15 tires. F60-15 (1972 tire) - 81.75" 82.53" circumference (= 26.02" 26.27" diameter) & 8.00" 8.25" wide tread E60-15 (1974 tire) - 80.25" 82.00" circumference (= 25.54" 26.10" diameter) & 7.63" 7.50" wide tread Both are used and worn, I wanted to put both tires at same pressure but no tire gauge to be found. & only half the width difference (3/16") would be toward the fender. dimensions in RED from KELSEY TIRE's web site
[Re: Dartman440]
#206160
10/24/10 12:14 AM
10/24/10 12:14 AM
Posts: 704 USA
rftroy
USA
Here is the page from the May 70 version of the 1970 parts book. Shows different B and J with and without 15 inch wheel. But, 6.00 X 15 Tires means ?
Bob
AAR 4-speed 3.91, Tor-Red; 70 440 6 pack Roadrunner 4-speed 3.54, Plum Crazy; 68 Formula S conv 383 4-speed 3.23, Electric Blue; 69 Barracuda conv Slant 6 OD4 2.94, 71 B5 Blue; 78 Lil' Red Truck, Red; 70 Challenger S/E. 505 6 pack, Passon 5-speed, 3.55, B7 Blue
[Re: Alaskan_TA]
#206161
10/24/10 12:22 AM
10/24/10 12:22 AM
mike s
Mi,U.S.A.
Your source is incorrect.Creative did not make a tool for Chry.They did fab the tools for us.Chry did not hand modify any Hemi fenders.They restamped the fenders with the problem area removed.Availablity of the new fenders seems to coinside with the March 5 cut off date for the moldings.Only those later cars have the second tag. We begin work the last week of Sept 69 and finished about March 1st 70 (see March 5).We did 10-15 cars per day at least.The Creative lot was full of cars (100+ or more) when we started as was the area where we did the work.(about 18 cars)We did have weeks where we did other work including the holidays.Maximum of 5 weeks total.Those numbers prove only a very small amount of cars got out witout the mods. If anyone recalls the model year and new car roll out started about the second week of Sept in those days.There is another issue.We changed the wheels and tires on many many cars.I beleive it was the Magnum 500 wheels that were not available when the cars were built.Possible it was the tires or both.Due the that issue and the original reason for the mods we think the cars were held back.It is entirely possibly that a small number were shipped out mistakenly.There are examples of unmolested cars with no fender mods.So far they seem to be Cudas that were wheel lip delete.We did modify other Cudas w/lip mouldings delete but it was rare for a Cuda. This was a late change and they were in a hurry.I hope to find some paperwork but I doubt I will be able to access the archives since Creative was sold. Hope this helps.
