Re: DAKOTA DONORS- WHAT YEARS R BEST-Whos used them?
[Re: fstfish66]
#660840
04/12/10 02:17 PM
04/12/10 02:17 PM
Posts: 773 Crofton, Ky.
rattler
Crofton, Ky.
Scratch wanted some more pics,
1957 Dodge truck, Snakeskin Green with a little stroker motor. 1964 Plymouth Savoy wagon ( my new project)
[Re: RUMBLON]
#660845
07/23/13 07:29 PM
07/23/13 07:29 PM
rattler
Crofton, Ky.
For those few that have not seen my 57 in paint.
[Re: rattler]
#660846
07/23/13 07:32 PM
07/23/13 07:32 PM
rattler
Crofton, Ky.
under hood shot
[Re: rattler]
#660847
07/23/13 08:50 PM
07/23/13 08:50 PM
Posts: 9,857 Cambridge Idaho
RUMBLON
Cambridge Idaho
BEAUTY-- is that snakeskin green? a Viper color?
RUMBLON
[Re: RUMBLON]
#660848
07/23/13 10:46 PM
07/23/13 10:46 PM
rattler
Crofton, Ky.
Yep, Viper color. I don't think it would get near as much attention if it was a different color.
[Re: RUMBLON]
#660851
11/18/13 10:05 PM
11/18/13 10:05 PM
moparpollack
Lil Herman
Lil Herman
85086
If I found a 87 era Dakotawith the V6 in it, will the k member take the V8 or will that have to be replaced.???
Rumblon
I used spool mounts on the motor with custom mounts on the frame.
[Re: RUMBLON]
#660852
11/19/13 12:03 AM
11/19/13 12:03 AM
Posts: 10,654 Freeport IL USA
poorboy
Freeport IL USA
Rumblon
There is no replaceable K member on a Dakota. They are a one piece frame like the full sized trucks. In a hot rod, the V8 in place of the V6 is not an issue, in the real truck, the 87 engine compartment was smaller the the 88 & newer and firewall and radiator clearance may become an issue.
[Re: RUMBLON]
#660853
11/21/13 02:44 AM
11/21/13 02:44 AM
Posts: 1,757 levittown pa
fstfish66
levittown pa
Rumblon
I would like to think its the same K frame,but i do not know for sure,,but the 1987 3.6 v6 is a 318 minus 2 cylinders,i would think they share the same block motor mount ears,,,either way its not hard to fab a bracket to use the spoool mounts,,also you can check a guy callled schumaker he makes all sorta of adapter and better then original mopar motor mounts
1966 barracuda prostreeter super charged 340(SOLD) 1940 dodge coupe 241 hemi street rod 2014 ram express hemi 4x4 dailey driver 2015 cherokee 2013 R/T classic
[Re: fstfish66]
#660854
11/21/13 03:52 PM
11/21/13 03:52 PM
moparpollack
Lil Herman
Lil Herman
85086
If my frame wouldn't of been hacked in the first place I would of just put a mustang II on it. There is a 200 hours in just getting the frame to work.
[Re: RUMBLON]
#660857
10/02/14 02:32 AM
10/02/14 02:32 AM
poorboy
Freeport IL USA
My 48 Plymouth has a throttle body EFI, 3.9 V6, from a 1990 Dakota, mine has the 5 speed and 3:55 gears. (It actually has the full Dakota frame under it.) The car is fun to drive, it feels fast, even though it really isn't. I can get a chirp from the 235 x 75 x 15 radials through a good tight limited slip rear axle in 3rd gear! I get 17 mpg beating the crap out of it, and it will get over 20 on the highway if I can keep it around 70. When I blow this 3.9 up, there is another one waiting. Nothing wrong with the 3.9, they are tough, have decent power range, a will pull decent mileage. The only issue I see is there is little aftermarket support, as far as performance parts available. I am considering a turbocharger for the next 3.9, time will tell. Gene
[Re: RUMBLON]
#660858
10/09/14 03:07 AM
10/09/14 03:07 AM
fstfish66
levittown pa
Found a 89 with a V6 in it. Are these V6s any good for a ratrod project? This one is an auto, I would like to build a cheapo ratrod using a mid 40s truck cab. Now that I have the move to Idaho done and a small place built to live I have time to start looking around.
RUMBLON
I had one of those v6 dakota 1987 3.9 v 6 5 speed 2 bbl was a good motor,,,if you look around you may find a mopar performance 4 bbl intake,,, i dont know if any after market intakes were made for that motor,,,its a 318 minus 2 front cylinders
