Re: Just drove the Hot Rod [Re: Hemijoejr] #2060603
04/24/16 01:35 AM
04/24/16 01:35 AM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
Get a spare converter.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Just drove the Hot Rod [Re: pittsburghracer] #2060762
04/24/16 12:44 PM
04/24/16 12:44 PM
Charleston
sixpackgut Offline OP
Drag Week Mod Champion
Charleston
Lol, that sounds expensive
I actually did some research on the converter hub problem
It seems there was one particular co that uses a certain hub that holds up very well in 904s. When I called Lenny at Ultimate we discussed this for a while and told me he also uses that same hub. Its more expensive and made from whatever steel and is alot stronger, there is alot less slop on pump tangs and he also has never had a failure. Now that Ive said this I hope I didnt jinx myself but I think the aftermarket may be making better parts now
Re: Just drove the Hot Rod [Re: sixpackgut] #2060901
04/24/16 05:27 PM
04/24/16 05:27 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
I didn't have converter issues but had a hard time keeping the pump ears from shearing off!
