Re: intake sellection for 511 [Re: Sport440] #2061258
04/25/16 10:07 AM
04/25/16 10:07 AM
Mt Morris Michigan
mopar dave Offline OP
Mt Morris Michigan
ok, looks like victor, super victor or indy 400-2. I do want to make some power with this 511. 650 would be nice but 700+ would be perfect.
Re: intake sellection for 511 [Re: mopar dave] #2061269
04/25/16 10:26 AM
04/25/16 10:26 AM
Alberta
Wookie316 Offline
Wookie316  Offline
Alberta
1971 Plum Crazy Super Bee. 572 World Aluminum block with a Cope 727 & Dana 4.10 out back. 9.88 @ 138 with a 1.35 60 NA. Dialed back to 10.0’s. 4000 lbs with me in it.
Re: intake sellection for 511 [Re: Wookie316] #2061288
04/25/16 11:00 AM
04/25/16 11:00 AM
Mt Morris Michigan
Mt Morris Michigan
thats the power range i would like to end up at. your cam seems alittle conservative for the compression. mine will be 11.5:1 comp and im thinking a flat solid cam of mid 260's on the intake and .650 lift. going in a 67 barracuda notch at 3350#. currently have a 4.30 gear with 28" tire. may have to put the 4.10's back in with this combo. very nice car you have.
Re: intake sellection for 511 [Re: mopar dave] #2061300
04/25/16 11:24 AM
04/25/16 11:24 AM
Alberta
Wookie316 Offline
Wookie316  Offline
Alberta
I wanted to go bigger on the cam. My builder assured me it would be enough for my car. We'll see when I make my first pass this year.
Re: intake sellection for 511 [Re: Wookie316] #2061304
04/25/16 11:35 AM
04/25/16 11:35 AM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
Dave,
Go with the Indy single, IMO your car is light enough so with enough stall (like a tight-ish 8") and compression that you won't have much issue with low end distribution. the 400-2 can be a bit of a Light-switch but with the right cam and weight it won't be bad at all. I've ported Holley street dominators to very close to MW size and they work awesome with a spacer. Do you know your head flow? Remember the Runner CC on the indy's and the victors can be a bit deceptive compared to standard mopar heads since they incorporate the CC volume of a comparable Stage VI intake spacer into the casting.
I run the ported MP 337 Single on my low deck (but I have the Chapman Stage V1's) and it'll still "pull the hinges off the gates of He!!" down low.
Tell me about those 360-1 heads in a PM, I just bought an R3 block and I'm thinking turbo devil
WIZE
In Car:
Re: intake sellection for 511 [Re: mopar dave] #2061333
04/25/16 12:40 PM
04/25/16 12:40 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Todd's heads are MW size.
For a low deck manifold, afaik there are basically 3 choices for "bolt on" installation and a single carb............Indy 400-2, 400-3, Mod Man.
Re: intake sellection for 511 [Re: Streetwize] #2061336
04/25/16 12:43 PM
04/25/16 12:43 PM
Mt Morris Michigan
Mt Morris Michigan
ok, indy 400-2? heads i will use on this 511 are victors with hughes cnc. flow 359@.600,.700.800. cc is 332 im told. looking at the hughes solid flat cams right now. there 264/268 and 268/272@50 and .650".
the 360-1's i will be selling soon were fully ported by dwayne welder. port size is 330cc avg and flowed 330cmf on best port. so 328cfm avg. will be sold with 1.6 T&D rockers. still in shop getting a couple valves replaced from the engine failure and cleaned up. they have new ferrea compitition + valves and new pac springs for solid roller.
Re: intake sellection for 511 [Re: mopar dave] #2061341
04/25/16 12:45 PM
04/25/16 12:45 PM
So. Burlington, Vt.
So. Burlington, Vt.
I'll bet you a dollar your 360-1's aren't 330cc(or to put it another way, 85cc's bigger that the CNC 245's).
Re: intake sellection for 511 [Re: mopar dave] #2061348
04/25/16 01:02 PM
04/25/16 01:02 PM
Alberta
Wookie316 Offline
Wookie316  Offline
Alberta
Use a Howard's cam. Cheaper than Hughes.
http://m.summitracing.com/parts/hrs-720152-08
Re: intake sellection for 511 [Re: Wookie316] #2061406
04/25/16 02:33 PM
04/25/16 02:33 PM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
Yeah, 330+ cc seems a big large for a 360-1 head.
Don't mean to threadjack.
WIZE
In Car:
Re: intake sellection for 511 [Re: fast68plymouth] #2061429
04/25/16 03:06 PM
04/25/16 03:06 PM
Mt Morris Michigan
Mt Morris Michigan
yes, your right. 230cc. my mistake. dont know what i was thinking there.
