Re: Screen in lifter valley? [Re: turbo toad] #2059136
04/21/16 04:50 PM
04/21/16 04:50 PM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
My block is done in four sections with Moroso epoxy. Three smaller, rectangular pieces cover the openings over the cam and on larger "T" shaped piece protects covers the opening in the front near the tower shaft bushing.
I was mostly mitigating the cam or oil pump drive from accidentally digesting a 7/16" pushrod and not too concerned with a small mesh size due to bushed roller lifters and non-needle bearing rockers. It would make sense to use a mesh smaller than your smallest part.
For a supplier check ebay. There was a guy selling smaller sections of stainless in any mesh size you can think much cheaper than the typical industrial supply shops.
Re: Screen in lifter valley? [Re: gregsdart] #2059505
04/22/16 03:46 AM
04/22/16 03:46 AM
Originally Posted By gregsdart
Nice work on those screens up I need to go smaller mesh to stop needle bearings from getting down to the oil pump ,gear drive or oil pump gear. Anybody run anything with smaller mesh? I figured that it might work to put a finer mesh over the screen in the oil pan, but that might not protect the gear drive?
Putting mesh above the roller wheels won't stop the needles from falling out the bottom of the lifter bores, will it workI had two Mopar brand solid roller wheels break in half and get the cam, luckily I shut the motor off before sucking any of the needles bearing up into the oil pump shruggy
Re: Screen in lifter valley? [Re: gregsdart] #2059650
04/22/16 01:00 PM
04/22/16 01:00 PM
Alexandria, LA
Blucuda413 Offline
Blucuda413  Offline
Alexandria, LA
I used aluminum window screen on my X block. There were enough holes and area that I was not concerned about the small mesh. I even build a dam for the rear of the block and screened a couple holes in it to give additional exit space. I did all this after a lifter came apart and thankfully no major damage was done. I used JB Weld to glue the screen to the block. Has worked great.
Re: Screen in lifter valley? [Re: gregsdart] #2059977
04/22/16 09:57 PM
04/22/16 09:57 PM
Wild West
M_D Offline
M_D  Offline
Wild West
I have a basic concept of securing the screen without screws or epoxy. I'll make a drawing and post it here. With the various blocks (e.g. factory, megablock, KB, and etc.) there are differences in the shape geometry around the drain holes though.
Re: Screen in lifter valley? [Re: gregsdart] #2059986
04/22/16 10:13 PM
04/22/16 10:13 PM
Duloc
The Shadow Offline
The Shadow  Offline
Duloc
Why bother with valley screens?
Put a hydraulic filter strainer on the suction line in the pan and all your issues are solved.
Ran my milodon pump that way for 10yrs and the pump was like new inside.
Re: Screen in lifter valley? [Re: The Shadow] #2060065
04/23/16 12:15 AM
04/23/16 12:15 AM
aotearoa
rebel Offline
rebel  Offline
aotearoa
you would not believe the amount of damage something like a broken lashcap can do to an engine if you're also running a windage tray. they chip away at your rods leaving potential stress points for a crack to develop into a break. Also broken rocker arms falling into the oil return holes tend to break cams & that in turn does other damage. Valley screens are worthwhile if you're a regular racer.
Re: Screen in lifter valley? [Re: M_D] #2060090
04/23/16 01:01 AM
04/23/16 01:01 AM
michigan
turbo toad Offline
turbo toad  Offline
michigan
Thanks id appreciate it, i fabbed up a hold down today like what rebel posted the pics of and received some screen today but haven't started any block mods but im hoping to get the block in this week or next for final machining so I'm trying to dot all my eyes and cross my teessss.
Check out my build on Facebook Ttoad Hurley its updated regularly
Re: Screen in lifter valley? [Re: gregsdart] #2060100
04/23/16 01:40 AM
04/23/16 01:40 AM
Its a TRAP!
DARTH V8Я Offline
Oh No!! I just had a moron attack!
DARTH V8Я  Offline
Its a TRAP!
^^ Love you car man.. callme
When it takes more than a sweet mullet to prove you rule at the trailer park..
Re: Screen in lifter valley? [Re: Cab_Burge] #2060102
04/23/16 01:43 AM
04/23/16 01:43 AM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
iagree Wont stop the needle bearings, but the screens are a good idea.
