I guess if the build was intended to turn 7K and make 750+ HP, both different heads and intake would have been used. I don't disagree that heads that small probably aren't the best match for 500-ish c.i. builds, unless the expectation is that it's going to be choked down in RPM and HP compared to "bigger" choices for heads, intake & cam.
