question. Recently purchased upper door panel from legendary in white color code 100. Painting lower door panels to match. Want to use Sem dye paint, does anyone know which color white will match upper panels. Thanks for help
I'd try either SEM SUPER WHITE, it's a little on the oyster white color range, excellent match for 70 interiors, or aged white interior components, if the Legendary Interior panels are really brite white, then perhaps SEM's SAILCLOTH white, it's the brightest white they have, I'd recommend you finish off the last spray coat with SEM's LOW LUSTRE CLEAR, won't leave any sheen, looks natural, but protects the "dyed" surface from stains/mars/scuffs/etc, and allows for easier cleaning with out damaging the "dyed" surface