Re: Screen in lifter valley? [Re: Cab_Burge] #2060149
04/23/16 03:06 AM
04/23/16 03:06 AM
Wild West
M_D Offline
M_D  Offline
Wild West
Greg has had issues with rocker arm failures and is focused on keeping broken rocker parts contained.
Re: Screen in lifter valley? [Re: Sport440] #2060262
04/23/16 12:08 PM
04/23/16 12:08 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I've never broke a rocker that the needle bearings
came out(knock on wood) but have had lash caps and
broken PRs laying in the valley.. I dont want that
trash getting hung up on a cam or have it fall down
onto the crank/rods at 8000+ rpm.. that screen has
done its job for me a FEW times... the lifters are
below the screen so it might not help with them
but it does help for stuff up in the heads
wave
Re: Screen in lifter valley? [Re: gregsdart] #2060263
04/23/16 12:13 PM
04/23/16 12:13 PM
gregsdart Online content OP
gregsdart  Online Content OP
Afterr reading Cab's comment about the roller lifters, though I haven't lost any, I may opt for a finer screen in the pan to go over the one that is there. That one though will need to be sized as big as possible and still stop the needles. Anybody know what size roller lifter bearing needles are?
Re: Screen in lifter valley? [Re: gregsdart] #2060265
04/23/16 12:18 PM
04/23/16 12:18 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Greg.. myself I wouldnt do that.. if you make that small
enough to stop anything that could get there I dont think
you would get the flow you would need.. specially on cold
oil... JMO.. at some point you just have to take your chances
and hope it doesnt happen
wave
Re: Screen in lifter valley? [Re: MR_P_BODY] #2060304
04/23/16 01:39 PM
04/23/16 01:39 PM
Alexandria, LA
Blucuda413 Offline
Blucuda413  Offline
Alexandria, LA
On my roller lifter failure it was the upper part of the lifter that failed and left the 2 lifters untied. Even tho small parts got down in the rotating assembly I was fortunate enough to discover the problem before either lifter turned so the damage was not nearly as bad as it could have been. I will not run another without some fine screen to keep the parts on top.
Re: Screen in lifter valley? [Re: Blucuda413] #2060352
04/23/16 04:06 PM
04/23/16 04:06 PM
I should have clarified in my first post that screens are a good deal thumbs Not intending to keep anyone from using it, sorry blush I've had lash caps and psuhrods drop down into the lifter valley when a valve spring broke whiney
Re: Screen in lifter valley? [Re: gregsdart] #2060362
04/23/16 04:31 PM
04/23/16 04:31 PM
Its a TRAP!
DARTH V8Я Offline
DARTH V8Я  Offline
Its a TRAP!
Why not use a bushed roller lifter? Safer & a lot stronger. Personally I don't trust needle bearings at any level
https://www.lunatipower.com/News.aspx?id=121
Re: Screen in lifter valley? [Re: DARTH V8Я] #2060368
04/23/16 04:39 PM
04/23/16 04:39 PM
MR_P_BODY Offline
MR_P_BODY  Offline
When I bought all my stuff they didnt make the bushed lifters..
if I were buying something now I MIGHT look at them.. but
as I said already.. I have never had a needle bearing come
apart on me.. been using them for years now
wave
Re: Screen in lifter valley? [Re: DARTH V8Я] #2061047
04/24/16 09:50 PM
04/24/16 09:50 PM
michigan
turbo toad Offline
turbo toad  Offline
michigan
Thanks DARTH if that thumbs up was for my bucket of bolts... drive
Heres what i came up with using the design rebel posted and I ended up using a 1/4 20 bolts, I had to take it slow drilling the first 1/4 inch making sure it was straight it could of blew out a side every easily as theres only a tad over a 1/4 inch of meat on the rib.
Re: Screen in lifter valley? [Re: gregsdart] #2061115
04/24/16 11:26 PM
04/24/16 11:26 PM
aotearoa
rebel Offline
rebel  Offline
aotearoa
you did well. i used a 7/16 drill for a pilot hole first but you got it done. now loctite in a stud & you're ready for a nylock nut to seal the deal.
