What material for brake caliper brackets?
#2058377
04/20/16 02:06 PM
04/20/16 02:06 PM
Posts: 7,501 Minnesota
Hemi_Joel
Minnesota
I am going to fab some caliper brackets out of 5/16 aluminum plate to mount some Aerospace calipers on a 9" ford with 11.44" x 5/16" discs. Is 6061-T6 adequate, or should I try to find some 7075-T651? Or something different? This is a street/strip car, but not a wintertime car, so corrosion resistance is not a big factor. Thanks, Joel
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
Re: What material for brake caliper brackets?
[Re: Hemi_Joel]
#2058434
04/20/16 03:26 PM
04/20/16 03:26 PM
Posts: 52,972 Romeo MI
MR_P_BODY
6061 T6 will work fine. the brackets on my diff are made from it EDIT As to corrosion.. I painted them black(rustoleum spray paint).. been on the race car over 15 years now.. granted I'm not stopping 4000# but I stop my junk from 151 mph and 99% of the time I dont pull the chute.. just the brakes and on some of the tracks its a short shut down area so I am on the brakes pretty hard and with skinny fronts I do about 85% of the braking with the rear tires
[Re: Hemi_Joel]
#2058471
04/20/16 04:03 PM
04/20/16 04:03 PM
Posts: 22,806 Bitopia
jcc
Bitopia
I am going to fab some caliper brackets out of 5/16 aluminum plate to mount some Aerospace calipers on a 9" ford with 11.44" x 5/16" discs. Is 6061-T6 adequate, or should I try to find some 7075-T651? Or something different? This is a street/strip car, but not a wintertime car, so corrosion resistance is not a big factor. Thanks, Joel IMO, a 5/16" disc indicates not a lot of stopping repeatedly going on, therefore 6061 would be more then adequate, unless the calipers are really offset on the brackets, and I'm a big fan of overkill. I would not suggest welding on any alum caliper bracket, ever.
[Re: Hemi_Joel]
#2058517
04/20/16 05:13 PM
04/20/16 05:13 PM
Posts: 4,213 New York
polyspheric
New York
X2 - straight tension is best, if you need a big step go up on thickness.
Boffin Emeritus
[Re: Hemi_Joel]
#2058524
04/20/16 05:25 PM
04/20/16 05:25 PM
Hemi_Joel
Minnesota
they'll be pretty dog gone straight.
[Re: jcc]
#2058565
04/20/16 06:34 PM
04/20/16 06:34 PM
Posts: 5,207 Menomonee Falls
DemonDust
Menomonee Falls
Why?
[Re: Hemi_Joel]
#2058596
04/20/16 07:57 PM
04/20/16 07:57 PM
Hemi_Joel
Minnesota
Clanton, That looks like what I'm doing. I'm mounting 2 calipers on each: one 4 piston hydraulic, and 1 cable operated mechanical. This is a street car with a manual trans, so I want a parking brake. Also, I was at the Mopar Nats in '06 when that guy in the Dart lost his brakes and went off the end of the track. Not pretty. ![frown frown](/ubbthreads/images/graemlins/custom/frown.gif) I want an emergency brake. ![up up](/ubbthreads/images/graemlins/custom/thumbs_up.gif)
[Re: Clanton]
#2058612
04/20/16 08:19 PM
04/20/16 08:19 PM
Hemi_Joel
Minnesota
I use a hydraulic hand brake for e brake on 1 of the calipers. I was contemplating doing that. How's it working out for you?
[Re: Hemi_Joel]
#2058637
04/20/16 08:59 PM
04/20/16 08:59 PM
Posts: 4,489 northern,Ohio,USA
Clanton
northern,Ohio,USA
I use a hydraulic hand brake for e brake on 1 of the calipers. I was contemplating doing that. How's it working out for you? I tested it at the stripe[138mph 3900# car]with medium force slowing to about 40 a couple times and it did great.I have a hotter pad in the ebrake also.I would be interested in your cable parts list just for the info.
[Re: Hemi_Joel]
#2058642
04/20/16 09:25 PM
04/20/16 09:25 PM
Hemi_Joel
Minnesota
Wilwood MC4 Mechanical Calipers 120-12069-BK and 120-12070-BK. I have an old style floor mount E brake handle. Not sure on the cables yet.
[Re: Hemi_Joel]
#2058804
04/21/16 02:28 AM
04/21/16 02:28 AM
Posts: 4,785 Utah and Alaska
astjp2
Utah and Alaska
So I guess the .400" thick 4140 is overkill for my front brake caliper brackets?
1941 Taylorcraft 1968 Charger 1994 Wrangler 1998 Wrangler 2008 Kia Rio 2017 Jetta
[Re: DemonDust]
#2058845
04/21/16 08:31 AM
04/21/16 08:31 AM
jcc
Bitopia
Why? 1. the item has no redundancy if it fails, ie loss of on all braking on that hydraulic circuit 2. The potential great damage/harm to car, driver, others, by any crash caused by sudden loss of braking effort 3. For example, 6061 T-6 has a tensile strength of around 43K psi, in the welded zone , if not re heat treated, the tensile strength drops to around 11K psi 4. the rapid variation of strength from high to low back to high at/near the welded zone is an effective source for a welded induced stress riser. 5. Any welding induces some pre stress into the material iupon cooling 6. All alum fatigues, it fatigues at a faster rate as it is loaded closer to its limits, and in this case that limit varies greatly thru the welded zone 7. Alum fatigues even faster when reverse load, but luckily that only happens in this case when braking in reverse, but it does occur.
[Re: Jerry]
#2059520
04/22/16 07:22 AM
04/22/16 07:22 AM
jcc
Bitopia
Upon further reflection, I am not yet convinced our concern about flange deflection caused by caliper offset is really that much of a real concern. My reasoning is any deflection is initially caused by the caliper tightly griping a turning rotor, and if the caliper mounting deflects, the rotor or the caliper has to also deflect, )))edit((( However with the Op's 5/16" rotor, its not overly stiff say compared to a 1.25" thick rotor. And this is a rear axle set up and relatively has much less loading then a front axle.
